Old Feb 04, 2002, 08:34 PM
hnearnest is offline
Find More Posts by hnearnest
Louisville, KY, USA
Joined Jan 2001
other kyosho motors any good for helis?
Has anyone tried any other kyosho motors besides the magnetic mayhem or atomic force? I am debating on trying the 17 atomic force or the 14 turn krpton Krystal in my corona. I have read some post that people had luck with atomic force and others stating that it did not have enough power to get the heli off the ground.
thanks Nathan
hnearnest is offline Find More Posts by hnearnest
Old Feb 04, 2002, 11:09 PM
gstew is offline
Find More Posts by gstew
Columbus, MS, USA
Joined Oct 2000
Atomic Force has a Kv (rpm/volt) of around 3500, Krypton Krystal is about 4400. This means you'll have to use a much smaller pinion with the KK... I haven't done the math (I don't even know the main gear tooth size on an LMH), but you may not be able to use it effectively.
Atomic Force works. If you can't get an LMH or Corona off the ground with one, either the motor is bad or you have a problem somewhere else in your system.
Greg in Minneapolis
gstew is offline Find More Posts by gstew
Old Feb 05, 2002, 11:32 PM
CryHavoc is offline
Find More Posts by CryHavoc
UAS Pilot - FAA# *******HRK
CryHavoc's Avatar
United States, TX, Copperas Cove
Joined Apr 2000
Nathan,
At the time I couldn't get an Atomic Force so I bought the 14 turn Krypton Krystal for my Corona. I ended up with a 9 tooth pinion and its been working well on 7 and 8 cell 2000mah packs. The 8 cell pack gets the motor a little hot though.
Hope this helps,
CryHavoc is offline Find More Posts by CryHavoc
Old Feb 06, 2002, 10:44 AM
gstew is offline
Columbus, MS, USA
Joined Oct 2000
Ok, ok, I now stand corrected. It's good to know another combo for the LMH.
Later!
Greg in Minneapolis
Discussion Eflite S75 - any good for these helis? julianb Micro Helis 3 Dec 28, 2005 05:23 PM
RC Car Motors & Batteries...any good for Planes? park-n-fly Electric Plane Talk 17 Apr 26, 2005 12:24 AM
"Nippy Black" brushless motors, any good for 3D? Thomas Manson 3D Flying 9 Nov 25, 2003 08:03 AM
Jeti Phasor brushless any good for EDF??? MartinL Electric Ducted Fan Jet Talk 4 May 23, 2001 09:14 PM
