Old Sep 14, 2004, 09:20 PM
rccraigb is offline
Find More Posts by rccraigb
United States, CA, Baywood-Los Osos
Joined Aug 2003
Mac OS X Motor Performance Utility
I've just made available a small OS X utility that calculates the thrust and power consumed by a two-bladed propeller driven by an electric power system. It's available at:
http://www.ceebeeaero.com/index.html
This is the text from the "Read Me" file that is included with the application:
AMP (Aircraft Motor Performance) estimates the thrust produced and power consumed by a propeller for an electric aircraft.
I wrote AMP so that I did not have to purchase PC emulation software, or bother someone in my club with a PC to run some numbers for me. I am making this early version available publicly so that it might be used for "rough" estimates - proven software must be used for any final calculations.
I spent most of the development time on the Propeller model, which is based on N.A.C.A. Technical Note Number 698. Right now, it only supports two bladed propellers up to 25 degrees in pitch measured at .75r. If there is sufficient interest, I will add data for three-bladed propellers and ones of higher pitch or different aspect ratio.
The Battery model is loosely based on Sanyo specifications for NiMh chemistry. It still needs some work, but should do well for most common conditions.
The models for the Gearbox and Speed Controller are overly simplistic. Again, though, they should work for initial estimates.
Of course, after experimenting with this application, users are encouraged to confirm assumptions and results using proven software (by either purchasing PC emulation software or bugging friends to run the numbers).
Feedback would be appreciated. I would also be very interested in empirical data to compare with the predicted results.
Craig
rccraigb is offline Find More Posts by rccraigb
Old Sep 14, 2004, 09:50 PM
Eljimb0 is offline
Find More Posts by Eljimb0
ni'ihau
Joined Nov 2003
Thanks, from a Mac user.
jimbo
"If you haven't had a Mac you have never really had a computer"
Eljimb0 is offline Find More Posts by Eljimb0
Reply With Quote  (Disabled)
Old Sep 15, 2004, 07:35 AM
twest is offline
Find More Posts by twest
100% electric since 1990
twest's Avatar
United States, MA, Ware
Joined Jul 2001
Thanks.
twest is offline Find More Posts by twest
Old Sep 16, 2004, 12:42 AM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Cool!! I'll grab it and give it a try!
Thanks.
BEC is offline Find More Posts by BEC
Old Sep 16, 2004, 01:02 AM
Goekeli is offline
Find More Posts by Goekeli
Member
Goekeli's Avatar
North Hollywood, CA 91606
Joined Jul 2003
Thanks for this!!! I love my mac too!
Joe
Goekeli is offline Find More Posts by Goekeli
Old Sep 16, 2004, 07:39 AM
Hogster is offline
Find More Posts by Hogster
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Looks interesting ... I'll download it anyway, just to show my support for Mac programmers - Macs rule!
Good work!
Hogster is offline Find More Posts by Hogster
Old Sep 16, 2004, 07:54 AM
Ron Williams is offline
Find More Posts by Ron Williams
slow but inefficient
Ron Williams's Avatar
Riverhead NY USA
Joined Dec 2000
Hi Craig -
I tried downloading the program but just got an Explorer window full of code. I'm on the latest OSX. ???
ronw
Ron Williams is offline Find More Posts by Ron Williams
Old Sep 16, 2004, 09:57 AM
Park_Pilot is offline
Find More Posts by Park_Pilot
How am I not myself?
Park_Pilot's Avatar
Montréal, Canada
Joined Jan 2004
Thanks a lot!
Samuel
Park_Pilot is offline Find More Posts by Park_Pilot
Old Sep 16, 2004, 10:02 AM
rccraigb is offline
Joined Aug 2003
Ron,
That's odd. I had done my testing with Safari; when I tried Explorer, I saw a window full of code, too.
The workaround in Explorer: 'control-click' on the link and select 'Download Link To Disk'. That works.
Thanks for the interest!
Craig
Old Sep 16, 2004, 11:08 AM
KillerAir is offline
Find More Posts by KillerAir
Plane dodger
KillerAir's Avatar
Stratford Sikorsky, Connecticut, United States
Joined Dec 2001
Does it work for OS9? Not on 10 for NT stability reasons, can't afford to have any downtime:O from doing client work.
Killer
KillerAir is offline Find More Posts by KillerAir
Old Sep 16, 2004, 11:26 AM
rccraigb is offline
Joined Aug 2003
Unfortunately it can't run under OS 9 - it is a 'Cocoa' application from the ground up.
Old Sep 16, 2004, 05:50 PM
Riverhead NY USA
Joined Dec 2000
Hi Craig -
Thanks. That worked fine. Looks good.
Killer -
I switch back and forth between the latest OSX and 9 all the time. Very stable so far. The new OSX is light years ahead of the last one (a mess). Maybe you need one of the new G5 imacs?
I enjoy seeing your art/graphics when they show up. Nice stuff.
ronw
Old Sep 16, 2004, 11:18 PM
macr0t0r is offline
Find More Posts by macr0t0r
Got more toys than my kid
macr0t0r's Avatar
USA, CA, Fremont
Joined Sep 2004
Not a bad program. May I make a request? Aallow me to specify volts per cell. Having to convert LiPo cells' voltage and internal resistance into NiMh values is a little tiring.
Are you sure you should auto-calc .75r angle? This will vary from prop to prop, so you may want to let the user override the default value (perhaps a checkbox stating "auto-calculate generic value").
Nonetheless, this is excellent work with a clean interface. It'll help me narrow the field as I try to engineer the next powerplant for my project. I REALLY like the ability to calculate estimated values at a given airspeed. Thanks!
macr0t0r is offline Find More Posts by macr0t0r
Old Sep 17, 2004, 03:46 AM
jojonz is offline
Find More Posts by jojonz
jojonz's Avatar
Auckland New Zealand
Joined Feb 2004
Thanks for thinking of us Mac users, Craig.
It looks and works great.
jojonz is offline Find More Posts by jojonz
Old Sep 17, 2004, 11:50 AM
mdiehl is offline
Find More Posts by mdiehl
Joined Jun 2004
Amp
Just downloaded using Safari and 10.3.5, no problems seems to run fine. Thanks!
Cheers
Mike D.
mdiehl is offline Find More Posts by mdiehl
Mac OS X and PHX-Link software vote LRHann Castle Creations 19 Mar 06, 2012 02:36 PM
Mac OS X ZLog Interface Available rccraigb Aerial Photography 26 Sep 25, 2007 12:26 AM
Zagi 400-X climb performance AirVenture Foamies (Kits) 6 Aug 04, 2001 01:09 AM
Can't Get Zagi 400-X Motor to Start mpj220 Foamies (Kits) 8 Jul 31, 2001 11:26 PM
LS motor performance probs tderse Parkflyers 8 Apr 21, 2001 04:40 AM
