Old Sep 04, 2004, 07:15 AM
crudpuppy is offline
Find More Posts by crudpuppy
high tech redneck
Greenville, SC
Joined Feb 2004
which way does a motor pul
I think I mounted this motor wrong I gave it down and right....isnt it that the motor will natually pull up and right???
crudpuppy is offline Find More Posts by crudpuppy
Old Sep 04, 2004, 08:03 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Mounting with a little down thrust and right thrust is perfectly normal (assuming it's not a pusher). Not all models need either down or right but I don't think I've ever met one that needs left .
Steve
slipstick is offline Find More Posts by slipstick
Old Sep 04, 2004, 08:23 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Under power there will be a tendency for the aircraft to climb - hence the need for ~3 degrees downthrust.
Now to the "right thrust":
Look at your aircraft head on - the prop will be turning counterclockwise won't it. Every action has an equal and opposite reaction - thus the aircraft will have a tendency to roll clockwise, as an opposite reaction to the centripetal force exerted by the counterclockwise turning prop. Rolling clockwise will drop the left wing, thus instigating a left turning action - giving the motor ~3 degrees right thrust will balance out this left-turn tendency.
Physics 101 - I hope you can understand this ill-expressed explanation!
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 04, 2004, 08:42 AM
high tech redneck
Greenville, SC
Joined Feb 2004
Thanks guys. I got it now.
Old Sep 04, 2004, 01:21 PM
Bill Mixon is offline
Find More Posts by Bill Mixon
Bill Mixon's Avatar
Georgia
Joined Mar 2002
A motor only pulls in the direction it's pointed. (With the exception of gyroscopic procession) Other pitch yaw issues are airframe related.
This is dependent on the aircraft, but a right offset is only used to counter slipstream spiral, and P-factor.
If the aircraft is setup with 0 right thrust, and is flying relatively straight adding 3 degrees of right will only cause the aircraft to yaw to the right with power.
At flying speeds the wings provide such a stabilizing force that torque is a minor factor to consider. A slight right aileron trim may be needed though.
I must stress that the type of model makes a huge difference in how you look at offset.
Bill Mixon is offline Find More Posts by Bill Mixon
Discussion Motor - Which way does it turns? truestorys Electric Sailplanes 10 Jun 08, 2006 03:37 PM
Overlord - which way should motor turn? borgs Flying Wings 2 Sep 15, 2005 05:48 PM
Which way does it go? Prop pins crashsiegel Electric Sailplanes 4 Mar 06, 2005 09:37 PM
Which way does it point...? naX Batteries and Chargers 4 Jul 14, 2004 04:25 PM
