Old Aug 30, 2004, 09:27 AM
North East England
Joined Feb 2004
What electric power unit for .049 powered gliders?
Hi all
Can anyone give me a bit of advice regarding powered gliders; I have several plans for Cox .049 / 1cc diesel powered gliders which I built and flew in my 'messy fuel' days and I'd like to know what equivalent electric power units I could use. For example, one plan is for a simple 60" span all balsa built-up glider, flying weight about 16ozs or thereabouts - what electric motor/gearbox/prop would I need to fly it?
I have a few GWS EPS 300 motors with the 3.22 gearing - would this (or any of the GWS motors) be suitable, as I'm trying to keep costs down? As long as it could take the glider up to a decent height I'd be happy - I'm not looking for mega performance, I just want to get a glider up there!
Any advice and suggestions would be greatly appreciated.
Steve, North East England
Redbaron25 is offline Find More Posts by Redbaron25
Old Aug 30, 2004, 10:04 AM
Dragons, Windmills. All Same.
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Greetings,
If you can keep the AUW under 18ozs, at about a 60" span, a SP400 direct with 6x3 folder will work well, with say a Kan 950ma pack, or similar. Any heavier, or larger span, than a geared sp400 with about a 11x8 folder may be needed.
A properly setup and flown sp400 direct system with atain just about the same altitude as a geared system, and cover nearly three times the air. Instead of climbing on the prop, direct systems require you to maintain speed and climb up on the wing.
I have never tried using the 300 geared motors, although if funds are tight, it may be worth a try. As well as using a light battery pack and components.Go with what you have and try and keep everything as light as you can. And you are right, just enough power to get her up, can be a lot of fun.
Jared
jcstalls is offline Find More Posts by jcstalls
Old Aug 30, 2004, 10:47 AM
xtc
outrageously large member
xtc's Avatar
no-where near tx
Joined Feb 2004
a proven system http://www.hobby-lobby.com/skimmer400.htm
xtc is offline Find More Posts by xtc
Old Aug 30, 2004, 11:13 AM
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
Since it's mainly a glider, you would typically be looking for max thrust for the best climbing, so a geared setup with a big folding prop works best. An 8x4.5 folder on 7-8 cells would work great on your SP300 gearbox.
Pierre Audette is offline Find More Posts by Pierre Audette
Old Aug 30, 2004, 11:37 AM
Concord, MA
Joined Jun 2002
16 oz plane at 50 watts per lb = 50 watts OUTPUT motor. This is accomplished easily with a speed 400 on 7 cells. 10 amps X 8 volts times 60% efficiency is 48 watts OUTPUT, close enough. These motors cost 10-20 over here. They get less efficient as they wear out.
A 6-3 folder would be decent. I think your 300 motor geared will be a little wimpy.
BEA flyer is offline Find More Posts by BEA flyer
Old Aug 31, 2004, 09:48 PM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
When quoting watts per pound, usually we just consider input watts. That's why brushless is so impressive - the efficiency of these motors makes a big difference in performance.
..a
Old Sep 24, 2004, 11:14 AM
robbie's Avatar
Barsoom
Joined Jan 2004
what did you decide to use?
robbie is offline Find More Posts by robbie
Old Oct 06, 2004, 05:59 AM
North East England
Joined Feb 2004
Robbie - haven't used anything yet, as I put the whole 'powered glider' thing on the back burner and concentrated on a couple of sports models! I appreciate all the info though and I'll probably go for the direct drive s400 option when I eventually get round to building the glider.
Steve
Old Oct 06, 2004, 06:11 PM
Concord, MA
Joined Jun 2002
You should look at the Skimmer 400 as a kit. It flies well. They have a low wing version too. I have one. I sheeted a bit of the wing with 1/32 and capstrips and have flown it on anything from a long-can 400 to a mega 16-25 3 on 11 1700AUP sanyos. It pulled the firewall right off and was probably twice as much power as it ever could use, I think the weight was around 2-2 1/2 lbs depending on batteries. These "fully" 480n motors are pretty good for a brushed set-up. I would run a 6-3 folder and 8 or 9 1100 GP nimh
what spec power supply for Triton charger? Astro30 Batteries and Chargers 21 Jun 13, 2003 09:39 AM
What is the best power supply for a Schulze DesertRC Power Systems 9 Sep 15, 2002 01:46 AM
need calculation formula to figure out what electric motor to use in a gas powered ai slopefreak Electric Plane Talk 6 Sep 13, 2002 04:38 PM
what is the best power package for Kabriolin Ali Sport Planes 6 Jun 19, 2002 06:58 AM
Programming JR 8103 for E powered gliders franz Electric Sailplanes 3 May 06, 2001 10:48 PM
