Old Sep 08, 2004, 06:07 PM
splash99 is offline
Find More Posts by splash99
Plane Crazy
Zurich, Switzerland
Joined Aug 2003
Multiplex Easystar part 10
so in little over a year we had over 4500 postings, and probably close to 50'000 viewings, if we can take thread 9 as a measure..
so here we go again: part 10 - the epic continues...
Easystar threads:
part 9, Aug 1st - Sept 9th 2004
part 8, June 21st - Aug 1st 2004
part 7, June 3rd - June 21st 2004 (18 days - boys we were BUSY those days!)
part 6, May 18th - June 3rd 2004 (16 days!)
part 5, May 3rd - May 18th (15 days!!!) 2004
part 4 , April 8th - May 3rd, 2004
part 3 , March 12th - April 8th 2004
part 2 , Feb 17th 2004 - march 12th, 2004
part 1 , Aug 21st 2003 - Feb 17th, 2004
I see we have slowed down a bit, while we did 500 postings in 2-3 weeks this spring, we are back to moderate typing now; we only need a new thread every 5 weeks
maybe people spend more time flying than typing...
splash99 is offline Find More Posts by splash99
Old Sep 08, 2004, 06:14 PM
Patrick Plawner is offline
Find More Posts by Patrick Plawner
Patrick Plawner's Avatar
Joined Sep 2001
10 threads already, Time flies. Thanks Splash99 for creating #10.
Should we celebrate this 10th birthday of our EasyStar with something special ?
Splash99, what about having the Easy build as a water plane ? Did you decide to not do it ? I really think it would be so nice to see this but it would not be easy, I guess.
Patrick Plawner is offline Find More Posts by Patrick Plawner
Old Sep 08, 2004, 06:22 PM
splash99 is offline
Plane Crazy
Zurich, Switzerland
Joined Aug 2003
already bought blue elapor floats, good for up to 750 g AUW.
Still thinking about how to put them on, non-permanent (i.e. so that I can decide when they come of )
Old Sep 08, 2004, 06:27 PM
Joined Sep 2001
Can't wait to see your test flight with this
When do you think it could be ? Among the 10th thread sounds reasonnable for it or you will just land the EasyStar on a frozen lake soon
That's another one. The EasyStar taking of from hard snow. I would love to ski and pilot a EasyStar, all the way down the slope....
I wish I would live near a ski resort....
<replaced "leave" with "live">... And thanks for pointing me to this mistake
drj153 is offline
Find More Posts by drj153
Numb Thumbs
drj153's Avatar
Melbourne, Australia
Joined Oct 2003
Float Plane
Get ZoomZoom's setup and you probably won't be on the water long enough to need floats! Sure should ROW easily enough!
Cheers
David
drj153 is offline Find More Posts by drj153
Old Sep 08, 2004, 06:35 PM
splash99 is offline
Plane Crazy
Zurich, Switzerland
Joined Aug 2003
zz setup will RO anything...
Patrick: I did ROG with the ES in near stock (400 7,2V, 8xKAN1050, 5x4) last winter of some heavy, already warm powder snow.
No Problem.
The climbout wasn't as impressive as zz's, though...
oldpilot is offline
Find More Posts by oldpilot
oldpilot's Avatar
Australia, NSW, Mona Vale
Joined May 2002
MAKE a little stub wing out of balsa ("BALSA"--horrors) about 250mm long. Glue it to the bottom of the fuse under the CG. Glue the floats under the tips of the stub wing so that the CG remains in the correct position. No need for any struts. The step on the floats should be just Fwd (2mm) of the CG for correct attitude for take off.
Worked for me on an EPS ducted fan plane.
Cheers. Paddy.
oldpilot is offline Find More Posts by oldpilot
Old Sep 08, 2004, 06:56 PM
jcosta is offline
Find More Posts by jcosta
SlopeHead
jcosta's Avatar
Lisboa, Portugal
Joined Jan 2004
Vielen danke, Herr Meyer!
jcosta is offline Find More Posts by jcosta
Old Sep 08, 2004, 06:57 PM
splash99 is offline
Plane Crazy
Zurich, Switzerland
Joined Aug 2003
Paddy:
thought about that, but I want to take the floats off occasionally.
Velcro?
Ercman: re your question at the end of thread 9:
porpoising comes from noseheavyness.
See also: Thread 7 , post 491 and others, we have discussed this indepth many times, bc is so confusing for beginners. Yuo could run a search and will find a lot of information alone in the ES threads.
Or Post 307 in the Magister thread 2 about a related topic.
Old Sep 08, 2004, 07:07 PM
splash99 is offline
Plane Crazy
Zurich, Switzerland
Joined Aug 2003
Originally Posted by jcosta
Ah, so I can put it in the corn field!!!
Have you seen the videos yet?
yes - you look good
had no time to edit, cut nor compress them yet.
a nice inverted sequence with a lovely comment from you
Old Sep 08, 2004, 07:10 PM
Zoomzoom is offline
Find More Posts by Zoomzoom
Joined Jul 2002
Jeez, guys it's just one of those sweet running 6V Speed 400's with a 6 cell 840 mAh battery It just barely gets off the ground.
The setup does get the Easy Star a little more respect from other flyers though Scared the crap out of someone flying one of those ParkZone J-3 Cubs with it I thought he was going to soil himself.
Zoomzoom is offline Find More Posts by Zoomzoom
Old Sep 08, 2004, 07:14 PM
jcosta is offline
SlopeHead
jcosta's Avatar
Lisboa, Portugal
Joined Jan 2004
yes - you look good
What is the comment, if printable? I bet it's something about Patrick "doesn't fly well inverted" Plawner... The man has proven that he can fly anything, except for an inverted EasyStar... My current record is over 30 seconds inverted at full speed (After that I nose planted it because I was flying far too low - 3-4 meters)
And my flying may look OK, but I never look good, except to my wife and kids - "love is blind"...
Old Sep 08, 2004, 08:49 PM
oldpilot is offline
oldpilot's Avatar
Joined May 2002
SPLASH.
If you want to take the floats off just glue some hard balsa inserts in the Fuse and screw the stub wing on with SS screws.
I did that too after an inadvertant landing on"Terra Firma" tore the floats and stub wing off the Fuse. I'll see if I can find a pic.
Cheers. Paddy.
Old Sep 08, 2004, 08:54 PM
jug is offline
jug
Find More Posts by jug
jug
Joined Aug 2004
Air intake
Just finished my second easystar today and I noticed how hot it gets inside the cockpit. I'm afraid I will damage some of the electronics with the amount of heat it builds up during long flights so I want to cut a hole in the front to air it out. Looking for some tips on how to do this right. What are the disadvantages and do you need an exhaust? I like oldpilots intake mod but I dont know where to put the exhaust.
jug is offline Find More Posts by jug
Old Sep 08, 2004, 09:30 PM
Hammer Head is offline
Find More Posts by Hammer Head
the journey is the reward
Hammer Head's Avatar
Canada
Joined Apr 2002
Just watched the Zoom Zoom vid!
WOW, lol …that is one cool...ROG?...maybe an SOG
Sliding off Ground
Sledding off Ground
Skidding off Ground
HH
Hammer Head is offline Find More Posts by Hammer Head
Yippee! Multiplex EasyStar thread - Part 3! tim hooper Foamies (Kits) 496 Apr 08, 2004 05:40 AM
Multiplex EasyStar thread - Part 2 tim hooper Foamies (Kits) 502 Mar 11, 2004 05:10 PM
New from Multiplex: EasyStar Jurgen Heilig Foamies (Kits) 497 Feb 16, 2004 11:18 PM
Yippee! GWS Tigermoth Story ....Part 10 1987tc Parkflyers 505 Jan 12, 2004 02:28 AM
Discussion Multiplex EasyStar For FMS aeropal Simulators 0 Nov 19, 2003 12:19 AM
