Old Sep 08, 2004, 07:22 AM
parabelum is offline
Find More Posts by parabelum
Joined Jul 2002
Question
Mig 15 home build
Hi everybody!
I've read a lot of post here and now I'm building a Mig 15 with wemotech minifan 480 and HP 200/20/6 motor.
I'm planning to fly with 3s2p lipos.
But I still have a question: What sould be the best airfoil for my mig???
I looked up for an Eppler 193 or an SD6060 but I realy don't know witch one to choose and if I'm right with those.
If anybody can help! TNX
Sorry but my English is not perfect.
parabelum is offline Find More Posts by parabelum
Old Sep 08, 2004, 07:36 AM
sibstar is offline
Find More Posts by sibstar
sibstar's Avatar
Bath, SW, UK
Joined Jan 2004
The K&A mig has SD6060 and flys real good
sibstar is offline Find More Posts by sibstar
Old Sep 08, 2004, 07:45 AM
Joined Jul 2002
Thanks for answer! I think it's a good option but on K&A mig, they say that it's a SD6060 MODIFIED so what will be the difference between the standard and the modified one?
What is modified on this K&A's SD6060???
Not simple at all for me...
Old Sep 08, 2004, 07:48 AM
sibstar is offline
sibstar's Avatar
Bath, SW, UK
Joined Jan 2004
Sorry thats beyond my knowledge.
Old Sep 08, 2004, 07:56 AM
Joined Jul 2002
I also want to hand launch it and have a smooth flight like the Alfa's mig.
I hope it will be around 650 g-700 g / 22 oz - 25 oz
Old Sep 08, 2004, 08:08 AM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
For models that size when you want good hand launchability you really can't beat the S3021. My Panther uses it (it has been nahd launched, but I don't because it's too hard to hold on to), and Graham's Aviojet uses it (it handlaunches perfectly). You can't design a small jet aimed purely at flat out performance as the airfoils that will give that will really suffer at low speeds. BTW, put 1.5-2 deg washout in the tips, essential with a swept wing! Good luck!
Stu.
ps. a modified SD6060 is no longer an SD6060, and you can't pay any attention to the SD6060's polars. There are so many good airfoils to choose from, I can't understand why anyone with less knowledge than Dr's Selig or Donovan (or Dr Drela) would attempt to "modify" and already good airfoil......
stumax is offline Find More Posts by stumax
Old Sep 08, 2004, 10:26 AM
Joined Jul 2002
Ok then I will use S3021, I hope it works cause the mig has a biger V in the wing so it's quite different than the panther.
If anyone have more info about airfoil, I'll be happy to get it.
TNX all your very helpfull!
Old Sep 08, 2004, 10:57 AM
sukhoiboi is offline
Find More Posts by sukhoiboi
wiltshire, england
Joined Apr 2004
I have built and flown a fully scale mig 15 with 25 inch wingspan for microfan using an rg14 section with 1 degree of incidence and 2 degrees of anhedral. we have never tried a hand launch but im sure it could be done. it had amazing slow speed handling and would come in at a slow walking pace once you had scrubbed off speed. which takes a while with rg 14. it was designed for pylon racing so cornering without scrubbing speed is what the section was designed for
sukhoiboi is offline Find More Posts by sukhoiboi
Old Sep 08, 2004, 11:18 AM
William E Brown is offline
Find More Posts by William E Brown
Wichita, KS
Joined Apr 2003
Most airfoils identified as modified have the trailing edges made a finite thickness (as opposed to a razor sharp edge) and the last 10-15% made a straight line to the trailing edge (no convex control surfaces as a flutter preventive measure). At Beech that is why the Bonanza airfoil is identified as an NACA 23012 modified.
Wm
William E Brown is offline Find More Posts by William E Brown
Alfa MIG 15 Build sarge Parkflyers 170 Nov 28, 2013 06:13 PM
Kamdax Mig-15 Build MDG3 Electric Ducted Fan Jet Talk 137 Dec 12, 2006 11:52 AM
Discussion alpha mig-15 build nitromag57 Electric Ducted Fan Jet Talk 0 Jul 14, 2006 09:50 AM
Discussion Alfa MIG-15 build question cmb5 Foamy EDFs 12 Jul 07, 2006 09:10 PM
Question Mig 15 Build Mopar92 Electric Ducted Fan Jet Talk 4 Aug 19, 2004 01:10 PM
