(link to foam wing construction) Quote:
Actually, a fellow modeler gave me the motor/gearbox/prop I want to design around - also, I want something that'll fly in my backyard - something I can toss off the 14 foot tall deck which is just outside my kitchen door. Here's the drivetrain (& I realize this'll be a slow flying plank): Speed 300 gear drive with 11" prop 2100 3 cell lippo's (the only batteries I have avail) 2 HS-55's for elevons So, I was thinking about something in the 36" range with a nearly flat bottom wing to haul around the 5 oz battery. Covering & c/f spar will be omitted . . . who needs 'em? Impacts are much more entertaining & violent without that stuff. I guess I could spray paint some artwork on the thing but my goal is to have a two hour wing - from first cut of foam to tossing it off my deck - two hours tops. I think it can happen - I'm going for it!
I only build and fly planks I prefer eppler sections over clack y but if you want to see photo's here's our hompage
http://swenban.rchomepage.com/ and its not a commercial site lol |
Latest blog entry: 4 days
I've just found the link to the post about the Zippy if anyone wants to take a look.
http://www.rcgroups.com/forums/showthread.php?t=250921 |
You've not heard about Profili? How many Eppler's would you like? 100, 200? How about NACA and any others you can think of. This program has at least 2000 sections. It's a superb tool to have. You can download a simple version or buy the full one (and unusually, it's worth it!)
Look for some reflexed ones and build the stability in. MH52 is good. http://www.profili2.com/ |
here's a link to any section you want
http://www.aae.uiuc.edu/m-selig/ads/coord_database.html |
dont need it
Happy flyin' & for the United States folks, happy Labor Day, Buzz |
Here's an idea I had for a plank - the airfoil is sort of based on the Zagnutz shape, 36" x 9" (including 1 1/4" for elevons). The pod below the wing houses the lipo battery - does it seem like using an HS-55 for each elevon would work, or do I need to use larger servos like HS-81's?
Again, my plan is to design something that flies well with a total of two hours of building. |
| Thread Tools | |
| Discussion Clark Y airfoil in dxf or dwg format? | magic612 | The Builders Workshop | 22 | Mar 18, 2012 10:26 PM |
| Help! Clark Y X S7055 - Wich One????? | CESARNOGUEIRA | Modeling Science | 3 | Jan 16, 2003 09:07 AM |
| Clark Y X S7055 - Wich One????? | CESARNOGUEIRA | Scale Electric Planes | 2 | Jan 13, 2003 07:58 AM |
| CofG / Clark Y help | stuartaw | Power Systems | 5 | Oct 08, 2001 05:50 PM |
