Old Aug 04, 2001, 09:49 PM
parkcityskier is offline
Find More Posts by parkcityskier
Parkcityflier
parkcityskier's Avatar
Park City, UT, USA
Joined Aug 2001
Brushless motors, ESC connection
I recently purchased my first brushless motor, a Hacker B20-18L. It has 3 black wires at the back of the motor. My ESC has red, white and black wires. Does it matter which wire goes to which black wire on the motor? I suspect that reversing the black and red wires on the ESC will affect the direction of rotation. How about the white wire? The instructins were pretty non existant.
parkcityskier is offline Find More Posts by parkcityskier
Old Aug 04, 2001, 11:35 PM
fisher is offline
Find More Posts by fisher
Joined Apr 2001
Welcome to the E Zone!
If the controller is sensorless just hook them up. If the rotation is backwards, swap any 2.
-fish
fisher is offline Find More Posts by fisher
Old Aug 05, 2001, 06:29 PM
Parkcityflier
Park City, UT, USA
Joined Aug 2001
Thanks for the answer. I figured that it must be something simple. I've got another one for you: Hacker says don't solder the connectors to any of the black wires (use crimp on). Why is this? Possible wicking up the wire or heat damage to the motor? Thanks.
Old Aug 05, 2001, 10:52 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Crimping is as good as solder, IF you have the right tools. A good crimper is $100+
..a
Old Aug 05, 2001, 11:00 PM
RedLine is offline
Find More Posts by RedLine
NE Ohio
Joined Apr 2001
..yeah but.. why can't they be soldered?
RedLine is offline Find More Posts by RedLine
Old Sep 16, 2007, 01:55 AM
redykilowt is offline
Find More Posts by redykilowt
Rodney
Salt Lake City Utah
Joined Sep 2007
electronics soldering
when soldering electronice things you need to be good at soldering in the first place...then use a HEAT SINK between the solder joint and the device..the heat sink is an aluminum allegator clip made to absorb heat..use a small pointed solder pencil and thin rosin core solder.
If possible make the connection a good mechanical connection ( twist the wires together first ) then a good electrical solder connection... it only needs enough solder to flow and have capillary action suck the solder into the connection
redykilowt is offline Find More Posts by redykilowt
Old Sep 16, 2007, 09:03 AM
BD Flyer is offline
Find More Posts by BD Flyer
BD Flyer's Avatar
United States, NJ, Monroe Township
Joined Aug 2006
Just so you know, this thread is 6 years old...
BD Flyer is offline Find More Posts by BD Flyer
Old Sep 16, 2007, 09:34 AM
Stan Richardson is offline
Find More Posts by Stan Richardson
Old Bold Pilot
Stan Richardson's Avatar
Holiday, Fl. USA
Joined Apr 2007
Question
And still good. I've pretty well checked all the threads relating to new Electric R.C.ers and I find you guys are here to help. And so the question: I have a J.R. SX 600 which works good. I'm trying to convert my Hobby-Lobby Decathlon 480 to use it. Can you recommend a good receiver, RSC, and servos which will not be too HEAVY for my little (21.5 oz.) foamy? Thanks,
Stan
Stan Richardson is offline Find More Posts by Stan Richardson
Old Sep 16, 2007, 09:45 AM
BD Flyer is offline
BD Flyer's Avatar
Joined Aug 2006
Stan
Hi Stan,
Here's a list of electronics that will work with your JR Radio:
Receiver - Castle Creations Berg 4 along with one of these crystals (you have to get one that matches your radio... for example, if your radio is on channel 40, you have to get a channel 40 crystal)
RSC - I'm not sure what a RSC is. Do you mean ESC (Electronic Speed Control)?
Servos - Hitec HS-55's will work fine.
Old Sep 16, 2007, 09:53 AM
Old Bold Pilot
Holiday, Fl. USA
Joined Apr 2007
bad typing
Hi Stan,
Thanks for the quick reply. Yes, I meant ESC.
In the future I'm staying with this thread. (read my blog)
My other plane is a Hangar 9 P-51 P.T.S which I'm staying on the buddy box until I'm profficient. I love it. (and the JR tx.)
Old Sep 16, 2007, 09:57 AM
BD Flyer is offline
BD Flyer's Avatar
Joined Aug 2006
Okay, you will have to upgrade your ESC only if you're going to use a different battery. So, are you going to be using a different battery? Also, are you going to be using a different motor?
Old Sep 16, 2007, 10:10 AM
Old Bold Pilot
Holiday, Fl. USA
Joined Apr 2007
upgrade
Thanks again. You're doing good at showing me what questions to ask. I'm going to stay with the 480 motor 'til I wear it out. It came with 8 cell 9.6 V NI-MH battery, which does a good job (10 min. flights) but the ESC doesn't seem to like my JR. (yes I hooked it up by the Jr locations)
Stan
WANTED: Brushless Motors/ESC meteor Aircraft - Electric - Airplanes (FS/W) 0 Jul 07, 2003 10:25 AM
Brushless motors and ESC on Ebay neilo Aircraft - Electric - Airplanes (FS/W) 0 Jul 01, 2003 10:55 PM
Brushless motors and ESC FS bruff Aircraft - Electric - Airplanes (FS/W) 0 Feb 05, 2003 06:30 PM
Brushless Motors, ESC, and kits FS bruff Aircraft - Electric - Airplanes (FS/W) 2 Oct 25, 2002 11:00 AM
