Old Sep 06, 2004, 10:11 PM
MK
MK
Guest
n/a Posts
GP Super Skybolt is tail heavy
Years in the building, by 2 builders, the craft is near completion. Way
tail heavy. I tired two standard 600maH RX batts on the firewall but it
still needs much more.
I'm concerned about putting batteries on the firewall. it's wrapped with
auto trim mounting tape(servo tape) and screwed down with plumbers
tape(steel strip whit holes in it)
Eng is an MVVS 90, too much power I think but If I go out and buy a 90
four stroke I don't think it'll be much heavier.
I guess I need to break down and buy an after market fiber glass cowl and
put the eng out on the end of the eng mount beams....then add lead!
Just sounding off before I get the lead out<G>
mk
Old Sep 07, 2004, 12:11 PM
Mathew Kirsch
Mathew Kirsch
Guest
n/a Posts
Re: GP Super Skybolt is tail heavy
"MK" <mikekolodziejREMOVEKILLERCHAOS@earthlink.net> wrote in message news:<th8%c.31$xA1.28@newsread3.news.pas.earthlink .net>...
> mk
Absolutely nothing surprising or new about this... The Super Skybolt
is reputed to build heavy, and tail-heavy at that. The Super Skybolts
I've seen all have 1.20 4-strokes in them, both for the nose weight
and extra power to pull the hefty bird around with any authority.
Old Sep 09, 2004, 02:11 PM
Harry Kolomyjec
Harry Kolomyjec
Guest
n/a Posts
news:th8%c.31$xA1.28@newsread3.news.pas.earthlink. net...
> mk
My Super Skybolt had much the same construction time and people working on
it as yours, but I substituted 1/4" aircraft ply for the firewall and
landing gear mount. Drilled the aluminum landing gear for a 1/4-20 plastic
screw and made the wood cover removable. Replaced the mickey mouse cowling
with a fiberglass cowl, used a 1100 mah battery pack, and installed a OS
pumped 1.20 four stroke.
I didn't need any nose weight and the aircraft flew and landed perfectly,
you couldn't ask for better flying aircraft. You will be happy with that
..90, use it!
One thing...you have to allow for a turn and one-half extra after releasing
the controls from a spin.
Good luck,
Harry
Discussion Any convert a GP Super Skybolt to elec? jcm1010 Electric Plane Talk 1 Aug 08, 2006 09:44 PM
NIB GP Super Skybolt kit (FREE SHIPPING) Biper/Piper Aircraft - Fuel - Airplanes (FS/W) 8 Feb 06, 2005 12:44 PM
