Old Sep 10, 2004, 09:59 PM
Nethole is offline
Find More Posts by Nethole
Registered Lurker
Nethole's Avatar
Joined Aug 2004
left slow circle turn in slowstick with FMS
Ddts
Nethole is offline Find More Posts by Nethole
Old Sep 11, 2004, 08:55 AM
ggunners is offline
Find More Posts by ggunners
Bit-Twiddler and Flyer
USA, VA, Chantilly
Joined Apr 2002
Originally Posted by Nethole
Yet, when I run the model, I get a slow left hand turn no matter what I do. elevator seems to work as expected. Any suggestions?
Motor torque, see the answer to your other post. Reverse the motor direction and it'll turn the opposite way.
-- ggunners
ggunners is offline Find More Posts by ggunners
Old Sep 11, 2004, 08:21 PM
Nethole is offline
Registered Lurker
Nethole's Avatar
Joined Aug 2004
how to add a second motor
Ddts
Old Sep 11, 2004, 08:34 PM
ggunners is offline
USA, VA, Chantilly
Joined Apr 2002
Here's 2 electric motors:
MOTOR //Motor(en) (motor, engine)
-0.4415 0 0 //Position [m] (position)
1 0 0 //Zugrichtung (direction of thrust)
0.1651 //Propellerdurchmesser [m] (prop diameter)
0.1397 //Pitch, Steigung des Propellers [m] (pitch, upward gradient of prop)
2 //Anzahl Propellerblätter (number of prop blades)
0.009 //mittlere Propellerblatttiefe [m] (mean chord length of prop blades)
RIGHT //rechtsdrehender Propeller (clockwise rotating prop)
0.0002 //Rotationsträgheitsmoment von Propeller und Motor [kg*m^2] (rotation moment of inertia)
4 //Kanal (channel 4)
ELECTRO //Motortyp = Verbrennungsmotor (motor type = COMBUSTION/ELECTRO)
12 //Nennspannung des Motors [V] (motor voltage)
15000 //Leerlaufdrehzahl [U (idling speed)
10 //Leerlaufstrom [A] (idling current)
70 //Blockierstrom [A] (blocking current)
1 //Übersetzung des Getriebes (typischerweise > 1) [-] (translation of transmission, typical > 1)
1 //Getriebewirkungsgrad [-] (transmission efficiency)
12 //Anzahl Zellen des Akkus (jeder Motor hat seinen eigenen Akku) [-] (number of batt cells)
2100 //Kapazität des Akkus (0=Akku nie leer) [mAh] (capacity of batts, 0 = never empty)
3 //Innenwiderstand des Akkus [mOhm] (internal battery resistance)
LEFT //rechtsdrehender Propeller (clockwise rotating prop)
Old Sep 12, 2004, 08:58 AM
Nethole is offline
Registered Lurker
Nethole's Avatar
Joined Aug 2004
trouble getting both engines
Ddts
Old Sep 12, 2004, 06:42 PM
ggunners is offline
USA, VA, Chantilly
Joined Apr 2002
Yes there are other things in the file that could cause a left turn to happen all the time.
One wing shorter than the other.
One wing positioned not directly opposite the other.
One wing with a higher angle-of-attack.
Wind pushing the model off track. Is wind zero?
Which model are we talking about?
Can you share the .par file?
-- ggunners
Old Sep 12, 2004, 10:16 PM
Nethole is offline
Registered Lurker
Nethole's Avatar
Joined Aug 2004
found problem
Ddts
Slowjazz video?? Any out there with slow planes flying in the gym? thor4944 Scratchbuilt Indoor and Micro Models 2 Oct 16, 2008 11:13 AM
Interested in starting with e-helis, need advice mromaszewicz Electric Heli Talk 11 Jan 30, 2002 08:20 AM
Some mistakes with FMS RookieOne Beginner Training Area (Aircraft-Electric) 13 Oct 27, 2001 03:22 AM
Need help with FMS to Hitec Fash 5 interface cord? Signal but no channel input. erashby Beginner Training Area (Aircraft-Electric) 9 Sep 15, 2001 11:49 PM
Using my controller with FMS spy0o7 Power Systems 4 Jun 30, 2001 08:43 AM
