Old Sep 18, 2004, 06:55 PM
Rogerdoger is offline
Find More Posts by Rogerdoger
Rogerdoger's Avatar
United States, CA, Clovis
Joined Apr 2002
Question
Micro Tiger Moth Build - Questions
Micro TM
I am wondering if there are some folks out there who have built this little Tiger Moth and might have some suggestions for me. I have not built a kit like this before and there are some things that must be assumed that I donít know and lack experience.
First of all, where is the best place to locate the wires for the rudder and elevator? Should they run along the inside of the body?
Secondly, what have you done for adding color to the wood? I read about watercolor paint, but that will not always be the same depending on the piece of wood being painted. Options?
I have much of the plane together, but the fuselage is twisting at the rear. I have not tried to steam it out. One of the sides is much harder than the other. I probably should have made another fuse half, but I didnít think it would be a problem. Suggestions?
Also, please jump in with any pictures that may help me. Iím a visual learner, so they are worth thousands of words to me.
Roger
Rogerdoger is offline Find More Posts by Rogerdoger
Old Sep 18, 2004, 06:58 PM
Rogerdoger's Avatar
Joined Apr 2002
Micro TM
Here is a pic of the pieces.
Roger
Old Sep 18, 2004, 07:30 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Are you building from a kit or scratch from plans? The wires ahould be inside the fuse. Moving the actuators from the tail to inside the fuse with a remote actuator setup makes it much easier to balance. Looks like you have a bit of glue on the aft portion of the fuse too. That just adds weight to the tail. Nasty gaps in the top of fuse in front too. You can cut another fuse from a single piece of wood and help with the bowing /twisting problem. Take two fuse side templates and tape them together at the top seam on the turdle deck (aft of the back cockpit) and cut it out as a single piece. Join the top seams between the cockpits and forward before you worry about adding formers. You just have to take your time and be careful to get it straight.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Sep 18, 2004, 07:52 PM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
If you CA'd it together, acetone will debond it so you can try again...
Mike Taylor is offline Find More Posts by Mike Taylor
Old Sep 18, 2004, 08:19 PM
Rogerdoger's Avatar
Joined Apr 2002
Micro TM
tiberius,
I am building the kit. I decided to get the whole thing or I might not have begun. I got the gap at the cocpits by seating the former too high. I didn't pre-fit the wood around it. I wish there had been some warning about that before I began. There is very little instruction to follow. The front is not finished and will fit together ok, I think.
Mike Taylor,
It is CA. I realy can't use acetone here, so I may just cut out new parts and see what happens. At the same time, I may just push on from here and see how it goes.
I have the actuators that are the colis and magnets. I thought I was ordering the remote ones with the throw, but I just didn't know what to specify. I found the kind I wanted at Bob's Selman's place. Will they work with any receiver?
Thanks for your tips and input guys,
Roger
Old Sep 18, 2004, 09:59 PM
Rogerdoger's Avatar
Joined Apr 2002
Micro TM
I was wondering if either of you still have any pics of your model to post?
Roger
Old Sep 19, 2004, 01:18 AM
Team 30 Micro EDF
Joined Apr 2002
??? Why not? Get it at the drug or grocery store (the ladies use it for cleaning their finger nail polish), dip a Q-tip in it and qive the seam around the former a couple of wipes and it pops right apart. The instructions do say to joint the fuselage center section seams first. There are also several long and detailed threads on this model here (search for Micro Moth). Since the two models are similar, also search for Micro Pitts (good thread here at: http://www.rcgroups.com/forums/showthread.php?t=60849).
Old Sep 19, 2004, 01:15 PM
Rogerdoger's Avatar
Joined Apr 2002
Polish Remover
Mike,
Thanks for the tip. I will do that.
Sarah and I are currently living or "camping" at my sisters' house while a new house is being built. I am limited in space and activity here. When the new house is built, I will have my own hangar and can build away.
I did several searches and got nowhere. The link will help. I read about joining the backs together, but only did the rear portion. I will have to read better in the future! I bet my old students would like to tease me about not getting that!!
Thanks again for yor time,
Roger
Discussion Last couple of questions for my Tiger Moth Build CSI GWS (Grand Wing Servo) 15 Jul 14, 2006 02:06 AM
Couple more Tiger Moth build questions fogflyer Parkflyers 8 Sep 24, 2002 08:14 AM
Tiger Moth prebuild questions. fogflyer Parkflyers 20 Sep 23, 2002 01:59 PM
Tiger Moth Construction Questions... Newb Parkflyers 1 Jul 18, 2002 07:46 PM
Tiger Moth building questions Zak Parkflyers 2 Jun 23, 2002 04:25 PM
