Old Aug 24, 2004, 11:47 AM
Stefan lamers is offline
Find More Posts by Stefan lamers
Groningen, The Netherlands
Joined Aug 2004
depron pusher prop F16
This is my first depron model, and the material is great.
It is a scratch built depron F16 with a pusher prop. if this all goes well i wil proceed to an EDF. wings are a little oversized but look proportionally still OK.
wingspan: 70 cm
lenght: 88 cm
weight: hopefully 500 grammes or less
equipment weight (radio, brushless motor, lipo): 200 grammes
Most parts are made, the model is almost ready for painting.
Stefan lamers is offline Find More Posts by Stefan lamers
Old Aug 24, 2004, 12:35 PM
Hawker is offline
Find More Posts by Hawker
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
Stefan,
Welcome to the Ezone! That looks great! Congrats on a beautiful job. How
long did that take you, and did you do that from just a 3-view with cross
sections? Please continue to post your progress. Very impressive.
What thickness of depron are you using, 1.5mm, 3mm, or 6mm?
Hawker is offline Find More Posts by Hawker
Old Aug 24, 2004, 12:54 PM
ssyed is offline
Find More Posts by ssyed
Joined Sep 2002
VERY impressive... this should be in jets too..!! you will get a lot of interest there as well because this is very scale etc..
ssyed is offline Find More Posts by ssyed
Old Aug 24, 2004, 01:38 PM
Esprit440 is offline
Find More Posts by Esprit440
Supersonic hover
Esprit440's Avatar
Michigan, United States
Joined Sep 2003
Stefan, this looks beautiful! Your treatment of the forward fuselage underside, radome, and leading edge extensions is very smart. I'm working on an F-16 for the jet design contest with similar construction - great minds think alike I guess! Please keep us updated,
-Matt
Esprit440 is offline Find More Posts by Esprit440
Old Aug 25, 2004, 05:33 AM
Joined Aug 2004
thanks for the welcome. i will keep on posting pictures. i designed it from a 3side vieuw and after browsing the internet found some cross sections aswell. i am using 6 mm depron for bulkheads and stringers and 3 mm for sheeting.
Old Aug 25, 2004, 05:47 AM
Joined Aug 2004
hi matt
do you have more info about that jet design contest? sounds very interesting.
i added another picture from the rear structure and full flying stab detail.
The stab has a steel torque tube with a nylon tube as bearing. this is sandwiched in some balsa and the balsa will be epoxied in the rear slot.
i hope this structure is strong enough to handle flight loads.
Old Aug 25, 2004, 06:38 AM
Mr. Boogie is offline
Find More Posts by Mr. Boogie
Mr. Boogie's Avatar
Morristown, New Jersey (excl EWR), United States
Joined Oct 2003
Stefan,
Your F16 looks fantastic!
What do you estimate your AUW to be and what is your intended power system? (Motor, Prop and Batteries)
Excellent work!
Mr. Boogie
Mr. Boogie is offline Find More Posts by Mr. Boogie
Old Aug 25, 2004, 07:15 AM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Excellent! Very cool... Ya gotta love Depron
Pete
mtflyr is offline Find More Posts by mtflyr
Old Aug 25, 2004, 11:19 AM
Joined Aug 2004
thanks, the AUW is hopefully 500 grammes or less. it will have a receiver and two micro servo's. A PJS 550 brushless motor (50 grammes) and a kokam 3S 1200 mAh
battery (75 grammes). altogether the radio/motor/battery is 200 grammes which leaves enough room for the airframe. this motor battery combination is at the moment installed in a balswood 80cm, 450 grammes, Su26 aerobatic plane and it pulls it easy vertically up with a 9X4,7. ofcourse i will change the prop to get more speed instead of pulling power but still it should do.
Old Aug 25, 2004, 11:40 AM
Supersonic hover
Esprit440's Avatar
Joined Sep 2003
Hi Stefan, you can read more about the jet design contest in the electric Jets forum. There is a "sticky" post at the top that has all the rules and entry information. The entry deadline has been extended to November 1st, and the completion deadline is April 15th, 2005. Since you've already started your F-16, you won't be able to enter it - but you could enter something else using the same techniques. I hope you do!
Old Aug 25, 2004, 01:46 PM
Thomas Nelson is offline
Find More Posts by Thomas Nelson
Thomas Nelson's Avatar
Calgary, Alberta, Canada
Joined Sep 2002
Looks excellent! I'd expect your stabilator mechanism will work just fine for all scale-like maneuvers.
Thomas Nelson is offline Find More Posts by Thomas Nelson
Old Aug 25, 2004, 09:51 PM
Mr. Boogie's Avatar
Joined Oct 2003
Stefan,
I noticed that you cut out the ailerons and you obviously have full flying tail surfaces. Did you consider taileron control?
Also, how did you create the cool details in your radome?
Mr. Boogie
Old Aug 26, 2004, 01:01 AM
Joined Aug 2004
Hi mr boogie
I started this airplane before i found this inernet site and i must be honest that i never considered using tailerons only. when i saw it here it was too late and i had already cut them. I think it has great advantages, tailerons only, it saves you a lot of work. And i guess if you make the deflections big enough the roll rate should be fine.
The lighting protection strips on the composite radome (the real thing then) are 1 mm strips of balsa sanded down to make them as thin as possible.
greetings
stefan
Old Aug 26, 2004, 01:11 AM
Joined Aug 2004
the model has an aluminium 8 mm thinwalled spar (ex- arrow from my neighbour (he knows it)). it runs through the centersection to about halfway in the wing. the rest of the loads will be taken by the depron spars in the wing.
at the moment the model is still detachable but when it is finished it will be one assembly
Old Aug 26, 2004, 10:40 AM
Tomcat Fan is offline
Find More Posts by Tomcat Fan
NY, NY
Joined Jul 2004
Outstanding!!!!!
That is a fantastic looking '16!!!!!!!!!
Probably the best one we've seen in a while, quite frankly.
The most scale looking for sure.
For some reason, they all look good, but off a bit somehow.
Can't describe it but you'll see if you look in jets at the different '16 designs.
Please man, we beg you....POST PLANS!!!!!!!!
Let us know how the maiden goes b/c I think a lot of the reasons most of the'16s are "off" (I need a better description) a little bit is b/c the '16 platform is supposed to be designed to be a bit unstable, which is why they needed the fly-by-wire setup (not to mention, it sounded like a good excuse for the gov't and contractors to spend a ton of $).
Best of luck finishing her and keep us updated.
Tomcat Fan is offline Find More Posts by Tomcat Fan
new depron F16 pusher prop Stefan lamers Pusher Prop Jet Models 233 Nov 25, 2009 08:28 AM
Discussion .10 size pusher prop delta/jet depron liljoe Pusher Prop Jet Models 1 Sep 15, 2009 10:08 PM
4.5x3 pusher prop source opualuan Parkflyers 6 Oct 17, 2001 08:46 AM
pusher prop as a tractor prop ? Al P Power Systems 2 Jun 16, 2001 12:09 AM
Using pusher prop glovesave39 Beginner Training Area (Aircraft-Electric) 3 May 03, 2001 03:05 PM
