Go Back   RC Groups > Aircraft - Electric - Airplanes > Electric Plane Talk
Old Feb 08, 2002, 09:11 AM   #1
LJH
Moths do not fly inverted
LJH's Avatar
SP400 Rocket 4:1 what prop?
I have dreams of seeing my DMA Butterfly go vertical. and I was thinking that maybe I could use the Rocket 400 and my 4:1 gear box that it may work. The gearbox will add about 1oz so all up weight will be around 15 oz. I was wondering if anyone has experience with the SP400 Rocket @ 4:1 could give me an idea of where to start with the prop, or even better if someone could run it through Motocalc to see what kind of thrust they predict.
Cheers,
Jim
LJH is offline Find More Posts by LJH   Reply With Quote
Old Feb 08, 2002, 09:22 AM   #2
Motors beat engines!
I used the rocket geared 4.09:1 with a gws 10x8 on 8 600ae's on my 17-7/8ths oz Frenzy and found it would hover and torque roll for the first 2 minutes.
Top speed was only around 40 or so, but that is prob just about right for the Butterfly.
Amps by the way are quite reasonable, and neither motor or batts get overly warm.
Please give us a flight report when you test it out.
DeaninMilwaukee
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee   Reply With Quote
Old Feb 08, 2002, 06:35 PM   #3
Bill Glover's Avatar
Don't know what a Rocket 400 is, but on stock 6V S400 with 4:1 gearing and 8 cells I use APC-E 11x8.5.
Bill Glover is offline Find More Posts by Bill Glover   Reply With Quote
Old Feb 08, 2002, 08:34 PM   #4
poobs's Avatar
LJH
http://custompaintjob.com/ezcalc/dma.asp
poobs is offline Find More Posts by poobs   Reply With Quote
Old Feb 09, 2002, 11:42 AM   #5
LJH
LJH's Avatar
Thanks guys,
Wow, it actually looks like this will work . Poobs, Thanks for the link, I have never played with P-calc or Motocalc before. That is pretty easy . One of these days we have to get together and do a little flying.
Cheers,
Jim
Old Mar 04, 2002, 08:37 PM   #6
LJH
LJH's Avatar
Just finished up the the re-build of my Butterfly and this looks like it is going to work. The static thrust test shows that is will go vertical Useing a 8X600AE and a APC 10X7 Slow Fly prop. I ran it on my Wattmeter an it shows 10.8 amps and around 90 watts. If the weather is ok out tomorrow morning I will give it a test flight and let you guys know how it went.
Cheers,
Jim
Old Mar 04, 2002, 10:08 PM   #7
RPatrick's Avatar
Good Luck, can't wait to hear your results!
I am planning a Rocket 400 project and am very interested!
RPatrick
RPatrick is offline Find More Posts by RPatrick   Reply With Quote
Old Mar 05, 2002, 07:57 AM   #8
poobs's Avatar
LJH
That sounds good
Slow Stick 400 & 1500 7.4 lipo what prop? CarreraGTSCS Parkflyers 0 Nov 22, 2004 12:31 PM
Hacker B40 10L 4.4:1 - what 3D plane? rlanzi 3D Flying 5 May 04, 2004 02:39 PM
B20 15L 4:1 + what Lipo? sgil2001 Power Systems 4 Jan 04, 2004 01:55 AM
What can you Fly with a SP400 & 4:1 GB? wim5150 Power Systems 10 Nov 07, 2002 03:01 PM
sp400 sized plans/sites/what prop? etc etc MrBungle Racing Boats - Electric 19 Oct 18, 2002 06:28 PM
Bored? Want to fight?
Join the RCGroups clan!
