Old Aug 05, 2001, 11:36 AM
Pira-Cee is offline
Find More Posts by Pira-Cee
Hazleton, PA, USA
Joined Jun 2001
Zagi & removing 3M adhesive
My first Zagi 400 Electric is coming along. I have it to the point where the strapping tape is applied to both sides. However, I had a coating of 3M Super 77 Spray Adhesive on both sides, preparing to cover with the colored tape. I had to cut my building session short. I'm wondering, for weight reasons, if it makes sense to get some of it off and respray, since it's now far less tacky. If so, what's the easiest method of doing so?
Phil http://www.flightdeck.homestead.com/index.html
Pira-Cee is offline Find More Posts by Pira-Cee
Old Aug 05, 2001, 03:22 PM
peterv is online now
Find More Posts by peterv
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Hi Phil,
I would not worry about removing the 3M. Most modelers when covering foam let the 3M cure for 24 hours before covering, I've done it both ways and note the tape holds up much better if you let it sit for 24 hours and then tape it up.
Good Luck,
Pete
peterv is online now Find More Posts by peterv
Old Aug 05, 2001, 06:38 PM
Pira-Cee is offline
Hazleton, PA, USA
Joined Jun 2001
Thanks for the advice, Pete. It's actually been several days since I originally sprayed the foam with 3M. Still doesn't matter?
Phil
Old Aug 05, 2001, 10:53 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Nope, it will still do the job. Just apply tape as usual..
..a
Old Aug 06, 2001, 11:01 PM
Desert Joey is offline
Find More Posts by Desert Joey
Joined Jul 2001
deleted
Desert Joey is offline Find More Posts by Desert Joey
Old Aug 07, 2001, 02:35 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
It makes the tape stick MUCH better and does nothing to strengthen the foam - try flexing it before and after spraying with '77, no difference. It does make the tape a little easier to remove, however, as the tape tends to pull off the adhesive, and not the foam itself.
..a
Discussion Does anyone still use 3M adhesive transfer tape? rogerflies Thermal 4 Apr 05, 2006 06:34 AM
3M adhesive & radio question zeenon Foamies (Kits) 2 Jul 22, 2002 10:11 PM
