Old Sep 17, 2004, 04:55 PM
Rugar is offline
Find More Posts by Rugar
"Fly It Like Ya Stole It"
Rugar's Avatar
San Bernardino, Ca
Joined Jul 2004
Originally Posted by Norm35
Ruger,
I'd like to take your advise but it is impossilble to trim the rudder.
It is like trying to balance something on the cutting edge of a very sharp knife.
It may be the joystick I am using.
I can trim other models with it but not this one.
Thanks for the reply,
Norm
Im not sure what your problem is then. I use my regular TX hooked to my PC to fly FMS with. Seems to work fine. Maybe someone else that has the same problem will reply.
Gerald
Rugar is offline Find More Posts by Rugar
Old Sep 17, 2004, 05:10 PM
Ron H is online now
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Have you tried aileron trim? It may be swapped with the rudder.
Ron H is online now Find More Posts by Ron H
Old Sep 17, 2004, 06:58 PM
Norm35 is offline
Find More Posts by Norm35
Joined Sep 2004
I have ailerons on the same channel as the rudder.
Norm35 is offline Find More Posts by Norm35
Old Sep 18, 2004, 10:20 AM
Lj009 is offline
Find More Posts by Lj009
Greenville, South Carolina, United States
Joined Jun 2004
Wheels and motor
Morning everyone,Just need a tad of help, Just about finished the mods on my SS and I'm not happy with my CG.One upgrade I would like to do is the foam wheels and I think it would move my CG to where I satisfied. I've tried a search but I think I'm computed-out (spent the weekend searching the web for carbon fiber fus. replacement for my Slow V) Is there one site that I could get both the Wheels and a slightly upgraded motor (370 w/ d gearing) for a backup.
Thanks again
Jack
Lj009 is offline Find More Posts by Lj009
Old Sep 18, 2004, 11:35 AM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
Thanks again
Jack
Try www.allerc.com
boomer
www.boomerseflight.com
boomerace is offline Find More Posts by boomerace
Old Sep 19, 2004, 09:33 AM
Lj009 is offline
Joined Jun 2004
Hey Boomer,
Thanks for the info,David suggested the EPS-350c-d/bb and for the wheels LFW 508's but the wheels don't look like the one's you have (long spokes) am I wrong or is there a dif # for the ones like yours?
Jack
Old Sep 19, 2004, 11:13 AM
boomerace's Avatar
Joined Sep 2001
Hey Boomer,
Jack
Jack you can't go by my wheels as I usually bend a new heavier landing gear and wrap and CA it to the fuse so I can use any wheels I want as they don't have to fit the GWS landing gear furnished.
boomer
Old Sep 19, 2004, 07:44 PM
Valid8r is offline
Find More Posts by Valid8r
Valid8r
Valid8r's Avatar
Boston and Belgium
Joined Jul 2004
Jack - you may want to look at www.aircraft-world.com for the wheels. I believe that www.gwsexpert.com also has them.
Jon
Valid8r is offline Find More Posts by Valid8r
Old Sep 19, 2004, 09:42 PM
Ron H is online now
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
For anyone interested, I've just tested a Graupner 400 6v on 8 cells.H gear,1470 prop. 17oz thrust @ 9 amps. Retiming got me 20oz @13 amps, but I was overheating the motor. Backed off some to get 19oz thrust @10.5a with a cooler motor.
Old Sep 21, 2004, 11:02 AM
wing1 is offline
Find More Posts by wing1
What, Me Fly?
wing1's Avatar
Lakeland, Fl
Joined Feb 2004
These threads are so big that instead of reading through them, I thought I might risk asking if a 730 3cell thunder power pack will work on my slow stick. My 730 nimh packs are dead. Thought I would upgrade. If not, what will give good flight times vs good power?
wing1 is offline Find More Posts by wing1
Old Sep 21, 2004, 05:00 PM
Wertygrog is offline
Find More Posts by Wertygrog
Registered Disabuser
Wertygrog's Avatar
Norfolk, Massachussetts
Joined Jul 2003
I don't have any lipoes but i know from reading that you will most likely burn out the stock power system with that battery. A 2s battery should make the stock power system last longer, and provide good flightime. In about 10 min a lipo pro will answer your question, im sure.
Wertygrog is offline Find More Posts by Wertygrog
Old Sep 21, 2004, 05:17 PM
rmasonjr is offline
Find More Posts by rmasonjr
<burp>
rmasonjr's Avatar
Brookhaven, Mississippi, United States
Joined Mar 2002
agreed - you will burn the motor with a 3-cell...
rmasonjr is offline Find More Posts by rmasonjr
Old Sep 21, 2004, 06:08 PM
wing1 is offline
What, Me Fly?
wing1's Avatar
Lakeland, Fl
Joined Feb 2004
How about a two cell 860?
Old Sep 21, 2004, 06:15 PM
boomerace's Avatar
Joined Sep 2001
Good choice! TP 1320 would be good also.
boomer
Old Sep 22, 2004, 12:34 PM
millerhill is offline
Find More Posts by millerhill
millerhill's Avatar
USA, VT, Brandon
Joined Aug 2004
What's the difference between a re-timed 280 and a stock 350? Can I expect higher thrust assuming the same prop? I've been using 1180's and the 280 runs pretty hot.
millerhill is offline Find More Posts by millerhill
The Ultimate Slow Stick Help Thread Part 7 boomerace Beginner Training Area (Aircraft-Electric) 517 Apr 27, 2005 12:04 PM
The Ultimate Slow Stick Help Thread - Part 5 boomerace Beginner Training Area (Aircraft-Electric) 793 Sep 13, 2004 08:01 AM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 3 Martin Hunter Beginner Training Area (Aircraft-Electric) 639 Apr 11, 2004 11:17 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
