Go Back   RC Groups > Aircraft - Electric - Airplanes > Electric Plane Talk
Old Feb 06, 2002, 07:02 AM   #1
Throttle Target for Stall Speed?
Wondering if there is a general rule about throttle targets for stall speeds. While playing with eCalc I noticed different throttle ranges for different motor cell combinations as when it created a stall. Is there a rule of thumb you more experienced eflyers use i.e. stall at 30% throttle?
Martin
martin johnson is offline Find More Posts by martin johnson   Reply With Quote
Old Feb 06, 2002, 07:39 AM   #2
Stall speed can vary due to many factors and to a large extent has little to do with throttle setting. Any manouvre including turns increases the speed at which an aeroplane stalls due to the increased wing loading and drag so its not possible to come up with such a throttle setting.
The stall speeds given by programs like ecalc should be treated like all such information - as a guide only!
Brian
FlyinBrian is offline Find More Posts by FlyinBrian   Reply With Quote
Building Floater: wing loading / level flight stall speed relationship opualuan Parkflyers 7 Sep 30, 2007 05:41 PM
calculating stall speed Mike L Power Systems 17 Oct 23, 2001 06:13 AM
Prop for direct speed 300 T_Hartigan Electric Plane Talk 11 Sep 24, 2001 10:30 PM
"Tapping Off" Cells for BEC Speed Controls shv2sail Electric Plane Talk 9 Jun 28, 2001 12:20 PM
Help I need a good inline gearbox for my Speed 480 Joe Elston Electric Plane Talk 6 May 15, 2001 04:58 AM
Congratulations SimpleM!
