Old Aug 25, 2004, 12:21 AM
Anchorage, Alaska
Joined Sep 2002
Himax gearmotor 3 mm Collet Style Aluminum Prop Adapter
Anyone know any tricks to keep the collet from getting loose during flight and flying off? I've tightened it to the point I was afraid of stripping the aluminum threads but it still flys off after a while. Thanks
Bat21
Bat21 is offline Find More Posts by Bat21
Old Aug 25, 2004, 11:29 AM
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
try
a piece of 320 grade wet and dry sanding paper wrapped around the shaft and score it along the shaft not around, till you see that the high polish is well marked up, spray with some contact cleaner or similar to get rid of any sillicone from the paper and any oils, check inside the alloy bore on the prop adaptor and clean with a pipe cleaner ,when fitting the adaptor the taper should have just a oil smear and also the thread,you should find that your problem is solved , check your speed control that its set on soft or no brake, as sudden braking can make the problem worse.
olmod is offline Find More Posts by olmod
Latest blog entry: For motor builders
Old Aug 25, 2004, 11:48 AM
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
I had a problem with mine also...I believe it is a 2mm shaft on the gear. I finally fixed it by buying a 2mm collet from Hobby Lobby that has a nut.....never had a problem since.
They also have a neat kit that slips over the collet nut, then you attache a realistic looking prop Hub that looks like a Hamilton standard prop dome. real neat for war birds....or to just hide the nut.... The new collet is even tight going on...but the hub on my Himax is 2mm. I had it at the hoppy shop to make sure.
mjdee14 is offline Find More Posts by mjdee14
Old Aug 25, 2004, 03:19 PM
Joined Jun 2004
gone fishing
FRAMEDNLVS is offline Find More Posts by FRAMEDNLVS
Old Aug 25, 2004, 03:36 PM
Balsa to the Wall
Deep in the East Texas Piney Woods
Joined Dec 2001
Try a little Blue LocTite between shaft and collett.
Chuck
Chuck is offline Find More Posts by Chuck
Old Aug 25, 2004, 03:38 PM
Anchorage, Alaska
Joined Sep 2002
Hi olmod and mjdee14. Thanks for your replies. The sanding paper idea is good. My Himax gearmotor is the HG2025-4266. I measured the gear shaft diameter and it is 3.048mm (.120"). Very odd-ball. Even more odd-ball is the prop shaft diameter of 4.674mm (.184"). The length of the prop shaft is such that a props hub thickness can't be much over 1/4 inch. Most GWS props have a hub thickness of 9/16". Oh well. I checked the Hobby-Lobby website and they don't have any prop shaft adapters for 3mm shafts. 3.2mm was the closest.
Bat21
Old Aug 25, 2004, 08:43 PM
olmod's Avatar
Joined Apr 2004
Try www.ecubedrc.com they have them for most i had to buy some recently myself.
Old Aug 30, 2004, 09:15 AM
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
On another post someone had the same problem...and they called Max products...they sent out another collet. I just called and they are sending me another one also...
I haven't measured the shaft...and you may be right its probably 3mm not 2 like I thought...but Hobby Lobby had one in stock that fit perfectly and tightens down great. It may not be in the catalog...as the guy at the counter (I live right by them) gave me. it must have been the 3.3...it was too loose..he came up with 3mm (I guess) and it fit great...
I need to see if I kept the package.....and I might be able to give you a part number...
I'll look when I get home.....
Old Aug 30, 2004, 03:51 PM
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
Just measured the shaft and it is 3MM...I got new 3MM from Hobby Lobby and it works great , has a nut instead of the dome screw. i also called Maz producxts and they are sending me another collet..
Old Sep 02, 2004, 10:44 PM
huck328's Avatar
Chicago
Joined Jul 2004
Thanks olmod! I got my first Himax motor and APC props last week and I've been trying like nuts to get the adapter that comes with the Himax to get tight on there. The sandpaper trick worked like a charm.
huck328 is offline Find More Posts by huck328
Old Sep 02, 2004, 11:53 PM
Joined Jun 2004
gone fishing
For Sale 30 mm aluminum spinners with 3 mm collet Ted U Aircraft - General - Miscellaneous (FS/W) 1 Aug 20, 2006 07:04 PM
Discussion Where can I find a set-screw style 3mm prop adapter? PerfectStranger Electric Plane Talk 3 May 05, 2006 05:39 AM
Sold F/S Himax 2025-3200/ GWS GB/Mount Saver/Prop adapter combo Aobid Aircraft - Electric - Power Systems (FS/W) 4 Dec 13, 2005 07:08 AM
30mm spinner w/2.3 mm collet...can it be drilled to 3.2mm??? Joe Ford Electric Plane Talk 3 Jun 02, 2004 10:41 PM
Collet Style Prop Adapter or Spinner SteveR Sport Planes 3 Mar 03, 2002 10:03 PM
