Old Sep 13, 2004, 04:11 PM
Zenin
Zenin
Guest
n/a Posts
Screw Removal: 4-40 screws are too small for any easy-out! :-(
I had the head of a small 4-40 screw shear clean off with the body inside an
aluminum part. None of the easy-out screw removers I have are even close to
small enough to take this out and I don't see any at the hardware or model
stores around my area that are any smaller. The hole is not reachable from
the other side. And to help things out even more the screw was put in with
thread lock.
Does anyone make super-tiny screw extractors? Is there some other method
of taking out small broken screws?
Thanks!
Dean
Dean
Guest
n/a Posts
Re: Screw Removal: 4-40 screws are too small for any easy-out! :-(
>thread lock.
>Thanks!
Pretty much your only hope is to cut a slot in it with a dremel cutoff wheel
(the thinnest you can find). You will end up slotting the part a little too.
But otherwise you are gonna have to scrap it, not much you can do.
Proud owner of:
Associated RC10GT <the other basher>
Team Losi XX "CR" <the basher>
Team Losi XXX KE <the racer>
http://ripperd.com
email: dean (at) the above domain
Old Sep 13, 2004, 06:11 PM
Johnboy
Johnboy
Guest
n/a Posts
A way that works for me is to use a left handed drill bit from
McMaster.
Set the drill motor to reverse and carefully get the drill bit started
in the center of the 4 - 40, then apply pressure as normal. The heat
and
the constant torque usually gets it out.
"Zenin" <zenin@rhps.org> wrote in message
news:10kbuikfshj0uc1@news.supernews.com...
inside an
close to
model
reachable from
in with
> thread lock.
method
> Thanks!
Old Sep 13, 2004, 08:11 PM
Divrdan007
Divrdan007
Guest
n/a Posts
>Subject: Screw Removal: 4-40 screws are too small for any easy-out! :-(
>From: Zenin zenin@rhps.org
I have taken my dremel cutting wheel, and cut a slot in there, then used a
jeweler's screwdriver to remove the screw.
You will damage the surface of the part, but since it's aluminum, it shouldn't
matter.
The other alternative is to drill it out, and tap new threads.
Good Luck
Old Sep 14, 2004, 04:12 AM
Zenin
Zenin
Guest
n/a Posts
Johnboy <jondne@knology.net> wrote:
> A way that works for me is to use a left handed drill bit from McMaster.
> Set the drill motor to reverse and carefully get the drill bit started in
> the center of the 4 - 40, then apply pressure as normal. The heat and the
I'll give this a shot I think; I hadn't know of left handed drill bits.
Thanks!
The other ideas posted about cutting a slot in it might have worked
except since the treads start almost a 1/4" down the hole that's where
it broke off... I'd have to cut really deap into the part to get to it.
Duh. :-(
-Zenin
Old Sep 14, 2004, 12:11 PM
George Williams
George Williams
Guest
n/a Posts
> Thanks!
> Duh. :-(
Soak it in acetone or methyl ethyl ketone (MEK) to loosen it up first.
Don't try drilling out (right-hand bit, forward) if the screw metal is
steel, as the bit will deflect into the aluminium and break off. I hope
the left-hand bit (or screw extractor bit) works, although I haven't the
foggiest where one would acquire a left-hand bit.
Old Sep 14, 2004, 02:11 PM
Johnboy
Johnboy
Guest
n/a Posts
Since the broken screw is down in a hole, you can get a
piece of brass tubing from a hobby shop to use as a drill guide.
Cut a piece that fits into the hole and leave about .25 - .50
sticking out. Once you have a pilot hole started, you can remove
the brass and change to a slightly bigger bit to hopefully remove
the broken screw. This brass piece will guide the bit towards the
center of the screw.
news:10kd8k2blgl561b@news.supernews.com...
McMaster.
started in
and the
drill bits.
> Thanks!
worked
where
to it.
> Duh. :-(
> -Zenin
Old Sep 14, 2004, 05:13 PM
davemartin88 is offline
Find More Posts by davemartin88
Leesburg, VA
Joined Aug 2004
Found these, not cheap though.
http://www.aldn.com/mdrillout/
davemartin88 is offline Find More Posts by davemartin88
Old Sep 14, 2004, 10:11 PM
Robert Gross
Robert Gross
Guest
n/a Posts
I also found these, again not cheap.
http://www.sears.com/sr/javasr/produ...id=00952158000
Robert
"davemartin88" <davemartin88.1clisf@rcgroups.com> wrote in message
news:davemartin88.1clisf@rcgroups.com...
> davemartin88
> davemartin88's Profile:
http://www.rcgroups.com/forums/membe...o&userid=37683
> View this thread:
http://www.rcgroups.com/forums/showt...hreadid=275097
Old Sep 15, 2004, 12:11 AM
walker
walker
Guest
n/a Posts
"George Williams" <nyar1ath0tep@mac.com> wrote in message
news:41471E0B.E97259E9@mac.com...
McMaster.
in
the
bits.
> > Thanks!
where
it.
> > Duh. :-(
The poster mentioned McMaster's which is a huge tool and hardware
catalog. I had been unaware of it previously but I certainly won't forget
it. Amazing! They not only have left handed drill bits but several types and
SAE and metric.
George Williams
George Williams
Guest
n/a Posts
> SAE and metric.
Yes, I finally spotted that. Quite a good resource.
Question Are micro-deans too small for CC-10 & TP-1320 jatt5abdaa Power Systems 13 Mar 01, 2006 10:14 AM
AARRGGHH!! Minifan screws are too small for ..... Willmsy Electric Ducted Fan Jet Talk 5 Jan 08, 2005 11:18 AM
Whoops! 28 in 3DX too small for geared Astro??? poobs 3D Flying 7 Nov 28, 2003 08:35 PM
Dubro E/Z link too small for HS-55 Peter Mar Parkflyers 5 Dec 17, 2001 08:42 PM
HS60's too small for Push-E-Cat? Willm Beginner Training Area (Aircraft-Electric) 3 Apr 28, 2001 08:24 PM
