Old Feb 04, 2002, 07:43 AM
mralston is offline
Find More Posts by mralston
Woodbridge, VA
Joined Dec 2000
Sanding Formica templates the easy way!
I thought I'd share a great way to sand concave and convex surfaces the easy way!
I ripped a 1/4" wide strip off of a belt sander belt, and clamped the strip in my scroll saw. I used a worn out 120 grit belt (all I had) and it sanded very quickly and accurately....I could literally sand away half of the line on my template! Don't use too much speed or pressure because the sandpaper strip will heat up and break.
If the belt wears out, put a 1" piece of wood on the table and expose a whole new section of the belt.
Formica templates have never been quicker and easier!
Mark
mralston is offline Find More Posts by mralston
Old Feb 04, 2002, 08:06 AM
RookieOne is offline
Find More Posts by RookieOne
Michele Somaschini, Spain
RookieOne's Avatar
Madrid (Spain)
Joined Sep 2001
I use them too for my foam wings. Works fine and faster than metal templates.
RookieOne is offline Find More Posts by RookieOne
Old Feb 04, 2002, 12:57 PM
jopereira is offline
Find More Posts by jopereira
Just one more plane...
jopereira's Avatar
Lisbon, PORTUGAL
Joined Nov 2001
I also used them, in a water-jet cutting machine
But now I find an easy way too: thin ply 1/64" or 1/32" with scissors - a good combination.
jopereira is offline Find More Posts by jopereira
Question Easy way to setup ailerons Mikey-flies Parkflyers 3 Mar 05, 2002 09:33 PM
True Flaps (is there a easy way) LJH Electric Plane Talk 13 Jan 08, 2002 08:03 PM
Easy way to calculate antenna legth Skysailor Parkflyers 2 Dec 10, 2001 07:10 PM
Easy Way to Route Cutie Antenna AirVenture Electric Plane Talk 4 Dec 08, 2001 03:31 PM
Easy way to break in a .61? KMKAZE Life, The Universe, and Politics 4 Nov 24, 2001 09:00 AM
