Old Sep 05, 2004, 10:37 AM
kahuna_socom
A moderator felt this post violated the following rule: Cross-posting. It is temporarily hidden while kahuna_socom edits it.
Old Sep 05, 2004, 11:04 AM
willhicks is offline
Find More Posts by willhicks
Dealer
Hendersonville, NC
Joined May 2004
Can you post a picture of the problem? That would help a lot.
Will
willstech.com
willhicks is offline Find More Posts by willhicks
Old Sep 05, 2004, 12:27 PM
kahuna_socom is offline
Find More Posts by kahuna_socom
Joined Aug 2004
well its sooo small its really hard to see!!!!! even with bare eye
kahuna_socom is offline Find More Posts by kahuna_socom
Old Sep 05, 2004, 03:10 PM
Joined Aug 2004
here it is....
Old Sep 05, 2004, 03:12 PM
umrk is offline
Find More Posts by umrk
umrk's Avatar
Paducah Barkley, Kentucky, United States
Joined Sep 2003
Bad link to the pic... " http://proppic.jpg/ "
mike
umrk is offline Find More Posts by umrk
Old Sep 05, 2004, 03:15 PM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
Try again, but this time click on the "Manage Attachments" button below and upload the image file.
Miami Mike is offline Find More Posts by Miami Mike
Old Sep 05, 2004, 03:19 PM
Joined Aug 2004
ok here it goes
Joined Aug 2004
its about one cm from the end of the thread.
Old Sep 05, 2004, 04:28 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
You need a tool called a "die". Taps and dies usually come in sets, but you might be able to get the one you need from a specialty tool store. You might also try to find someone who already has a tap & die set with the size you need. The die will screw onto the shaft and cut new threads in the bad section.
Old Sep 05, 2004, 05:22 PM
Sunspot is offline
Find More Posts by Sunspot
CLUB GITMO
Sunspot's Avatar
Little Rock National Airport
Joined Nov 2003
Remove the GB from the motor...Apply a small amount of heat while you attempt to loosen the screw.....be careful not to apply too much heat as it will warp your shaft....
Good Luck..
Spot.
If it is cross-threaded do what Miami said too.
If you are using thread lock...I hope it is blue....
Sunspot is offline Find More Posts by Sunspot
Old Sep 05, 2004, 05:37 PM
bhenry is offline
Find More Posts by bhenry
Crash Dummy!!!
bhenry's Avatar
Dallas Love, Texas, United States
Joined Jun 2004
I would suggest removing the motor and then taking the E clip off.
It's the clip that holds the drive shaft on.
BECAREFUL because the little sucker is hard to find.
You can then use pliers to hold the shaft and take action.
I have several replacement drive shafts ($1.25) and a pack of E clips ($1.00 for 20) I got from Hobbytown.
It really helps having them around when they are needed.
bhenry is offline Find More Posts by bhenry
Old Apr 10, 2005, 09:39 AM
Joined Aug 2004
thx alot guyz but i just ordered a new prop shaft!thats the easiest thing to do!!
Old Apr 10, 2005, 10:00 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Order ten
They bend!
Old Apr 10, 2005, 10:41 AM
Old Man is offline
Find More Posts by Old Man
Master of the figure 9
Old Man's Avatar
United States, IN, Indianapolis
Joined May 2004
Originally Posted by vintage1
Order ten
They bend!
What Vintage said. I usually buy 10 to 15 at a time. I order 20 props at a time as well. I hate being grounded by a $2.00 item.
Old Man is offline Find More Posts by Old Man
Old Apr 10, 2005, 02:51 PM
Joined Aug 2004
ya i already was safe and bought a whole 50 peice box of props from my local shop but they had no prop shats!!so i ordered it but it still hasnt come in yet
