Old Aug 30, 2004, 03:13 PM
ibopage is offline
Find More Posts by ibopage
Joined Aug 2004
Question
Help with my first T-IFO
I just finished my first T-IFO and I don't have much lift. It almost seems under powered. I went through quite a few ifo threads and people don't usually seem to have this problem. I am using the gws A motor that came with the kit along with a 950 mha lithium poly. Could it be that my motor is slanted at too much of an angle?
ibopage is offline Find More Posts by ibopage
Old Aug 30, 2004, 08:22 PM
mrfirkin is offline
Find More Posts by mrfirkin
Oh, Ho, Ho, It's Magic!
mrfirkin's Avatar
Australia, VIC, Southbank
Joined Apr 2004
G'day ibopage,
I have the same setup as you.
I know this sounds stupid, but is your prop on the right way? ie; GWS Logo on prop blades should be facing forwards.
It's a real nice bird when trimmed properly. Also, make sure your CoG is correct. A little nose heavy is better than tail heavy.
How about some pics?
Cheers,
Paul.
mrfirkin is offline Find More Posts by mrfirkin
Old Aug 31, 2004, 07:54 AM
MikeTwain is offline
Find More Posts by MikeTwain
MikeTwain's Avatar
Joined Sep 2003
The prop suggestion is the most likely culprit. In fact, I'm pretty sure you'll soon reply and report success.
If not though, you could also have a bad motor or a bad or improperly charged battery.
Apparently some of the GWS A motors are better than others and the efficiency varies somewhat.
I don't know the first thing about LiPos, but you should probably find out what voltage your pack should be at when fully charged then use a voltmeter to check them.
[EDIT: Changed paragraph about battery. Didn't see that you provided info about your pack.]
MikeTwain is offline Find More Posts by MikeTwain
Old Aug 31, 2004, 09:02 AM
Higher is offline
Find More Posts by Higher
Nashville, Tennesse, United States
Joined Mar 2004
Try setting your motor to zero angle. Most Ifo's don't need any.
Higher is offline Find More Posts by Higher
Question Help with my first built-up model Gerdawr Free Flight 18 Oct 23, 2004 08:16 PM
A Little help with my first F3B Eagle target Composites Fabrication 2 Jul 24, 2004 08:02 PM
Building my First T-IFO Suggestions/Comments? Tommy D Scratchbuilt Indoor and Micro Models 9 Jul 11, 2004 10:54 PM
Building my First T-IFO Suggestions/Comments? Tommy D Parkflyers 11 Jul 11, 2004 10:05 PM
Help with my first warbird electromonkey Scale Kit/Scratch Built 7 Feb 04, 2002 11:13 AM
