Old Sep 01, 2004, 10:58 AM
Eljimb0 is offline
Find More Posts by Eljimb0
ni'ihau
Joined Nov 2003
Originally Posted by Mr DIY
Ok .. now I am lost. I am getting mixed responces. Some people give me the immpression I am correct and others not. Regards Rons remarks, I am not sure what he is saying or who he is agreeing with. I thought my pics solved all of this. I will now drop this subject once and for all.
Brian
Brian,
Please don't let this go away. I am flabbergasted how Ron has danced around this topic. It could have been worked out weeks ago with one simple answer.
One clear winding diagram.
thanks,
jimbo
Eljimb0 is offline Find More Posts by Eljimb0
Reply With Quote  (Disabled)
Old Sep 01, 2004, 11:05 AM
Eljimb0 is offline
ni'ihau
Joined Nov 2003
Waiting for Ron...
There is an old saying we use here in the west. "S or get off the pot"
Which wires to which
aloha,
jimbo
Old Sep 01, 2004, 12:39 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Simple, I don't have a drawing and I don't know it of the top of my head. And heavy thinking has not been my priority these last two months. Something else on my mind, sorry.
Groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Sep 01, 2004, 03:43 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
Y Connection
A diagram isn't necessary. Its been stated many times that you connect the 3 starts together and the 3 ends to the ESC for Y. That's all there is to it. Since we are winding our own motors it should be simple to keep track.
If you have to have a diagram Gertjan has one:
http://www.solcon.nl/gjkool/brushlessE1.html
Rick.
rpage53 is offline Find More Posts by rpage53
Old Sep 01, 2004, 03:46 PM
max.ferra is offline
Find More Posts by max.ferra
max.ferra's Avatar
Padova, Italy
Joined Oct 2002
Jimbo and Brian, please be patient: hoping to help Ron, I'll try tomorrow to post a drawing and an explanation on HOW I MAKE MY LRK's... plus the complication of parallel and series connection of the two opposite teeth
Max
Waiting for Ron...
aloha,
jimbo
max.ferra is offline Find More Posts by max.ferra
Old Sep 01, 2004, 05:20 PM
Wheazel is offline
Find More Posts by Wheazel
Tech freak
Sundsvall Midlanda, Sweden
Joined Aug 2002
When winding, does it matter from what direction i wind the stator teeth? Lets say I am going to wind 20 turns, I start at root and goes to the tip, at this time it has 10 turns.
Now I am winding back towards the root and get 20 turns when reaching the root.
Is this the correct way, or should i start at tip?
Wheaz
Wheazel is offline Find More Posts by Wheazel
Old Sep 01, 2004, 11:13 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
Wheaz
Wheazel: It makes it *neater* if you start AND end at the root. It's not vital however. It gets the winds out of the way of the other windings is all. You might discover this when doing the 3rd winding.
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Sep 02, 2004, 04:09 AM
Mr DIY is offline
Find More Posts by Mr DIY
Mr DIY's Avatar
South Africa
Joined Aug 2003
Brian,
OK .. I will not contest anything, merely make a few points this time.
Ron said…
Ron forgive me for being so blunt, bit I suspected you were not sure of the correct answer all along. It is the only explanation for your lack of decisive feedback, for which we all have the up most respect for here.
However, this post
Originally Posted by arx_n_sparx...For Wye/Y/Star it's EITHER the 3 starts OR the 3 ends that must be hooked together.
Correct Brad/arx_n_sparx/Igor (when will you make up your mind, are you schizofrenic by any chance ?), otherwise you end up with 60, 60, 240 degrees difference between the phases instead of 120, 120, 120
Groeten Ron
Is a bit up in the air. Don’t know what you are saying or who you are agreeing with. I think it may have fueled more confusion, as it would indicate that you did know something on this issue and perhaps holding back. Or maybe I am just missing the point completely.
Rage53
Have a look at the distributed Y diagram below. Your statement is contesting “5 years of German engineering” as somebody else here put it to me.
As far as my drawings go, seems nobody has taken the time to study them.
Max.ferra.
If I take your numbers and put them to a drawing via a puzzle solving exercise, I get the attached configuration. It’s the only way the pieces can fit. If this is correct, you and I will see eye to eye on this and agree with what I have being saying all along.
Brian
Mr DIY is offline Find More Posts by Mr DIY
Old Sep 02, 2004, 04:54 AM
Joined Dec 2003
Brian: It seems to me that you have a mind block about this. I'm looking at the posted diagram you put into the post above. Would you agree that ALL of the "S" windings are clockwise looking from *the outside of the stator towards the inside*? IF you continue to look at those windings *from the start*, then the other coils are CCW. Notice that the 3 "S" windings are tied together for a Y/Wye connection. As Ron said, you have to be at 120° apart on these. Ron isn't "hiding" anything; I'm glad this point came up so that we can clarify things. You HAVE to be at 120°/120°/120° or else you end up with a motor that doesn't work well.
360°/3Φ = 120°
Just my 2¢
Brad
Old Sep 02, 2004, 05:00 AM
Joined Dec 2003
IN your autocad drawing, you would hook up either 135, or 246
<edit> scratch that - there's a mistake in there - gimme a minute
Brad
Old Sep 02, 2004, 05:03 AM
Joined Dec 2003
Make it 145, or 236
Old Sep 02, 2004, 05:07 AM
Joined Dec 2003
AW, heck - just draw a center line through the middle of the rotor, and tie one side together. (I'm looking at the pic with the black background)
Brad
<edit> NOw that I look at it, same applied to the top pic with R1-3 and S1-3. Bisect the rotor, and attach one half of the leads together
Old Sep 02, 2004, 07:38 AM
max.ferra's Avatar
Padova, Italy
Joined Oct 2002
Hi all
I completed a .doc file, it's 282kb and I cannot attach it here.
So I uploaded the file on the "file" folder of LRK-torquemax mailing list.
http://groups.yahoo.com/group/lrk-to...les/max.ferra/
You need to be a member of that mailing list.
Please feel free to give any suggestion and comments.
Max
Old Sep 02, 2004, 07:44 AM
Joined Feb 2001
empty
Old Sep 02, 2004, 08:06 AM
Joined Feb 2001
... Ron forgive me for being so blunt, bit I suspected you were not sure of the correct answer all along...
Yes. It's no use telling about things that one doesn't know. In my case, the forum would explode
Other reasons
http://www.rclineforum.de (Germany)
http://forum.modellflynytt.no (Norway)
http://www.lennokit.net (Finland)
http://forum.rcdesign.ru (Russia)
http://www.svensktmodellflyg.se/forum.asp (Sweden)
http://www.rc-unionen.dk/nytforum/forum.asp?FORUM_ID=40 (Danmark)
http://www.modelbouwforum.nl (Netherlands )
http://www.miliamperios.com -> http://www.rcmaterial.com/forum (Spain)
http://www.modelisme.com/forums (France)
http://www.baronerosso.net/PNphpBB2-viewforum-f-23.html (Italy)
http://www.toflyrc.com (Italy)
http://www.indiarc.com (India)
http://www.electricflight.co.nz/modules.php?name=Forums (New Zealand)
http://www.rcgroups.com
http://www.yahoogroups.com/group/lrk-torquemax (English)
http://www.yahoogroups.com/group/moteur-perso (French)
Throw in a couple of extra (+/-50), less frequent outrunner harrassed newsgroups, mailinglists and fora and you get the picture.
All for the good course naturally
Groeten Ron
LRK and other larger homemade brushless motors t-turley Power Systems 627 Jan 16, 2006 06:07 PM
LRK and other larger homemade brushless motors, part II Ron van Sommeren Power Systems 13 Jul 19, 2005 04:18 PM
"Effecient homemade brushless motors Show Case" jlm0924 Power Systems 1 Jul 13, 2004 07:31 PM
larger homemade brushless t-turley Power Systems 10 Jan 04, 2004 01:44 PM
FW Ta 400, 4.35m, six lrk-torquemax diy homebuilt brushless motors Ron van Sommeren Scale Kit/Scratch Built 0 Jan 13, 2002 02:52 PM
