Old Feb 06, 2002, 06:48 PM
green66 is offline
Find More Posts by green66
United States, CA, Covina
Joined Dec 2001
Large foam cores
Anyone know of a supplier who can cut large foam wing cores, 8 to 10 foot panels, preferably CNC-cut?
green66 is offline Find More Posts by green66
Old Feb 07, 2002, 01:36 AM
Avro is offline
Find More Posts by Avro
Pacific Models
Vancouver, BC
Joined Dec 2000
Lenght of panels
I can cut a 4 foot panels making a 8 foot wing or multiples ok. I don't think that anybody can cut more than 4 feet CNC.
What kind of wing are you looking for?
John
Avro is offline Find More Posts by Avro
Old Feb 07, 2002, 02:00 AM
green66 is offline
Joined Dec 2001
My requirements might make things tough, insofar as foam cores go. I'm looking to scratch-build a Paul-Bunyan-size flying-wing glider: 16 to 20 foot span, tapered planform, possible transitional airfoil and / or washout, need spar slots (parallel to span and off-angle) plus other cutouts, wing may be partially sheeted. Could probably live with joining 4-foot foam sections, although I haven't given that point much thought yet.
Old Feb 07, 2002, 01:37 PM
Ben74 is offline
Find More Posts by Ben74
Ben74's Avatar
San Francisco, CA, USA
Joined Jun 2001
you could try http://www.flyingfoam.com
Ben74 is offline Find More Posts by Ben74
Old Feb 07, 2002, 07:12 PM
Danal Estes is offline
Find More Posts by Danal Estes
Flys with Thumbs
Danal Estes's Avatar
Frisco, TX, USA
Joined Sep 2001
Dig up anyone who's built a Long-EZ, Vari-EZ, Quickie, Q2, Q200, or other all foam, full scale, person carrying, experimental aircraft. They build 16 to 30 foot wings from 4 foot long hotwired cores. There is a standard technique for joining that results in a strong light joint.
The brief description is:
1. A good butt joint of the foam, flat surfaces, no more than 1/16" gap anywhere.
2. A medium to dry slurry of microballons and epoxy in the joint, carefully portioned and applied so that it fills the joint but does not slop out any "edges".
There is a tiny bit more to it than described above, but that's the basics. Any set of plans and/or builders guide for a full scale "moldless composite" (i.e. Rutan style) aircraft will have all the details on how to join cores.
Danal Estes is offline Find More Posts by Danal Estes
need large foam blocks ryan d. Foamies (Kits) 6 Jul 30, 2002 05:54 PM
need foam cores cut ? foam_man Aircraft - Electric - Airplanes (FS/W) 0 Jun 16, 2002 08:56 PM
Yippee! Large foam cores - where to get them? green66 Power Systems 2 Feb 07, 2002 09:55 PM
Large foam cores - Know any sources? green66 Electric Plane Talk 2 Feb 07, 2002 09:39 AM
Yippee! Large foam cores - where to get them? green66 Power Systems 0 Feb 07, 2002 12:20 AM
