Old Aug 31, 2004, 03:55 AM
Astro30 is offline
Find More Posts by Astro30
Astro30's Avatar
Honolulu Intl, Hawaii, United States
Joined Feb 2003
Let's see them Eolo's! Post your pic and setup here :-)
Let's seem some Eolo's, we can post pics and setups and people thinking about one or have one that has questions about hop ups or elecs, we can ask eachother here. I guess I'll start...
Eolo Pro (cf blades, boom support, cf fins come stock! )
hs-85's on ccpm
hs-81 on the tail
Gy-401 gyro, gain at 60%
Airtronics 92778 rx
Power antenna
Hacker C40 12T w/stock 16t pinion
Kontronik Jazz 40-6-18
Tail drive ball bearing mod
Quick aluminum head
Quick aluminum swashplate
3rd bearing mod
aluminum anti rotation arm
-5 to +12 pitch range
throttle % at 97% straight across
8 cell GP 3300's, About 9.5 minutes of hover and 11 minutes or so with forward flight.
Astro30 is offline Find More Posts by Astro30
Old Aug 31, 2004, 06:05 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Nice looking helicopter mine is not very good looking because its patched up after being crashed several times. I definitely need a new canopy.
RC Man is online now Find More Posts by RC Man
Old Aug 31, 2004, 11:56 AM
busted nut is offline
Find More Posts by busted nut
Winnetka, CA
Joined Aug 2004
My Set Up
Hello, My EOLO goes like this.
EOLO Pro Kit
Twist 3700 with Jazz
3S4P TP gen 1
Third Bearing Kit mod
Tail drive bearings
Metal Head
Alu Swash Quick UK
Alu Servo upper mount
Alu Mixers (center holes)
Lightend paddles (stock mounts)
Futaba 9C
DP149 Rx
3 Hitech HS 85mg CCPM
Gy 401 with 9253
Pitch range +10 >< -10
Sorry no photos yet, no camera.
This one flies great and for 25 to 30 minutes.
busted nut is offline Find More Posts by busted nut
Old Aug 31, 2004, 04:02 PM
RandyT is offline
Find More Posts by RandyT
Gardena, California, United States
Joined Feb 2004
I picked up a used Eolo R22 and am setting it up. I hovered it yesterday in fixed pitch mode and I noticed that it's tail heavy with the 8 cell battery pack in the stock position. What kind of set up is that in order to move the battery forward~? Thanks.
Randy
RandyT is offline Find More Posts by RandyT
Old Aug 31, 2004, 07:03 PM
Astro30 is offline
Astro30's Avatar
Joined Feb 2003
You need to get the battery mounts, RChover.com has them...
RCman- thanks for the compliment, let's see some pics of yours
Busted Nut- yours sounds sweet, can't wait to check it out!
Old Aug 31, 2004, 10:08 PM
RandyT is offline
Joined Feb 2004
Thanks for the 411
Randy
Old Aug 31, 2004, 10:32 PM
rcaddition is offline
Find More Posts by rcaddition
lone wolf
rcaddition's Avatar
(us military)
Joined Mar 2004
eolo r22
hacker C40-8L 14t pinion
kontronik jazz/bec dis w/4.8v nicd
hs81mg cyclic
gy401 & s9253 tail
heliup boom support
heliup 3rd bearing anti rotation
heliup cf gyro plate
heliup servo holder
lightened paddles from rc hover
aluminum paddle holders
quick mixers
quick swash
quick grips
quick head
cf fin set
boom bearing upgrade
futaba 8 ch receiver
whip antenna
tp 3s2p
ms cf blades &white cf blade from rchover
this one's going to sit on the shelf while I master the stock eolo I am flying now. I don't want to crash too soon. also I'm looking into getting a custom paint job done on one of darths canopies .
rcaddition is offline Find More Posts by rcaddition
Old Aug 31, 2004, 10:33 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
Eolo R22
hitec eclipse 7 with spectra module
carbon MR blade,
cf finset with cnc aluminum clamp
Mega 22/20/2 with B50 heatsink and CC45
berg 6 dspIII receiver
3 hitec hs85
1 hitec hs5925mg digital servo on tail with futaba 401 gyro
3rd bearing (DIY)
tail drive bearing rotor guide with bearing
tail drive bearing block (UK QUICK)
CNC Servo Holder (Heliup)
CNC swash (UKQUICK)
CNC metal tailgear box
CNC Metal HEad Block
CNC aluminum mixing arm set
battery support
heliup gyro mount and tail rotor lever has been ordered.
askman is offline Find More Posts by askman
Old Sep 01, 2004, 12:55 AM
reefer is offline
Find More Posts by reefer
reefer's Avatar
Sha Tin, Hong Kong
Joined Apr 2003
Nothig Special.
Eolo Pro.
Avoex Brushless motor
Kokam 1500HC 5S2P and Polyquest 2200 5S1P
Al. head
Al mixer
3rd Bearing mod.
Quick Al BB Tail pinion Holder
Al. swash
Heliup Gyro support
Al. Paddle holder
KS Paddle
DIY BB guides in Tail boom
Heliup CCPM servo holder
Heliup Tail support
Heliup landing gear supports
Futaba 9CHP and DP149 Rx
GY401
4 x hs-81
reefer is offline Find More Posts by reefer
Old Sep 01, 2004, 01:37 AM
buzzsaw 46 is offline
Find More Posts by buzzsaw 46
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
I'll try to remember all the add ons
Mechanics:
Eolo Pro kit
CNC head block
CNC tail box
Heliup boom brace
Heliup gear braces
Heliup mixing arms
Heliup 3rd bearing
Heliup bb tail drive
Quick UK swash plate
KSJ paddles
Aluminum padle mounts
Electronics:
3 HS-85BB(soon to be upgraded to S3150's)
GY-401
1 DS8417(to be replaced by a Volz Speed Maxx XP)
Berg 6 G3 RX
JR 8103 TX
Aveox 27/26/2, 14T pinion
CC P-80
Sbec
5S Irate 1800 packs
buzzsaw 46 is offline Find More Posts by buzzsaw 46
Old Sep 01, 2004, 02:15 AM
Astro30 is offline
Astro30's Avatar
Joined Feb 2003
Sweet Eolo's! That aluminum tail gear box is next in my sights!
Old Sep 01, 2004, 02:24 AM
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
Astro the money for the CNC tail box might be better spent on a better tail servo, before I switched to my 8417 I had an HS-81 on the tail and a full power climb out would drive the tail to the right since I put the better servo in it holds much better. Unless you suspect a problem from the plastic tail box?
Old Sep 01, 2004, 02:50 AM
Astro30 is offline
Astro30's Avatar
Joined Feb 2003
ok. no I don't have any problems with my tailbox and in fact for my sport flying, my tail holds fine with the hs-81, it does kick slightly on full climb out punches but I can live with it for now. I just think the aluminum tail box looks super sweet. I do plan on upgrading the servo in the future though, I've been hearing about this Polo4? Know when that one comes out? I'll probably get that when it does. I'm sure I'll want to upgrade the tail servo as my flying starts to get more demanding.
btw. some people have tail rotor gear box twisting, I don't thave this prob but does the aluminum tail gear box prevent this?
That dual boom support and mounts also look a lot more effective than the Eolo pro one, I may want to do that one too. Whew, too many cool goodies for this bird. This hobby just hurts the pocket
Old Sep 01, 2004, 09:26 AM
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
Ya if your after the BLING the CNC tail box has plenty of it I havent had my box twist in flight but I have had two rough landings that twisted it and broke other parts as well so I guess I would expect it to twist It is easy to get carried away with bling on the Eolo they just look so good when you get them all decked out!!
Old Sep 06, 2004, 08:10 PM
Robert Stinson is offline
Find More Posts by Robert Stinson
Ahhgh! Not ANOTHER new plane!
Robert Stinson's Avatar
San Diego, CA
Joined Dec 2001
Just got mine flying today, still needs some tweaking, but it looks to be a lot of fun...
Robert Stinson is offline Find More Posts by Robert Stinson
Let's See the 1/144's Holycow Scale Boats 7 Dec 18, 2005 07:12 PM
Post your Hornet Setup... ThomasJoehnk Micro Helis 29 Sep 19, 2005 02:28 AM
Post Your Corona Setup/Radio Mr_Bazball Electric Heli Talk 106 Sep 14, 2004 09:16 PM
Post your XBOW Setup Depdog Foamies (Kits) 3 Jan 31, 2003 05:07 PM
Post Your FROG Setup Depdog Foamies (Kits) 13 Jan 25, 2003 03:28 PM
