Old Sep 08, 2004, 05:15 AM
ontheweekend is offline
Find More Posts by ontheweekend
ontheweekend
Sydney, Australia
Joined Jul 2004
My First Lipo, Need Help, Whats with the two wires? Photo Attached for reference
Hi there,
I recently bought my first lipo and charger (picture attached).
http://www.ontheweekend.com.au/personal/lipo1.jpg
http://www.ontheweekend.com.au/personal/lipo2.jpg
My question is this, whats the second wire for, or with Lipo's, do you not just charge straight into the normal connector?
The charger has a couple of standard connectors.
Can anyone tell me what is supposed to go where before I set myself on fire?
Also, the charge can charge as small as 0.5 amps, everywhere i read you should charge as slowly as possible.
The lipo is 11.1v 1900mah, wont that take days to charge at .5 amps?
Cheers
Rob
ontheweekend is offline Find More Posts by ontheweekend
Old Sep 08, 2004, 05:53 AM
sarge is offline
Find More Posts by sarge
sarge's Avatar
Fayetteville, NC
Joined Dec 2002
Did you buy that LiPo for a very specific application? I don't recognize the connectors. If your charger has matching connectors, charge on the connector with the heavier gauge wire. Charging at .5 amps (500mah) will take about 4 hours if the batt is discharged to a high degree. You can safely charge at up to 1C, or in your case 1.9 amps/1900mah.
sarge is offline Find More Posts by sarge
Old Sep 08, 2004, 05:57 AM
windface is offline
Find More Posts by windface
windface's Avatar
San Juan Marin Intl, Puerto Rico
Joined Jul 2002
The other plug is to monitoring the cell one by one.
windface is offline Find More Posts by windface
Old Sep 08, 2004, 08:58 AM
ontheweekend
Sydney, Australia
Joined Jul 2004
Originally Posted by sarge
Did you buy that LiPo for a very specific application? I don't recognize the connectors. .
No, its just the connector the lipo came with, which I will have to change to fit the connector I have on the plane.
Rob
Old Sep 08, 2004, 09:14 AM
gtstubbs is offline
Find More Posts by gtstubbs
gtstubbs's Avatar
Perth Westen Australia
Joined Jun 2003
Originally Posted by ontheweekend
Hi there,
Cheers
Rob
How about a picture of the actual charger and its connections/connectors?
Are the charger and the pack som sort of matched set?
Any instructions with the pack and charger and what do they say?
gtstubbs is offline Find More Posts by gtstubbs
Old Sep 08, 2004, 12:50 PM
moyg is offline
Find More Posts by moyg
Morristown,NJ
Joined Oct 2003
The "primary" connector is a Molex / Tamiya / Kyosho variation used in a few scant applications. (What country are you in?) The "monitoring/balancing" connector looks similiar to the PolyQuest connector available from www.aircraft-world.com which appears to be down right now. As far as charge rates, what sarge said ... it's somewhat a matter of how gentle you want to be to them.
Just got the site, check:
www.aircraft-world.com/shopexd.asp?id=2124
moyg is offline Find More Posts by moyg
Old Sep 08, 2004, 01:28 PM
Flybyguy is offline
Find More Posts by Flybyguy
Go Giants!
Flybyguy's Avatar
San Mateo, California, United States
Joined Jun 2002
When you change that connector, cut one wire, solder the new connector to it, then cut the other wire and solder the other wire.
As in, cut red wire, solder red from battery and red from new connector.
Then, black and black.
That way, there is no chance of shorting the battery out and having it go thermal on you.
Brian
Flybyguy is offline Find More Posts by Flybyguy
Old Sep 08, 2004, 05:38 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
This should help with the charger; http://www.rcgroups.com/links/index.php?id=4535
Change the main connector for sure though. The Molex plugs are lousy.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Sep 10, 2004, 08:47 PM
ontheweekend
Sydney, Australia
Joined Jul 2004
Many thanks for all the help, looks like i happened to buy a decent charge by mistake!
Cheers
Rob
Discussion painted my first body, need help with rider columbo Motorcycles 11 Dec 31, 2006 01:14 AM
Discussion emaxx noobie - my first truck - need help TerryE Off-road Cars 2 Jun 17, 2006 12:44 PM
My first Helicopter - I need help, no really! Daddy-O Micro Helis 42 Aug 15, 2005 05:34 AM
Setting up my first Hummingbird - Need Help. Mesmer Micro Helis 3 Dec 12, 2003 09:31 AM
narrowed down choices for my first HLG! Need help selecting. MichaelConnally Hand Launch 19 Sep 08, 2002 03:40 PM
