Old Aug 30, 2004, 11:51 PM
kevinlongisland is offline
Find More Posts by kevinlongisland
Glendale, AZ
Joined Mar 2004
What other rx's are compatible with hitec?
what other manufacturers rx's are compatible with hitec focus 6 tx?
kevinlongisland is offline Find More Posts by kevinlongisland
Old Aug 31, 2004, 01:24 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
Any PPM receiver using negative shift. Futaba for one, also you can get FMA receivers for either shift and some that are shift selectable.
Rodney is offline Find More Posts by Rodney
Old Aug 31, 2004, 01:33 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
while the focus is - shift only, note that their new offering the Optic 6 offers shift select. Keep that in mind when shopping next time.
I have an Airtronics RD8000 that shift selects and it is great to be able to use any PPm receiver.
Old Aug 31, 2004, 08:23 PM
Glendale, AZ
Joined Mar 2004
thanks guys. what does ppm mean? i got the focus 6 because there were two for sale in one auction on ebay and it was perfect because i'm ripping them apart to use for a special application and i need to steal parts from one and make some custom stuff inside, and add switches to the outside and sliding potentiometers and stuff. so i needed something cheap i wouldn't mind messing up!
Old Aug 31, 2004, 08:42 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
PPM = Pulse Position Modulation
Check here for a good read:
http://www.mh.ttu.ee/risto/rc/electr...dio/signal.htm
http://www.torreypinesgulls.org/Radios.htm
Discussion Which rx's are you confident with? mdlifcrisis Electric Heli Talk 13 Jan 06, 2007 11:44 PM
What other RX`s can be used with Ace TX`s kushal_22 Radios 5 Nov 08, 2002 12:25 AM
What other battery choices are there? temacc Batteries and Chargers 0 Sep 02, 2002 02:45 PM
Multiplex Tx Compatible with Hitec Rx & Servos? green66 Electric Plane Talk 1 Apr 22, 2002 06:34 PM
Futaba 6XHS compatible with other rx's? planecrash Electric Heli Talk 3 Jul 21, 2001 04:42 AM
