Old Sep 14, 2004, 12:11 PM
Guest
n/a Posts
Small, low cost, low power GPS receiver for model airplane
Can anyone recomment a small size, low cost, low power GPS receiver with
velocity, position and height serial data output ? (It will be used in a
model airplane for data logging)
Old Sep 14, 2004, 08:11 PM
DaveG
DaveG
Guest
n/a Posts
Re: Small, low cost, low power GPS receiver for model airplane
What's that saying in manufacturing ? ...
something like "cost, quality, quantity ... you can have any two of the
three"
Dave
MikeWhy
MikeWhy
Guest
n/a Posts
"DaveG" <dave.green@despam.xparadise.net.nz> wrote in message
news:4147892B.5010405@despam.xparadise.net.nz...
a
> three"
In engineering, that's good, fast, or cheap; pick two. There's a little more
wiggle room with market positioning and volume for manufacturing.
Anything from the Garmin eTrex line would work well. They store
"breadcrumbs" and also spit a serial NMEA PVT stream. The Summit model has
built in altimeter and electronic compass; I expect these can be sent on the
serial, as well. The eTrex are great on the motorcycle, too. They're small,
well weatherproofed, and extremely rugged. Mine survived a 4 foot fall to
the pavement at 60 mph three years ago, and it's still in use.
I would try it first without the datalogger, and see if the breadcrumbs have
enough resolution for your needs.
Old Sep 17, 2004, 02:11 AM
Kevin Gomez
Kevin Gomez
Guest
n/a Posts
Have you looked here : http://www.laipac.com/
e.g. GPS engine like TF30
small - 30x40x7mm
low cost - $75 + $20 for active antenna
low power - 3.3V, 50mA
code to interface to a PIC microcontroller provided.
"MikeWhy" <mikewhy@my-deja.com> wrote in message
news:9_L1d.19976$4S3.6299@newssvr24.news.prodigy.c om...
>> > with
> a
>> three"
> more
> the
> small,
> have
Old Nov 16, 2004, 04:11 PM
Justin Fielding
Justin Fielding
Guest
n/a Posts
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Any luck finding one?
Justin.
DaveG wrote:
|> with velocity, position and height serial data output ? (It will be
|> used in a model airplane for data logging)
| three"
| Dave
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.5 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFBmlUw93SxCpNRmGQRAsCSAKCJMCappcYNasrl9uHHVp cSOpy+MgCeKIh0
Qust6WDB7Hnh7DPVsByqkJU=
=Et4p
-----END PGP SIGNATURE-----
Old Nov 18, 2004, 12:11 AM
Wayne
Wayne
Guest
n/a Posts
This site has many links to GPS and UAV site.
Good luck
http://www.elkhart.net/~miked/Ulinks.htm
"Justin Fielding" <justinfielding@yahoo.dot.co.dot.uk> wrote in message
news:1100633404.2bJ4IZLQkOctnfXmUbiMVA@teranews...
> Hash: SHA1
> Justin.
> | three"
> | Dave
> =Et4p
Old Nov 18, 2004, 10:11 AM
Fritz Bien
Fritz Bien
Guest
n/a Posts
On Tue, 16 Nov 2004 21:30:01 +0200, Justin Fielding
>Hash: SHA1
>Justin.
>| three"
>| Dave
>iD8DBQFBmlUw93SxCpNRmGQRAsCSAKCJMCappcYNasrl9uHHV pcSOpy+MgCeKIh0
>=Et4p
I've been flying a Garmin Foretrex 201 in (on) both my Aegea Mantis
and my Ultrasport for the last 4 months. It updates as fast as in 1
second intervals. It can be purchased at Amazon.com for less than
$140, has a serial port read-out, and together with software available
on the net, you can do all what you're asking. Jan Kansky wrote up a
nice tutorial at:
http://www.jeklink.net/projects/GPS_...Sailplane.html
I've logged speeds in excess of 100 mph,using the GPLIGC program, but
you have to be aware that this is ground-speed, that the GPS measures,
so when you get to the edge of your vision, and split-S back, the
speed momentarily drops to zero.
-Fritz
Any ideas for low cost foam cutting power source? slowflyer Foamies (Kits) 24 Apr 10, 2009 12:45 PM
low power warning buzzer for a TX ? volt flyer Power Systems 0 Apr 29, 2001 04:03 PM
