Old Apr 23, 2006, 02:27 AM
PLD is offline
PLD
Find More Posts by PLD
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Jim,
Very nice... very very nice. I think I should put that up on my "working with balsa" page as a prime example of just how effective doculam can be (okay, I won't really, but it would be an excellent example).
Paul.
PLD is offline Find More Posts by PLD
Old Apr 23, 2006, 08:21 AM
sgtdirt is offline
Find More Posts by sgtdirt
Mentor, OH
Joined Dec 2004
thought i'd post a couple of pics of the Elipstik 460. i painted the inside of the doculam so when it belly lands, none of the paint will come off. the stripes were done using wet news paper and the shield on the bottom was paper templates.
if your going to paint the "glue" surface, make sure you keep the the paint to a minimum. the glue has a hard time getting throught the paint.
sgtdirt is offline Find More Posts by sgtdirt
Reply With Quote  (Disabled)
Old Apr 23, 2006, 08:49 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
My latest doculam covered plane is the Seether -
The black/blue parts are sign-makers vinyl scraps that I raided from their bins while they cut out the 'Seether' lettering.
The wings/stab are covered in doculam, it definately makes for a much better flight performance compared to raw wood.
Old Apr 23, 2006, 08:54 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
I should point out that one really great thing about doculam/laminating-film is that you can exploit its high temperature resistance to make way for a new method of bonding carbonfiber tow to the wings.
What I did was lay down a 1/2" wide strip of hotglue (smeared on while hot, spread with a ccard, masked off with masking tape), I put the CF tow down on the strip, apply the doculam over the top and turn the heat and pressure up. The result is a nicely wicked hotglue+CF mix and it's very flat (I do have photos available of the process).
Paul.
Old May 07, 2006, 10:56 AM
Boogie3D is offline
Find More Posts by Boogie3D
United States, FL, Daytona Beach
Joined Sep 2005
Has anyone actually weighed it?? How can You compare it to normal oracover/ solarfilm??
Boogie3D is offline Find More Posts by Boogie3D
Old May 07, 2006, 12:47 PM
sgtdirt is offline
Mentor, OH
Joined Dec 2004
it's not just the weight. you can paint it easily.
Old May 07, 2006, 01:54 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Clear it is a bit over solite. Painted it's probably close to solarfilm, depending on how much paint you use
charlie
portablevcb is offline Find More Posts by portablevcb
Old May 07, 2006, 06:59 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
btw, I updated my Doculam/laminating video - it's now in flash video format, so you don't need a codec.
http://www.pldaniels.com/flying/bals...culam-covering
(This is all part of the main flying page at http://pldaniels.com/flying )
Old May 07, 2006, 11:21 PM
Gerry Markgraf is offline
Find More Posts by Gerry Markgraf
Gerry Markgraf's Avatar
S. Calif
Joined Mar 2000
Heres a Tiny-X that I covered with Doculam on the tail and ailerons. I dry brushed the inside (adhesive) surface of the Doculam in a crosshatched pattern using red and white acrylics. Then I covered the model with the painted Doculam. I was happy with the results and the paint will never come off as its on the inside.
Gerry
Gerry Markgraf is offline Find More Posts by Gerry Markgraf
Old May 07, 2006, 11:35 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Gerry, that looks stunningly good.
What did you use to make the doculam red?
Paul.
Old May 08, 2006, 01:39 AM
S. Calif
Joined Mar 2000
Paul
I only covered the tail and ailerons with the dry brushed Doculam to get the crosshatched pattern. The wing is covered with one of the lightweight mylar films that came as transparent red (I forget which brand). I thought the pattern on the painted Doculam was a good contrast to the red wing covering.
Gerry
Old May 08, 2006, 02:02 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Gerry,
Darn, I was sincerely hoping you had found a great way to make fantastic looking dyed doculam (transparent red). Your crosshatched feathers strangely remind me of a candy-stripe rose bush I had
Old May 08, 2006, 07:46 AM
zbrubaker is offline
Find More Posts by zbrubaker
ParkScaleModels
zbrubaker's Avatar
United States, PA, Loganville
Joined Feb 2002
I was just discussing this same thing with one of my club members. Anyone have a practical idea of what could be used to 'dye' doculam?
zbrubaker is offline Find More Posts by zbrubaker
Old May 08, 2006, 05:18 PM
Dwaine is offline
Find More Posts by Dwaine
Joined Mar 2005
Just a quick question. Are most people using the clear Doculam or the frosted for painted models and is there any difference between the two for painting?
Dwaine is offline Find More Posts by Dwaine
Old May 08, 2006, 07:36 PM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
Are there two different types? Doculam is frosted when first taken off of the roll, but turns clear when heat is applied.
