Old Feb 05, 2002, 01:03 AM
Ulrich Dick is offline
Find More Posts by Ulrich Dick
Comox B.C Canada
Joined Feb 2002
Dhc-2 Beaver
I have converted the dumas DHC-2 kit to electric and am quite pleased with the results!
My current project is the same plane just enlarged 200% to give it a span of 60 inches and an area of 405 inches.
I have two questions
1 if want to use ailerons can I use the stock airfoil or is there a better choice?
2 what is a good rule of thumb for the tailplane angle?
Ulrich Dick is offline Find More Posts by Ulrich Dick
Old Feb 05, 2002, 01:33 AM
YVR is offline
YVR
Find More Posts by YVR
YVR
Sean in YVR (Vancouver)
YVR's Avatar
Vancouver, BC
Joined Sep 2001
Looks great! I like the Harbour Air livery selection - you're going to need some floats on that baby. Have you flown it yet?
YVR is offline Find More Posts by YVR
Old Feb 05, 2002, 10:51 AM
Rudderman98 is offline
Find More Posts by Rudderman98
AMA 670207
Rudderman98's Avatar
United States, WA, Sumner
Joined Oct 2000
Beautiful job!
What power system are you using?
Perry
Rudderman98 is offline Find More Posts by Rudderman98
Old Feb 05, 2002, 08:10 PM
Cadet is offline
Find More Posts by Cadet
Confirmed Adict
Cadet's Avatar
Malahat, BC, Canada
Joined Jan 2001
Gee do you live around here, or did you just see that livery in a book? I think my friend might need to build one of these anyone know where to get the plans.
Cheers,
Grant
Cadet is offline Find More Posts by Cadet
Old Feb 06, 2002, 08:07 PM
sblack is offline
Find More Posts by sblack
Scott Black, Montreal
sblack's Avatar
montreal quebec Canada
Joined Sep 1999
The stock airfoil should be fine. It cries for flaps! Also, 0 deg should be fine on the stab if you don't put the cg really far forward - there is no need to.
If you go for ailerons, don't forget to take out most of the dihedral. Scale is around 2 deg - you don't want more than that.
Nice work.
sblack is offline Find More Posts by sblack
Old Feb 06, 2002, 10:41 PM
Comox B.C Canada
Joined Feb 2002
Thanks very much for the compliments.
Here are the specs
2 HS 50 servos
JR 610M rx
EPU6 motor wit 5.9/1 gear
8/4.7 prop
7 cell 270 mah nimh
all up weight 205g/7.2oz
rog no problem wit 10 min flights aprox
DHC-2 Beaver appen Scale Kit/Scratch Built 0 May 30, 2004 01:49 PM
For sale: Parts from a DHC-2 Beaver David Hunt Aircraft - Electric - Airplanes (FS/W) 2 Sep 15, 2002 10:11 AM
GWS DHC-2 Beaver Horizon Vendor Talk 1 Jul 02, 2002 05:18 PM
GWS DHC-2 Beaver Horizon Vendor Talk 0 Apr 08, 2002 02:44 PM
Dhc-2 Beaver Ulrich Dick Parkflyers 10 Feb 27, 2002 05:47 PM
