Old Dec 24, 2004, 08:25 AM
powerditto is offline
Find More Posts by powerditto
Former User
powerditto is offline Find More Posts by powerditto
Old Dec 24, 2004, 08:50 AM
KreAture is offline
Find More Posts by KreAture
Impossible? Hah!
KreAture's Avatar
Oslo Fornebu, Norway
Joined Jun 2003
I get my motorcores from kitchen appliances.
Like this one, from a foodprocessor.
It measures 38mm diameter and a whopping 41mm in thickness.
I haver drilled the center to 12mm so I can fit a bearingtube.
Based on the mass of the teeth I should be able to run up to 1.3 kW on this little baby.
KreAture is offline Find More Posts by KreAture
Old Dec 27, 2004, 04:35 PM
hover dude is offline
Find More Posts by hover dude
Daytona Beach, Florida
Joined Apr 2004
hi
i opened up an old floppy drive and found this motor. it is kinda weird though, it seems as though it is missing 3 stator poles. it is not broken but there are three poles missing for some reason. why is this. how can i use this motor.
hover dude is offline Find More Posts by hover dude
Old Jan 03, 2005, 03:31 AM
Mr DIY is offline
Find More Posts by Mr DIY
Mr DIY's Avatar
South Africa
Joined Aug 2003
Hover dude ....
I have similar stators. At a first look, everything seems OK. On closer inspection, I found the stator teath not all spaced the same around stator. Dont know why they are made like this, but useless I guess?
Brian
Mr DIY is offline Find More Posts by Mr DIY
Old Jan 03, 2005, 04:55 AM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
Bah... Tiny toy-motors
This is the LRK and other larger BL thread remember?
To get good stators, I suggest you start picking apart kitchen-appliances like food-processors. That's where I find mine.
Like the one here, it should handle over 1000 watts
(38mm diameter, 41mm thick, 12 poles.)
It's a bit of work though. Getting the stator out of the appiance, stripping all the copper off it, bolting down the stator and drilling the center to fit both shaft and bearings and then figure out a way to mount the monster...
Old Jan 03, 2005, 05:00 AM
Mr DIY is offline
Mr DIY's Avatar
South Africa
Joined Aug 2003
KreAture ... are you using those nastly 'damaged' stator blades with the balancing slots machined into them? I tend to discard them.
Old Jan 03, 2005, 10:48 AM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
I haven't used anyone of em yet...
I was considering doing so this time, but haven't decided yet.
That exact stator is just bolted down and drilled so far.
Due to the ammount of mass in the blades where they have been grinded, I was thinking it would be semi-ok. It would get different flux to the mags at those spots, but the mass in the actual coil would be the same. (It's the part of the tooth where the wire actuall goes around that is what decides the max power capability ie saturation point.)
LRK and other larger homemade brushless motors t-turley Power Systems 627 Jan 16, 2006 06:07 PM
LRK and other larger homemade brushless motors, part II Ron van Sommeren Power Systems 13 Jul 19, 2005 04:18 PM
"Effecient homemade brushless motors Show Case" jlm0924 Power Systems 1 Jul 13, 2004 07:31 PM
larger homemade brushless t-turley Power Systems 10 Jan 04, 2004 01:44 PM
FW Ta 400, 4.35m, six lrk-torquemax diy homebuilt brushless motors Ron van Sommeren Scale Kit/Scratch Built 0 Jan 13, 2002 02:52 PM
