Old Feb 08, 2002, 05:30 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
How to Cover Foam with Brown Paper
(NOTE: The method described below has been replaced by the method found on page 2.)
After struggling with the technique for awhile, having gosh awful problems with the paper wrinkling, I ran across an article where the author said to use a spray bottle and mist the paper prior to application. THAT's the secret.
Method:
1 - Sand foam with 80 grit and than 150 grit paper.
2- Clean foam with damp rag.
3. - Apply a 50/50 mix of PVA (White glue) and water to the foam.
4. - Mist the paper.
5 - Apply a coat of 50/50 to the matte side of paper.
6 - Lay the paper on the foam and smooth/press out the excess glue with a rag.
7 - Attach some weights to the overhanging paper to keep the edges from peeling up when it dries.
8 - Apply a final coat of 50/50 to the outside of the paper.
9 - Let dry 24 hours.
10 - Sand and paint.
hoppy
hoppy is offline Find More Posts by hoppy
Old Feb 08, 2002, 08:44 PM
Spaulding is offline
Find More Posts by Spaulding
Dangerous
Spaulding's Avatar
LA
Joined Nov 2001
sorry, what kind of paper? Sounds great!
Spaulding is offline Find More Posts by Spaulding
Old Feb 08, 2002, 09:05 PM
FANMAN is offline
Find More Posts by FANMAN
Always looking UP
FANMAN's Avatar
Lilburn, Georgia, USA
Joined Nov 2000
Paper
Its called poly coated Kraft paper, and you can get it in a roll, its the same as grocery store brown paper bags, with a coating on one side, most office supply companies have it, go to www.uline.com!
My experience has shown 60/40 mix, more glue, also when doing wings, try to do one side, then the other right away. As the water evaporates and the glue dries, serious warping can and will occur. Pratice on a scrap sheet, before you commit....
FANMAN
FANMAN is offline Find More Posts by FANMAN
buckeyes1997 is offline
Find More Posts by buckeyes1997
buckeyes1997's Avatar
columbus, oh, usa
Joined Jun 2001
kind of paper
i used to use brown grocery paper bags, but now i found you can buy it on rolls at the post office or most office stores. its in the shipping department and looks like thick brown paper bag material.
it works so well because the fibers in the bag are multidirectional and so it has great strength when you put the glue on it.
i agree spraying the water on it before attaching works great. it needs to be "wetted out" or it wont shrink up a little. that is what makes it nice and tight without wrinkles.
buckeyes1997 is offline Find More Posts by buckeyes1997
Old Feb 08, 2002, 10:07 PM
mtayl is offline
Find More Posts by mtayl
mtayl's Avatar
Boulder, CO USA
Joined Sep 2001
Graham did a great review on this located at http://216.40.226.212/~admin2/forums...threadid=18025
Pictures and everything.
mtayl is offline Find More Posts by mtayl
Old Feb 08, 2002, 11:09 PM
Squidley is offline
Find More Posts by Squidley
Idaho
Joined Jan 2002
What about?
Do you think water based polyurathane would work just as well?
Maybe the paper would have to be uncoated.....Hmmmm...
Squidley is offline Find More Posts by Squidley
Old Feb 09, 2002, 01:27 AM
James Frolik is offline
Find More Posts by James Frolik
Long-Time Member
James Frolik's Avatar
Cologne, Germany
Joined Dec 1996
Yes, water-based polyurathane will work just fine and, depending what kind you use, it will sand more easily than diluted white glue. It is also lighter.
I have coverd various foam models with either of two water-based polyurathanes, one from HSB and the other from Rödel Models, both made in Germany. It's excellent stuff, albeit both I listed are prepared specifically for the model hobby, primarily for foam application.
I also used silkspan on my models, and I didn't coat the surface first. Rather, I applied the material directly and then applied the sealer on top. It easily soaked through and the finish is just fine.
James Frolik is offline Find More Posts by James Frolik
Old Feb 09, 2002, 02:34 AM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
Re: What about?
Ken Manuel's instructions for fibreglass and PU.
http://webhome.idirect.com/~manuel/html/cover.htm
rpage53 is offline Find More Posts by rpage53
Old Feb 09, 2002, 08:51 PM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Fiberglass cloth??? Where and what kind or weight?
All I have seen would add tons of weight.
Kirby
kepople is offline Find More Posts by kepople
Old Feb 10, 2002, 01:36 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Fiberglass cloth can be found at most hobby stores.... 0.5 to 0.75 oz material. It doesn't in my opinion, make a stiff a structure as brown paper, but it gives a nice surface to work with. It is also easier to work with.
hoppy
Old Feb 12, 2002, 01:01 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Can I change my mind?
After messing with the 50/50 glue, wetting the paper, brushing it on, putting another coat on the outside, and getting glue all over me, the table and the floor, I've come to the conclusion that 3M77 is a better method. A light coat on each surface, wait 30 seconds, and than CAREFULLY, postion the paper on the foam. The things I like are:
1. It wraps around sharp corners without a problem.
2. It's permament (Doesn't peel off easily like the PVA glue job).
3. The piece is dry and ready to go.
4. Goes on very smooth.
4. Doesn't weigh any more.
5. Doesn't warp the wing.
And now, what are the dissadvantages??
No bend in this wing with soup can on end. This is Walmart sturdy board too.
hoppy
Old Feb 12, 2002, 04:57 PM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
How much dose the bag covering weigh? I tried it once and felt it was not worth the weight. Might as well just leave the cardboard on the sturdy board.
I have used tissue paper and 50 50 mix and found that very light and fairly strong after drying and being painted. The brown paper bag stuff was very hard to get wetted through out as well.
JasonJ is offline Find More Posts by JasonJ
Old Feb 12, 2002, 08:38 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I'm figuring a 1.75 times weight gain. If the wing weighs 2oz bare, the covered wing will be about 3.5oz. I tried to tear up a 3M77 paper covered wing and it is very tough. Maybe much stronger than it needs to be. Much stronger than the 50/50 PVA glued paper wing cover. It must be the tighter adhesion of the 3M77 glued paper to the foam that increases the strength so much. Is it worth the weight to cover with brown paper?? I guess it depends on the crash worthiness one wants. Maybe 20# paper or tissue is worth a try....
hoppy
Old Feb 12, 2002, 08:49 PM
Shaky Mark is offline
Find More Posts by Shaky Mark
DeForest, WI, USA
Joined Jul 2001
To get the paper all wet, one might consider a pan like is used in putting up wall paper. I believe they are about 4x4x20. Just roll it up and soak it.
Mark
Shaky Mark is offline Find More Posts by Shaky Mark
Old Feb 12, 2002, 11:59 PM
moorej is offline
Find More Posts by moorej
Big Goof
Saskatoon, Canada
Joined May 2000
77 disadvantages
77 releases with heat. So, the paper could delaminate in hot weather.
Having said that, I've never actually seen this happen. It has to be pretty hot (like froma heat gun)
moorej is offline Find More Posts by moorej
How to cover a foam plane in fabric ChuckD Parkflyers 7 Jan 06, 2005 04:54 PM
How to paint foam with Acrylics??? Waldo Pepper Foamies (Kits) 14 Nov 27, 2004 09:36 AM
Please Help: How to cover wing with tape? Allan_A Foamies (Kits) 2 May 06, 2004 03:54 PM
Covering Twinstar with Brown Paper Method Steven DiStasio Foamies (Kits) 2 Jan 08, 2002 07:11 AM
