Old Aug 25, 2004, 07:48 AM
ilufa is offline
Find More Posts by ilufa
TAIWAN
Joined Jul 2003
Digital Servo Tester / LCD Tachometer, Three in one V3.0
Digital Servo Tester / LCD Tachometer, two in one
http://www.geocities.com/ilufa/DST0.jpg
The digital servo tester have three test modes:
1. Manual mode
the PWM pulse width range from 1000uS~ 2000uS, 10uS/step with one touch neutral point (1500uS).
2 .Slow mode
take 18 second from 1000 to 2000 and reverse too, auto process 3 times
3. Fast mode
Jump between 1000 and 2000 every 0.3 second, auto process 5 times
 http://www.geocities.com/ilufa/DST_E.htm
ilufa is offline Find More Posts by ilufa
Old Aug 26, 2004, 09:00 AM
ilufa is offline
TAIWAN
Joined Jul 2003
Version 2.0 available NOW!
with more test modes, include random test
Old Aug 27, 2004, 04:50 AM
Foxy is offline
Find More Posts by Foxy
Joined Nov 2001
Nice projects there, thanks for sharing.
Adam
Foxy is offline Find More Posts by Foxy
Old Aug 28, 2004, 10:32 PM
ilufa is offline
TAIWAN
Joined Jul 2003
schematic file DST.sch available
Old Aug 31, 2004, 09:15 AM
ilufa is offline
TAIWAN
Joined Jul 2003
V 3.0
New function: receiver & transmitter test
also, speed controller test
V 3.0 Attention: one more resistor to protect the IC
Old Jan 15, 2005, 10:02 AM
ilufa is offline
TAIWAN
Joined Jul 2003
V4.33 Multi tester for R/C
PIC16F88 with ADC
16x2 LCD with backlight, Mimic bar graphic
Analog knob input
Auto propeller air speed calculator
Bi-directional power protection
Voltmeter built-in
http://www.geocities.com/ilufa/MT/index_E.htm
Old Jan 18, 2005, 09:07 AM
jperch is offline
Find More Posts by jperch
Too lazy to repair!
jperch's Avatar
Round Rock, Tx
Joined Oct 2002
Ilufa,
That is a pretty neat project you have there. I was thinking of doing something very similar to that myself. Of course, I was planning on using a Silicon Labs MCU. But that is purely academic. One thing I was thinking of adding that you don't seem to have yet. The ability to measure how much current the servo is drawing. One could put the servo into an oscillating pattern (back and forth) and then sample the current drawn by the servo. The data could be saved and sent to a PC via an RS232 port or USB port or the maximum simply displayed on the LCD display. One could also do this with a measured weight on the servo to measure the max current draw under loaded conditions. This could be very useful for determining how many servos can be used on a given BEC.
Just a thought.
Joe
jperch is offline Find More Posts by jperch
Old Jan 18, 2005, 07:17 PM
ilufa is offline
TAIWAN
Joined Jul 2003
Joe,
Certainly, this is a very good idea.
But PC programming is out of my ability. and for current measurement require addtonal Amp. circuit, make the DIY project more complicative.
Old Jan 18, 2005, 08:49 PM
FDC is offline
FDC
Find More Posts by FDC
FDC
Joined Jan 2004
Hi Ilufa,
I just noticed you're located in Taiwan. Well I'm currently on assignment in Taipei. Are the parts/components locally available in Taiwan particulary Taipei? Or dou you order them fro overseas also?
I'm keen on building one of your designs but I still don't know where the electronics part stores are located in Taipei. If you could give me some addresses of the electronics store in Taipei, I would highly appreciate it.
TIA!
FDC
FDC is offline Find More Posts by FDC
Old Jan 18, 2005, 11:20 PM
ilufa is offline
TAIWAN
Joined Jul 2003
Originally Posted by FDC
Hi Ilufa,
TIA!
FDC
Located on Bade Road, Sec. 1, Guanghua Market is the largest market for electronics and computer products in Taiwan. Whatever you need in computer equipment, or the latest electronics, Guanghua Market has it all. Prices are low and often negotiable.
But PIC16F88 may not available, you can order it from microchip web
Old Jan 19, 2005, 10:21 AM
jperch is offline
Too lazy to repair!
jperch's Avatar
Round Rock, Tx
Joined Oct 2002
ilufa,
PC programming can be a bit daunting. But the circuit to read current may not need to be very complicated. Certainly no more complicated than the op-amps used in your tach circuit. In fact, a simple differential amplifier circuit would probably be all that is needed to amplify the signal. This would give you better resolution in the on board ADC. If you like, I could probably scratch together a drawing for you. It would be up to you to test it though. Work is too crazy right now for me to find the time.
Joe
Old Jan 19, 2005, 08:24 PM
ilufa is offline
TAIWAN
Joined Jul 2003
Originally Posted by jperch
ilufa,
Joe
Joe,
Surely, If you draw, I will try to program it.
Ilufa
Old Jan 20, 2005, 08:42 AM
jperch is offline
Too lazy to repair!
jperch's Avatar
Round Rock, Tx
Joined Oct 2002
Ilufa,
Okay, give me some time. I will try to put a sketch together. What range does the ADC on your PIC controller measure?
Joe
Old Jan 20, 2005, 05:08 PM
ilufa is offline
TAIWAN
Joined Jul 2003
Ilufa,
Joe
10 Bits ADC, ref.V = Vdd or Vss or Ext
Old Jan 20, 2005, 05:50 PM
jperch is offline
Too lazy to repair!
jperch's Avatar
Round Rock, Tx
Joined Oct 2002
Ilufa,
I hope this makes sense. Here is a PDF of what I drew. There is a connection labeled "To servo -". This means that instead of connecting the negative power lead of the servo to the tester's ground, you will connect it here instead. The output of the amplifier goes to the ADC input on the PIC. The value of R1 and R2 depend on the range of the ADC. If you are using VDD as the reference, then the range is 0 to VDD. I am assuming that is 3.3V. It also depends on how much current you expect to measure. With a 0.1 ohm resistor, a servo current of 5 amps would yield a 0.5V drop at the input of the amplifier. The gain would then need to be sufficient to amplify this to something close to the upper limit (3.3V). A gain of 6 would turn the 0.5V input into a 3.0V output. This would be very good. The equation for the gain of this amplifier is (1+R2/R1). So, if you needed a gain of 6, then R2 would need to be 5 times the value of R1. You could make R1 equal to 1k and R2 equal to 4.7k. This would give you a gain of 5.7 and you would be using resistor values that are typically available.
The op-amp is not really critical. You could probably use the LM358's that you have shown for the tach circuit. The best thing is to choose one that has a very low input current and a very small offset voltage. The other option is to calibrate out any error.
The idea of this circuit is that the current drawn by the servo will flow back through its negative lead. Since the op-amp has a very high input impedance virtually all of this current will flow through the 0.1 ohm resistor. This will create a voltage that is proportional to the current flow. You then use the amplifier to scale that voltage up to use as much of the range of the ADC as reasonable for best performance. Then you simply read the voltage with the PIC and then convert the reading into a current.
I hope you find this useful.
Joe
Discussion SKYFORCE. TWO in ONE. Micro kit Foamy. In TRU WOW fdaremi Micro Ready-to-Fly 6 Apr 14, 2007 10:26 AM
Help! Two in one day... CSRC bal/chgr problem! WarrrEagle! Batteries and Chargers 15 Apr 03, 2007 01:47 PM
Idea About to design a new digital servo tester. What features do you want? Mikael Pedersen DIY Electronics 35 May 22, 2004 12:03 AM
Help! How not to lose two planes in one day Sloper Mario Electric Plane Talk 13 Dec 01, 2003 03:43 PM
Servo tester with digital readout Mikael Pedersen Power Systems 4 Jan 10, 2002 07:20 AM
