Old Sep 11, 2004, 06:09 PM
jleonard is offline
Find More Posts by jleonard
Jerry Leonard
USA, HI, East Molokai
Joined Feb 2001
Help launching planks
Having problems trying to launch plank type, M-60 etc., through dirty air trying to reach the lift zone. The planes pitch up or down or do wing overs into the ground, just can't throw fast enough to punch through. On a slope where wind is in your face there is no problem lauching but here the wind blows stright up off the face with a rotor behind. Its a little scarry climbing down the rocks to launch over 1000' drop. Maybe small bungee launcher?
jleonard is offline Find More Posts by jleonard
Old Sep 11, 2004, 06:16 PM
artmonster is offline
Find More Posts by artmonster
R U killing the kittens?
artmonster's Avatar
Chaos, UC
Joined Jun 2003
how 'bout a BIG bungee? !!!!!
those M60's are pretty tough....and a doubled up set of fat surgical tubing will get you to the good stuff in no time !
not to mention the giggle factor.
artmonster is offline Find More Posts by artmonster
Old Sep 11, 2004, 06:41 PM
jleonard is offline
Jerry Leonard
Joined Feb 2001
do I need to build a launcher or can it be hand launched with the bungee? I would like to keep it simple as possible.
Old Sep 11, 2004, 06:47 PM
Brian Courtice is online now
Find More Posts by Brian Courtice
Free as a bird now.
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
Where are you flying? I would really like to head over to Molokai some day and fly the cliffs near Kalaupapa with you!
BTW, it sounds like you are launching in a rotor. Is there no way to get right to the edge of the cliff for launch?
The simplest bungie launcher is just a few yards of heavy surgical tubing (the stuff the spear fishermen use on thier spearguns), and maybe another 50 feet or so of monofiliment fishing line.
You attach a stake at the tubing end, and tie a metal ring on the fishing line end. You attach a hook to the bottom of the plane, and the launch is a simple matter of walking the plane back for a good stretch and then you let go.
Brian Courtice is online now Find More Posts by Brian Courtice
Old Sep 11, 2004, 06:59 PM
artmonster's Avatar
Chaos, UC
Joined Jun 2003
put the hook on the plane just forward of the wing LE for high launches, and closer to the nose for more horizontal launches.
Old Sep 11, 2004, 07:07 PM
jleonard is offline
Jerry Leonard
Joined Feb 2001
more like redirected winds spilling over the top, the rotor is up about 100' and behind. It dosn't come into play until landing and is just a matter of diving through shear into calm air. Edge launch is best but not the safeiest(sp) at this spot. Jump on da boat and come fly anytime.
Old Sep 11, 2004, 07:09 PM
jleonard is offline
Jerry Leonard
Joined Feb 2001
just like mini high start, easy, I'll go strip the three prong
Old Sep 11, 2004, 08:07 PM
windsox is offline
Find More Posts by windsox
windsox's Avatar
Rochester New York
Joined Feb 2004
another option for those conditions is to get one of mike bakers sabre wings It is a cranked delta ( lower aspect ratio bat/ bluto type planform) it is set up so that it can be side arm or discus launched . Should be no problem to throw it to clean air.
windsox is offline Find More Posts by windsox
Old Sep 11, 2004, 08:46 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Nope!
Same problem with my BW Zipper;
Dial in some up trim(1/16"??) before you toss out. Then dial it out, a little at a time and watch 'er speed up.
You can do this many different ways, I needn't elaborate....
Good Luck,
Target
target is offline Find More Posts by target
Old Sep 11, 2004, 09:45 PM
timmig is online now
Find More Posts by timmig
timmig's Avatar
Southern California
Joined Sep 2003
"put the hook on the plane just forward of the wing LE for high launches"
Forward of the leading edge??? That would be interesting!! That would be out in front of the wing>? How about just ahead of the CG-- or on the nose. IMHO-- would be fun to launch that way.
timmig is online now Find More Posts by timmig
Old Sep 12, 2004, 02:04 AM
wish is offline
Find More Posts by wish
wish's Avatar
Germany
Joined May 2003
@ Timmig... the M60 has a fuselage
Greetings from Holland,
Bob
wish is offline Find More Posts by wish
Old Sep 12, 2004, 03:04 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Ya, launching the M60 in those conditions is tough because
its stall speed is faster than you can throw it, and you're probably
standing where there's turbulent air blowing at your back. Generally it's
best to hold it by the nose in front of the wing, walk out to the lip, and
hold it nose down in the wind, and give it a push. Another thing I've
done is sit down on the ground just behind the lip (where it's almost dead
still) and give it a good heave from there. There's a spot there
where it won't get pounded by turbulence until it crosses the
shear layer, and then it's flying anyway. Where there's problems
is if the slope/cliff face is ragged at the top and there's
a ledge or two down from the top churning up the air.. In that case,
the bungee would be your best bet.
ian
Daemon is offline Find More Posts by Daemon
Old Sep 12, 2004, 03:48 PM
jleonard is offline
Jerry Leonard
Joined Feb 2001
Bungee Works
I put together a couple yards of surgical tubing and about ten feet of sugi with swivels and a ring on the end. Drove short piece of rebar in the ground and attached the line.
Make a hook that attached to small piece of ply. taped it to fuse about 1 1/2" in front of leading edge. Hooked in the plane, held it in left hand at base of tail, walked back applying tenshon and launched, problem solved. Mahalo to everone that responded. Jerry
Help! Need help launching multiplex micro jet 840193 Parkflyers 7 Aug 14, 2007 09:49 PM
Discussion Need help launching pusher.... wab25 Pusher Prop Jet Models 10 Apr 27, 2006 03:42 PM
Help - Launching Micro Jet brobin1 Foamies (Kits) 14 Sep 01, 2003 02:54 PM
S&B Corsair.... help launching Arief Foamies (Kits) 19 Aug 17, 2003 06:31 PM
Help - Launching a Wedgie Helicool Foamies (Kits) 11 Jun 07, 2003 10:33 PM
