Old Aug 22, 2004, 04:49 PM
OUAndy1807 is offline
Find More Posts by OUAndy1807
You're a nerd.
Norman, Oklahoma, United States
Joined Aug 2003
Will this non-programmable ESC work for my Lipos?
I have an ESC that I want to use with my 2s 730mah TP lipo pack. It is a 10 amp, with a low voltage cutoff at 3.6v (but it's not programmable.) I should be able to use this amp and not have to worry about ruining the battery pack, shouldn't I?
OUAndy1807 is offline Find More Posts by OUAndy1807
Old Aug 22, 2004, 05:10 PM
crashingagain is offline
Find More Posts by crashingagain
crashingagain's Avatar
Sacramento
Joined Nov 2003
Ive used nonprogramable escs with my lipos in the past. All you have to do is fly your plane for a few minutes with a timer keeping track. Land and check your votage and take off again. Do this til you batteries are close to the 3 volt per cell limit and you will know how long you can fly from now on. A cheap cooking timer with alarm works well.
crashingagain is offline Find More Posts by crashingagain
Old Aug 22, 2004, 05:16 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
3.6V is not high enough to rely on the LVC. For a 2s pack, the minimum recommended cutoff is 6.0V UNDER LOAD.
You can use it but like was said above, but do it by time and not the LVC. The voltage of your 2s pack should not go below about 6.6V by the time you get around to measuring it. That is because the voltage will bounce back up after you remove the load. I'd shoot for 6.8-6.9V after the pack has rested awhile.
hoppy is offline Find More Posts by hoppy
Discussion will this part work for my honeybee? slo123 Micro Helis 11 Apr 12, 2007 12:36 AM
Help! Can anyone tell me if this will work For my Rotofly? jayb79 Micro Helis 0 May 19, 2006 08:04 PM
Alert Will edf 40H work for my micro's Tail? Duct fan tail mod haddorh Micro Helis 9 Jan 13, 2005 07:32 PM
Will this work for my shocky? Guinea_Pig 3D Flying 3 Oct 21, 2004 05:23 PM
Question Will this ESC work for my 3D plane? CactusJackSlade 3D Flying 1 Dec 30, 2003 04:23 AM
