Old Oct 16, 2004, 08:20 AM
Ron H is online now
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Sounds like the epoxy set before you got the clamps on. Try adding a thin layer in the gap and hold it by hand. A few books or a pillow can be used to hold on side up. Let the other side rest on a table. Three degrees right when viewed from the rear.
Do you have a shim in the gap? If not, you may wind up with a lot of dihedreal. Put the front rods in the joiner and hold them in front of the wing. This is the correct amount of dihedral.
Ron H is online now Find More Posts by Ron H
Old Oct 16, 2004, 10:05 AM
AMF is offline
AMF
Find More Posts by AMF
AMF
AMF's Avatar
Chandler Williams, Arizona, United States
Well Ron, like everything I've done up to this point, this step was also wrong. Early this morning I mixed up another batch of epoxy and put the wing back together. I first used alcohol and made sure everything was clean. This time it appears to have held together. But like I said, everything I do is wrong. I put the front rods in the joiner and held them in front of the wing and sure enough, my wing tips are higher than where the rods lay. So now I have alot of dihedreal. So what's that going to screw up?
I also have to fabricate another thrust mod insert because I built mine just the opposite of course. This is no big deal since I actually like making it.
I have messed up every step of the way (Murphy's law I guess). I've screwed up so bad that this is actually my second kit. Between the two kits I might actually create one plane that flies. My $35 plane cost me $70!
Well back out to the shop and see what else I can mess up.
Thanks for you help!
Tony
AMF is offline Find More Posts by AMF
Old Oct 16, 2004, 10:58 AM
Vanning is offline
Find More Posts by Vanning
WAA pilot #21
Vanning's Avatar
Princeton NJ
Joined Dec 2003
As for the dihedral, dont sweat that. With the rods taped on and the wing rubberbanded to the plane it'd have to be wayyy out of whack to make a noticeable difference in the finished product. Besides, extra dihedral will make it more stable. Its less dihedral will make it tougher to fly.
The glue in the center joint - from an engineering perspective - is only to solidify the center rib. There is no force trying to open up the joint, the wings lift is pinching it shut. However, the wings strength is partly because of its curved shape. Ex: A flat piece of paper has no strength in bending, but curve the paper or roll it into a tube and its quite stiff. When you stress the wing to the point of failure, the squishy foam center rib stretches and allows the airfoil to flatten - like the sheet of paper.
BTW, the tape across the top? its useless to prevent wing folding. Tape works well in tension, but is useless in compression. It DOES help quite a bit in shear though, for those off-center mailbox strikes.
And the wood plug- couldnt you reverse it (front to back) to get it correct?
Vanning is offline Find More Posts by Vanning
Old Oct 16, 2004, 01:54 PM
AMF is offline
AMF
AMF
AMF's Avatar
Thanks Vanning for your comments. I believe I undestand a lot more now. The difference between the rods and the wing is not much and after I tape rods to the wing it will have a little force pulling it back down so in the long run it's probably pretty close.
As far as flipping the thrust mod plug goes, you can't really do that because one end is about 5/16 OD (the one entering the fuselage) and the other is about 3/8 OD that the motor mounts over. So if I flip it, it will be sloppy on the motor side. It only took me about 1/2 hour to make and probaly only about 15 minutes the second time.
I just finished soldering all the Deans connectors to the ESC and motor. At least this went very well. Next I'll be attaching the rods to the wing and finally mounting all the electronics as well as the battery tray I made.
After this, the manual says:
"After the balance point is determined, you are then able to connect the push pull rod to the servo.".
What do they mean by the "balance point"? And what do you balance against and for what purpose? This manual is very, very vague for us first time builders.
Tony
Old Oct 16, 2004, 01:59 PM
AMF is offline
AMF
AMF
AMF's Avatar
Vanning, you're right. I can just turn the plug 180 degrees and now I have down/right thrust. I was thinking I had to flip it around. See how nieve I am?
Tony
Old Oct 16, 2004, 04:05 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
Tony
Tony,
Did we clear up the down and right??? It's looking toward the front of the plane from the rear.
boomer
www.boomerseflight.com
boomerace is offline Find More Posts by boomerace
Old Oct 16, 2004, 05:06 PM
AMF is offline
AMF
AMF
AMF's Avatar
Yes Boomer I did clear up the right/down. Since I hadn't drilled any holes all I had to do was rotate the plug so the down/right was looking from the rear.
I have everything on the fuselage assembled (motor/prop, speed controller, receiver, servos, upgraded LG and wheels and the battery mount loosely fitted) as well as the control horns in the rudder and elevator. The directions are now telling me that I am ready to attach the push pull rod to the servo, but ONLY after the balance point is determined. But I don't know what they mean by the "balance point". I don't know what it is, where it is, or what it has to do with anything. Any idea what they are talking about?
Tony
Old Oct 16, 2004, 05:48 PM
Ron H is online now
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
They mean the center of gravity. Make a mark 4-1/8" from the front of the wing. Mark it on the bottom of the wing so it is clearly visible. It gets checked often. Then put the wing on and try to balance the plane on this mark. Doing it without the battery on will make things easier, and you can use any pack you want then.
Old Oct 16, 2004, 06:25 PM
AMF is offline
AMF
AMF
AMF's Avatar
Thanks Ron,
I don't know why they give me this instruction which is like two pages before they even talk about mounting the wing or talk about the the 4 1/8" measurement. I have the 400 which they say is about 3 3/4 inches for the starting point of the CG.
So basically I should just install all the electronics in the most convenient way I can. Then mount the wing and adjust everything so that I can balance on the CG I marked on the wing. Makes sense and is much easier than this manual.
Thanks again as usual,
Tony
Old Oct 16, 2004, 06:44 PM
Ron H is online now
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Even with the 400 I keep mine at 4-1/8. It is easy to shift the pack up or back when needed. The added nose weight is supposed to counter the up thrust, which you have already done.
Old Oct 16, 2004, 07:17 PM
Ron H is online now
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Here is a photo with a 400 that may help. The wing is 5-3/4 from the tip of the fuse. Two marks can just be seen on the wing One is 4-1/8" one 3-3/4". The yellow thing is the ESC, the switch is right in front of the wing. Rx is tucked between the servos, and held in with a zip tie. The battery holder had a piece of velcro covered foam glued on. This was later changed to a sawed off yardsick. Plenty of room to move the pack around.
Old Oct 16, 2004, 07:22 PM
AMF is offline
AMF
AMF
AMF's Avatar
Thanks for the tip and pic Ron a big help. Now I'll return to the shop and finish her up. I think I've got things under control now thanks to everyone here.
Thanks again,
Tony
Old Oct 16, 2004, 08:23 PM
boomerace's Avatar
Joined Sep 2001
4-1/8" no matter what motor you are using.
boomer
Old Oct 17, 2004, 12:45 AM
AMF is offline
AMF
AMF
AMF's Avatar
Right as usual Boomer. I completed the entire assembly, stuck the battery to the battery tray, marked 4 1/8" under the wing on both sides and attached the wing. Then I held the two CG dots and the plane balanced perfectly. I didn't even have to adjust anything!
The only thing I didn't due was cut the servo rods simply because I would hate to make a mistake at this point (no hobby stores open on Sunday). But tomorrow a guy is going to setup a buddy box and teach me how to fly the thing and he'll know how to cut and bend these rods so I'll do it at that time.
Before I head out tomorrow I'll take the before picture because I'm not sure what the after will look like. The only modification I didn't do was the tail LG enforcement as recommended by Boomer. I can see this is something that I must do. But I believe everything else I have done. Still though, the epoxy in the center of the wing failed again so I taped it. Not sure why the epoxy won't hold here as it was still very wet when I attached the two sides.
Thanks for everything guys and I'll let you know what happens.
Later,
Tony
Old Oct 17, 2004, 02:21 AM
rockbus is offline
Find More Posts by rockbus
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Good Luck tomorrow. I soloed Friday night. I did have one training flight with Mike at Sureflight a week ago which helped tremedously. He got it trimmed for level flight and suggested I reduce the control surface throw by using the inner servo arm hole. Also to move the ESC further away from the Rx since the plane had a few hits - spaz attacks.
But last Friday I went to this field near the beach with no one around and flew the thing like I knew what I was doing. Burned one pack just doing figure 8's with a smooth full stall landing. The next pack I burned just taking off, going around the pattern and landing - maybe 10 times, had a couple of nose overs in the weeds but walked away from all of them ...
Based on my luck so far you should do fine. I noticed I could limit my over controlling by blipping the rudder or elevator vice trying to move the stick around at first. After a while I got better with the stick but I'm just a beginner.
Ray
rockbus is offline Find More Posts by rockbus
The Ultimate Slow Stick Help Thread Part 7 boomerace Beginner Training Area (Aircraft-Electric) 517 Apr 27, 2005 12:04 PM
The Ultimate Slow Stick Help Thread - Part 5 boomerace Beginner Training Area (Aircraft-Electric) 793 Sep 13, 2004 08:01 AM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 3 Martin Hunter Beginner Training Area (Aircraft-Electric) 639 Apr 11, 2004 11:17 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
