Old Jul 31, 2001, 08:16 PM
Mike C is offline
Find More Posts by Mike C
Mike C's Avatar
Roxboro, NC U.S.A.
Joined Sep 2000
Can't get loopy
I have been trying to loop my T-52 without success. I dive at full power, pull back on the elevator and it starts to loop, but then it will fall out to the side of the loop as it goes over and goes into spin. Any ideas? Just more practice?
I was in the yard tonight and heard that familar drone of a glow engine. Went down the road and met a guy with a Cub. He was doing some wild acrobatics, we talked and he offered to let me fly his plane. I said thanks but no thanks since I didn't want to destroy his plane! amazing to watch that power.
Mike C is offline Find More Posts by Mike C
Old Jul 31, 2001, 11:16 PM
Paul Penney is offline
Find More Posts by Paul Penney
Senior Member
Paul Penney's Avatar
Ancaster, Ontario, Canada
Joined Nov 2000
mike, fight the temptation to convert.resistance is futile. you will be assimilated (again)
Paul Penney is offline Find More Posts by Paul Penney
Old Aug 01, 2001, 12:50 AM
Mitch G is offline
Find More Posts by Mitch G
Mitch G's Avatar
Naperville, IL USA
Joined Nov 2000
What's your powertrain?
Is it direct drive or geared?
I can loop mine running a 6V sp400, 2.3:1 GB and 9x6 prop on 8x600AEs.
Mitch
Mitch G is offline Find More Posts by Mitch G
Old Aug 01, 2001, 01:13 AM
Terry T is offline
Find More Posts by Terry T
Bend Oregon USA
Joined Mar 2001
Mike,
Try less elevator throw. Sometimes, the symptoms you describe are caused by too much throw. Try your loop with less & see what happens. Might not be the cause with a slowflyer, but worth a try.
Regards,
terry T
Terry T is offline Find More Posts by Terry T
Old Aug 01, 2001, 10:19 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Mike,
1. Tell us how much the elevator moves up with full up (measured at rear edge of elevtor)? Neutral = 0", full up = ?"
2. With the RX and TX on, is the elevator neutral or pointing up or down?
3. Where is the cg? Does the plane glide well if tossed without power?
4. What motor/prop/gearbox/battery are you using?
Mine will loop from level flight.
hoppy
hoppy is offline Find More Posts by hoppy
Old Aug 06, 2001, 02:02 PM
crashnburn
crashnburn
Guest
n/a Posts
Is your c.g. ok??
Sounds like it's noseheavy.
Old Aug 06, 2001, 08:09 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Mike must have looped out of the zone
hoppy
I can't get Matt Clements cable to work, any ideas? smshaffer Beginner Training Area (Aircraft-Electric) 13 Jul 20, 2002 03:00 AM
Can't get Tango motor for Logo 20 tdollmeyer Electric Heli Talk 2 Apr 30, 2002 06:02 PM
Can't Get The Corona To Start? drbird Electric Heli Talk 18 Mar 27, 2002 02:46 PM
Can't get the smile off my face... (aerial video) joemi Electric Plane Talk 4 Nov 17, 2001 10:06 PM
Can't Get Zagi 400-X Motor to Start mpj220 Foamies (Kits) 8 Jul 31, 2001 10:26 PM
