Old Sep 07, 2004, 01:23 PM
Persistant is offline
Find More Posts by Persistant
Somerset, PA
Joined Feb 2004
Yippee!
Please check-out my setup before I purchase
If you get a chance, please take a look and tell me if this setup is ok or not.
equipment I have:
1= Hitec flash4
2= CCPH10
3= 3S irate 1100 (Should I get 2S for the weight savings?)
1= gws4n receiver
2= Hs55
What I plan to purchase:
1= GWS Dragonfly base kit.
1= GY240 gyro
1= Himaxx 2015-4100 (main rotor) - which pinion? 12t?
(would this be the correct model for 3S?)
1= Feigao IPS brushless (tail rotor) which prop?
2= set of M24 rotor blades
Please let me know if I left anything out or If there is something I should change
Thank you very much,
-Jerry
Persistant is offline Find More Posts by Persistant
Old Sep 07, 2004, 01:38 PM
Vince Herman is offline
Find More Posts by Vince Herman
Vince Herman's Avatar
United States, OH, Strongsville
Joined Nov 2000
3 cell LiPos will give you so much more power. I would think that this is almost the only way to go, if you are full brushless.
1= gws4n receiver
Some people report difficulties with this receiver when they have it in such close proximity to noisy electronics. I have not experience that directly, as I use a different receiver, and I do not recall what Brother #1 and Brother #2 use on theirs.
Vince Herman is offline Find More Posts by Vince Herman
Old Sep 07, 2004, 02:12 PM
Yukonho is offline
Find More Posts by Yukonho
I see the future.
Yukonho's Avatar
Halfmoon Bay, BC, Canada
Joined Feb 2002
The only thing I see that you would change is the pinion. Use a 9 tooth with 3s LiPo's on the Dragonfly. You will have WAY more power than you know what to do with, dont worry about the weight of the batteries.
Also, I am not sure about the m24 blades. Being the maker of like90 blades, of course I recommend them. Getting your headspeed up is essential for good control.
Vince has a point about the receiver. They are not the best, and with the 2 CC Phoenix 10's, (which generate a good deal of rf noise) you may wish to consider a berg. The Berg 4 dsp is cheap and SOLID!
Standard prop for the Feigao is a GWS 3030 I believe.
Dont forget a head stiffener.
co
Yukonho is offline Find More Posts by Yukonho
Old Sep 07, 2004, 02:27 PM
Geoffrey109 is offline
Find More Posts by Geoffrey109
Blade Springs "Rock"
Central Coast, CA
Joined Apr 2004
Or.....
http://www.balsapr.com/common/single...ductId=U695483
The stock Dragonfly II prop with adapters.....
G.
Geoffrey109 is offline Find More Posts by Geoffrey109
Old Sep 07, 2004, 07:26 PM
Somerset, PA
Joined Feb 2004
If I get an HB elite do I need a head stiffiner?
Discussion Please check out my on sale AP equipment rudyy Aerial Photography 0 Jun 19, 2007 06:49 PM
Discussion Please Check Out My Checklist dmt Beginner Training Area (Aircraft-Electric) 30 Dec 27, 2006 09:16 PM
My Great Planes PT-40 MKII setup. please check out jkkissick Fuel Plane Talk 1 Jan 01, 2005 07:28 PM
My first AP web page! Please check out! Talontsi96 Aerial Photography 21 Nov 30, 2004 02:29 PM
