Old Sep 06, 2004, 09:11 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
The Dr Kiwi Test Stand revisited
A forum member asked me for measurements of my crude, but well-used and oft-illustrated test stand, so I drew up a diagram for him. I thought others might be interested, so here it is for general consumption (along with a few other photos to illustrate details not well explained by my poor quality rendition).
I've attached the drawing with measurements [not great quality, but I hope it will serve the purpose]. Also, some photos showing you how I made my base plate - depending on the type of scale you have, yours may have to be quite different. The structural upright part of the stand was all made from ~1"x1/2" pine - actually sold by Ace Hardware for ~$2 as a 3' long garden stake or sign post!
If you modified the design a bit you could accommodate larger props - I can just squeeze a 12" in there if I mount the motor exactly right! As you know from the other photos I've posted in the forum, all the gear (battery, Whattmeter, flashlight for tach, Rx, ESC, and obviously the motor) is loaded on top of the base plate, so that one only has to tare the scale to get a direct reading for thrust. The electrical gear is held by velcro, the flashlight sits in a crude foam "holder", and the leads are held in place by rubber bands looped over the various dowels. I have made up numerous motor mounts to accommodate everything from LensRC and Feigaos up to Phasors, and even ducted fans. These are simply screwed on to the flat/wide face of the vertical post.
If you have any questions just ask.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 31, 2004, 06:34 AM
Aspen is offline
Find More Posts by Aspen
Aspen's Avatar
Kingsport Tn.
Joined Nov 2001
Thanks for posting this. I finally got tired of guessing and built it yesterday. I used ¾” x ½” pine (since I couldn’t find 1” x ½”) and sized it to handle a 14 in. prop. I also used ¼” hardwood dowels throughout, including 2 to connect it to the base. The only screws used were those for the motor mount. Works great!
John
Aspen is offline Find More Posts by Aspen
Old Oct 31, 2004, 07:01 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
I went a little different way when I hacked mine out. It's 12" square, so a 14" prop is no problem. It's made up of a scrap particle board base, some 1/8" dowels and some 3/8" square stock. Lashed and CA'd together. So far no problem at 24oz of thrust...
Gene Bond is offline Find More Posts by Gene Bond
Old Oct 31, 2004, 12:08 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
John - Beautiful job - now mine looks really amateurish! How have you attached the base to the scale (?velcro or little rails beneath it on 3 sides)? If you get a biggish motor/prop on there pushing 20oz thrust it's going to want to wander around.
Cheers, Phil
Old Oct 31, 2004, 02:40 PM
Aspen is offline
Aspen's Avatar
Kingsport Tn.
Joined Nov 2001
Phil, I covered the bottom with the 1/4" latex foam used to pad slimmer gas tanks and radio equipment. It's extremely non-skid. The Mamba in the picture developed 24 oz of thrust and didn't move a bit.
John
Old Nov 06, 2004, 04:13 PM
umrk is offline
Find More Posts by umrk
umrk's Avatar
Paducah Barkley, Kentucky, United States
Joined Sep 2003
Variations on a theme...
Under Construction.
Thanks Doc!
mike
umrk is offline Find More Posts by umrk
Old Nov 06, 2004, 04:35 PM
peterangus is offline
Find More Posts by peterangus
peterangus's Avatar
Blackpool, Great Britain (UK)
Joined Dec 2003
These devices don't measure thrust, they measure thrust minus drag.
Obstructions to airflow in the slipstream should be minimised and streamlined.
peterangus is offline Find More Posts by peterangus
Old Nov 06, 2004, 05:16 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I agree that the design is not ideal [I tossed it together in an afternoon], and certainly the "bits" above the prop could be better streamlined, but I wonder exactly what percentage error we are inducing by having relatively small obstructions several inches behind the prop [and its much the same for every motor/prop we test, so our comparisons might still be reasonably valid - even if our absolute numbers are not spot on]. I imagine the most significant absolute error is in having an essentially stalled prop - but again, that's how it is for every prop we test, so the results are, to a considerable degree, comparable.
Cheers, Phil
Old Nov 06, 2004, 06:16 PM
umrk is offline
umrk's Avatar
Joined Sep 2003
And theres the fact that most planes do have some drag in the prop blast so it may be closer than you think.
Also I made mine so the motor/prop can be mounted on top/ pusher fashon (notice top unused hole in pic) if I wanted to, to minimize that if need be.
peterangus, show us your test stand, we've shown you ours.
mike
(of course you'd also need to match temp., humidity, altitude, airspeed... if you want to get picky )
Old Nov 07, 2004, 05:22 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Cheers, Phil
So now you need to build a variable speed wind tunnel, so you can get in-flight numbers.
Pinecone is offline Find More Posts by Pinecone
Old Nov 07, 2004, 09:11 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Yup. The back bell is a quickly thrown together version. I have a much better one in the works for a more powerful fan I got for it.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Nov 07, 2004, 09:25 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I for one think it is extremely nice of everyone to share both their collected data and means used to collect it. If you feel their data is inaccurate then collect your own or use someone elses.
Most of us here are hobbiest and some seem to think we are all wanabe rocket scientist.
My wind tunnel is provided by my revolving propellor and mother nathure.
My extremely hitech thrust stand can be viewed at post # 291 this thread
http://www.rcgroups.com/forums/showt...ghlight=lensrc
Charles
Charles
Old Nov 07, 2004, 10:36 AM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
Cheers, Phil
Your published thrust data (given prop and rpm) is allways lower then my measurements. The difference is about 10...15%. I think it is because of the drag of your stand (the parts above the propeller). My stand is a pusher, nothing in the path of the propeller wind (of course, this layout has its own shortcomings too).
However, as in most cases the aeroplane itself is in the path of the propeller wind your measurement maybe closer to the practical applications.
mmormota is offline Find More Posts by mmormota
Old Nov 07, 2004, 10:44 AM
umrk is offline
umrk's Avatar
Joined Sep 2003
Nice, Gordon!
Are you implementing a means of straightening and equalizing the air flow / ressure?
(I'm probably expecting too much on a hobby setup.)
mike
Old Nov 07, 2004, 11:30 AM
Boston, Mass
Joined May 2001
It has a honeycomb flow straightener (that's the white stuff in the intake bell) and three layers of screens behind that. Dave Robelen, retired NASA wind tunnel area, is my input for wind tunnel design points, and also the builder of a few hobby wind tunnels of his own.
Gordon
Build Log Dr Kiwi Thrust Stand revisited. Dr Kiwi Power Systems 74 Dec 07, 2015 11:04 AM
Discussion A Goldmine of Motor Test Data from Dr Kiwi hoppy Power Systems 9 Jun 03, 2007 04:33 PM
Discussion Thrust stand reconfiguration - the Dr Kiwi Mk III Pusher version Dr Kiwi Power Systems 26 Jul 04, 2006 01:46 PM
Dr. KIWI, please explain 7, 8, 9, 10, 11v test ratings Gyroguru Power Systems 3 Oct 07, 2005 10:12 PM
Eureka! Dick Hanson/Dr Kiwi thrust stand calibration Dr Kiwi Power Systems 10 Mar 12, 2005 04:39 PM
