Old Sep 09, 2004, 07:11 PM
GordySoar@aol.com
GordySoar@aol.com
Guest
n/a Posts
"I had the 9303 in my hands today!"
Hi guys,
Talk about coincidence! I am working a trade show in Windsor England and an
Aussie friend who sells a small loader has rigged it with servos and got the
new JR 9 to run it.
He flys IMACC gas stuff and JR.
Here's some stuff about it for those of you thinking of getting one.
First it is very much the 8103 program, so those of you already with an 8103
programming is normal for an open class ship.
It has Stylus style sliders on the sides.
It has a sort of rolling pin 1" long vertical 'mouse' on the right side of
the screen which allows you to rip thru the menu choices extremely
effectively. No hunting back and forth trying to 'see' where you need to find what you
want to change. You can do switch assignments. It is very light and uses the
same battery set up as the 8103 except for the pack has 9v battery
connectors on its end that slide into terminals, you know the mail and female ends on
a standard 9v alkaline type connectors (at least thats what they looked like
I didn't actually pull the battery) I did note that it does still have the
little plug on the board that the 8103 battery uses so I am guessing either
config works.
The screen size is very nice and there are 3 small rectangular buttons on
the left side of the screen that allows access to the 'adjustment' menu. To
get in the main menu, you simple hold down the 'mouse' roller, yes it not only
rotates for moving the cursor around on the screen it also acts as the
'enter' button.
No it does not do shift select. Z and S PCM and PPM same as the 8103.
Unlike a Stylus you can switch from aero to heli or sailplane models without
pulling cards or losing setups.
It has a two position switch on the top back right and a three position
switch on the front left face. Likely a little soldering could move them to swap
positions if you wanted the same access to flight modes (Launch, thermal,
reflex) like the Stylus. But from what I could feel, using the face switch
during launch proceedure would be no problem accesswize.
For those of you using lame ducks (versus the JR whip), the 9 uses the same
'inny' antenna as the 8103. (the Stylus uses and outy..screws into a mount
on the top, instead of deep inside).
Module is the same and there is a fuse still buried in there (pretty sure)
to protect the system against our charging abuse.
Shortcoming to me is digital trims on elevator, it would be neat if the
right lever could be used as elevator trim...beep beep beep beep..(question...was
that up or down trim movement:-).
So eat your hearts out....Gordysoar got there first again ;-)
Looks like slope west of London this Saturday with the British Nats Champ
again...gorgeous weather is supposed to end tomorrow nite.
North Dakota Sunday nite!
Gordy
George Voss
George Voss
Guest
n/a Posts
RE: "I had the 9303 in my hands today!"
No you didn't! The software for the US market is very different than the
9X. The case and face are the same from what I can tell. Hopefully though,
many of your comments will be true with the 9303. Hope you had a great trip
to England! gv
-----Original Message-----
Sent: Thursday, September 09, 2004 5:20 PM
To: soaring@airage.com
Subject: [RCSE] "I had the 9303 in my hands today!"
Hi guys,
"I had the 9303 in my hands today!".
Klaus Weiss
Klaus Weiss
Guest
n/a Posts
Re: "I had the 9303 in my hands today!"
Hey Gordy.
I have been using a 9Z for several months now. George says that the software for the US market is different. I don't know. I have found the 9Z to be a nice radio, and a good replacement for my 3810 (8103). Spring is here. When are you coming back for a visit?
Klaus Weiss
Sydney, Australia.
http://www.hsl.org.au
http://www.users.bigpond.com/kkw1
Old Sep 09, 2004, 11:11 PM
James V. Bacus
James V. Bacus
Guest
n/a Posts
John Diniz made a post on this exchange about a week ago, about setting up
his Tragi and actually using it...
Jim
Downers Grove, IL
Member of the Chicago SOAR club, AMA 592537 LSF 7560 Level IV
ICQ: 6997780 AIM: InventorJim R/C Soaring blog at www.jimbacus.net
RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off.
Old Sep 10, 2004, 09:11 AM
John Diniz
John Diniz
Guest
n/a Posts
The XP9303 is not in the hands of Gordy. The trany he was playing with does not have the US software. It is VERY different from the 8103 programming. Should be out very soon.
John
From: James V. Bacus [mailto:jimbacus@jimbacus.net]
Sent: Thursday, September 09, 2004 8:40 PM
Subject: Re: [RCSE] "I had the 9303 in my hands today!"
Jim
Downers Grove, IL
I held Babe Ruth's bat in my hands yesterday NewbieX Life, The Universe, and Politics 8 Feb 01, 2004 12:40 PM
Put a mpjet 25/35 in my formosa today! Newberry Foamies (Kits) 18 Oct 20, 2003 07:28 AM
Wemotec MC-001 Micro Fans in My Hands !!!! EAMRC Electric Ducted Fan Jet Talk 35 Jul 06, 2002 06:30 PM
