Old Feb 06, 2002, 06:40 PM
rsieminski is offline
Find More Posts by rsieminski
Florida
Joined Oct 2001
Source for a 5,6, or 7 to 1 Gear Box for a sp400?
I have had good results from 3.4:1, 10 700Mah NiMH, and 11X7 apc prop. I put the figures through MotoCalc and things really get good at around 5-7 to 1 with a bigger prop. The highest ratio box I can find is 4 to 1. Any suggestions?
Rick
rsieminski is offline Find More Posts by rsieminski
Old Feb 07, 2002, 01:17 PM
stuartaw is offline
Find More Posts by stuartaw
Berks, England
Joined Jun 2001
The highest I have seen in the shops is the Cosmotech (4.5:1). But listed in "Electric Flight Gearboxes" by Oliver Wennmacher are:
2-stage:
Conzelmann "Volksgetriebe", 5.4:1 and 4.3:1
Ludwig "CNC gearbox for 400 motors", 5.9:1 or less
Planetary:
Gross "Guppy", 6:1 or 5.29:1
I've no idea where these are available from. The author is from Germany, so I would try the mainland European distributors. The book is about 5 years old, so they might not still be around.
Stuart
stuartaw is offline Find More Posts by stuartaw
Wanted Mounting bolts for Hacker B20 w/4:1 gear box flystoolow Aircraft - Electric - Power Systems (FS/W) 8 Aug 02, 2006 12:17 PM
3- 1.7:1 gear drives for Speed 400 by Kyosho for Ferrias JTinCT Aircraft - Electric - Airplanes (FS/W) 2 Mar 16, 2003 07:38 PM
New - Hacker B50-11s Brusless Motor with 6.7:1 gear box! comes with Precision s Joe Pierson Aircraft - Electric - Airplanes (FS/W) 0 Mar 25, 2002 08:31 PM
Need a sp400 gearbox at 5, 6, or 7 to 1? Where? rsieminski Sport Planes 0 Feb 07, 2002 04:33 PM
Source for a 5,6, or 7 to 1 Gear Box for a sp400? rsieminski Parkflyers 0 Feb 06, 2002 11:20 PM
