Old Aug 28, 2004, 01:15 AM
David Smith is offline
Find More Posts by David Smith
David Smith's Avatar
United Kingdom, England, Standlake
Joined Jan 2003
Flyware data required
Can anyone help me with the data required to model a Flyware 350/20-10.5W in Motorcalc? I have been to the manufacturers website but the data is limited to size and weight.
Many thanks,
David Smith
David Smith is offline Find More Posts by David Smith
Old Aug 28, 2004, 06:05 AM
ohmite is offline
Find More Posts by ohmite
ohmite's Avatar
Eden NY
Joined Sep 2001
David,
I found a document on their website awhile back. Unfortunately it is too big to upload here. I took a screen capture of the relevant page and attached it to this post.
These are great motors, I have a 350/20/12.5w and it swings a 13x6.5 prop on 10 cells 7170rpm, 9.8V and 39.8A current. I'm using a 3s2p TP2100 pack with it now and a 12x8 prop and am getting great performance 7480 rpm 10.1V and 35.1A. Hope this helps. The table does not include no load current, I think I estimated that based on actual performance on my Motocalc entries, I used the info on page 4 for the rest.
Cheers,
-Eric
ohmite is offline Find More Posts by ohmite
Old Aug 28, 2004, 07:19 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Motocalc does not predict outrunners very well (yet?). It's pessimistic.
More Flyware info/numbers here:
ftp://213.240.180.102/
Met vriendelijke groet Ron van Sommeren
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Aug 28, 2004, 07:26 AM
Joined Jan 2003
Thanks, guys, it all helps. I have the motor mounted in the model now and just have to finish wiring the ESC to try it. It is in a Sig '4 Star', running (initially, at least) on 10 Nimh, replacing an Axi 4120/18 which required 20 cells. The same model originally flew on a .52 glow four stroke, so it is getting plenty of variety!
Cheers,
David S
Old Aug 28, 2004, 07:29 AM
Joined Jan 2003
That's a shame....all my models are flying on outrunners!
David S
Old Aug 28, 2004, 07:41 AM
Joined Feb 2001
Better a pessimistic calculator than an optimistic one.
Wilhelm Geck's calculator does a better job at it:
http://home.t-online.de/home/wgeck/
Direct link to calculator info:
http://home.t-online.de/home/wgeck/11eantrb.htm
Groeten Ron
Old Aug 28, 2004, 08:10 AM
ohmite is offline
ohmite's Avatar
Eden NY
Joined Sep 2001
David,
I think you'll be very happy with the motor in this configuration, I was getting 8 minute flights (mixed aerobatics and cruising) on 10 cell HV3000 NiMh cells. With the Lipos I'm getting two 9 min flights easily and I saved 10oz of battery weight.
For reference, I was using 1.35A for a no load current for mine and was getting pretty good agreement between Motocalc and measurements, with Motocalc accurately predicting max rpm and overpredicting current by about 2-3 amps.
The Flyware motors are real powerhouses for their size and weight. I've been trying to keep my current below 40A, they seem to like it better. It appears their effeciency drops off when you go much past it for this size.
Regards,
-Eric
Originally Posted by David Smith
Thanks, guys, it all helps. I have the motor mounted in the model now and just have to finish wiring the ESC to try it. It is in a Sig '4 Star', running (initially, at least) on 10 Nimh, replacing an Axi 4120/18 which required 10 cells. The same model originally flew on a .52 glow four stroke, so it is getting plenty of variety!
Cheers,
David S
Old Aug 28, 2004, 08:16 AM
Joined Jan 2003
Thanks again - it seems the 13x8 APC I tried was a little too big when I just tested the motor - the current overload of the ESC (60A) tripped in at full stick! Huge amount of thrust, though! A smaller prop seems a better idea than a bigger ESC, unfortunately.
David S
Old Jun 20, 2005, 01:42 AM
perttime is offline
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
I am thinking of getting a Flyware 350/15/12.5w.
Does anybody have any test data, calculations or recommendations? I am still undecided between a 10cell GP 2200 NiMH and some 3S xP LiPo. The use will be pattern style aerobatics and general flying (no 3D).
PM
perttime is offline Find More Posts by perttime
