Old Sep 10, 2004, 06:10 PM
AkshunJebus is offline
Find More Posts by AkshunJebus
what'd i break now?
AkshunJebus's Avatar
Dayton Montgomery, Ohio, United States
Joined Sep 2004
which direction should the rudder turn the tail?
just got a clone... first heli...
if i'm facing the tail of the heli and i move the stick (rudder) to the right, should the the tail move to the right or left.
of course the nose move in the opposite direction as the tail, so do the directions of the stick correspond with the nose or the tail?
just want to make sure i'm learning this the correct way.
thanks in advance
shawn
AkshunJebus is offline Find More Posts by AkshunJebus
Old Sep 10, 2004, 06:13 PM
Silverstreak328 is offline
Find More Posts by Silverstreak328
Really Cool User
Silverstreak328's Avatar
Tampa St Pete, Florida, United States
Joined Dec 2003
"Steer the nose, not the tail!"
Or else once you do forward flying it will be retarded....you know?
Silverstreak328 is offline Find More Posts by Silverstreak328
Old Sep 10, 2004, 06:17 PM
Geoffrey109 is offline
Find More Posts by Geoffrey109
Blade Springs "Rock"
Central Coast, CA
Joined Apr 2004
Try to get used to flying the nose. The answer is to the left facing the tail. The rotor is spinning clockwise, and the tail wants to go counterclockwise, so thrust is needed to compensate it. If you are flying the nose then it's to the right hand. It can get confusing, but think of it as you flying in the cockpit.
G.
Geoffrey109 is offline Find More Posts by Geoffrey109
Old Sep 10, 2004, 06:23 PM
what'd i break now?
Joined Sep 2004
thanks guys, i was afraid you'ld say that. it's so much more intuitive to me the other way.
oh well... to the simulator i go!!!
Discussion which way should the t-rex tail move?? matthew james Mini Helis 6 Dec 22, 2005 08:15 AM
Overlord - which way should motor turn? borgs Flying Wings 2 Sep 15, 2005 05:48 PM
Which way should my prop turn? Mr.Dickles Power Systems 2 Apr 19, 2003 12:35 AM
which way should prop turn Rugerman Power Systems 7 Dec 22, 2002 09:23 PM
moving up from corona to cp, which direction should I go jasonmbiggs Electric Heli Talk 15 Sep 13, 2002 08:24 AM
