Old Jul 08, 2006, 04:56 PM
LtDoc is offline
Find More Posts by LtDoc
McAlester
Joined Nov 2004
Erik,
Using a tug boat isn't exactly the easiest way to retrieve a boat, depending on just how you go about it. The good part is that it also provides additional 'play' time, it's fun, you can show off your 'ex-spurt-tease'... well, sort of (yeah, right). 'Jim' has it right, if it ~works~ it's the right way. That sort of limits the use of ducks, dogs, and geese, depending on the ducks dog and geese. If the fishing pole and ball work for you, good. If you wanna try it with a tug, fine. If you train the ducks and geese would you take pictures, please?
- 'Doc
LtDoc is offline Find More Posts by LtDoc
Old Jul 10, 2006, 05:07 PM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
Like LtDoc says, if it works, it wins. My favoured way if out of range of the flung tennis ball is to fix a long line to the normal towing hitch of the tug and run the line out past the stricken vessel, and then part-circle it. When resonably sure that the line has snagged the sticken one, stop the rescue boat and GENTLY pull the pair of them in.
mfr02 is offline Find More Posts by mfr02
Using Acetone as a CA debonder? Mike C The Builders Workshop 11 Feb 13, 2005 05:00 PM
using a motor as a servo? petn7 Modeling Science 4 Jul 16, 2004 12:13 PM
Please read this.....Is anyone out there using netscape as there browser? kushal_22 Parkflyers 21 Feb 27, 2003 03:26 PM
Using water as ballast? Ben74 Slope 17 Nov 06, 2002 09:46 PM
Question Using Wingo as indoor flyer? JensJakob68 Parkflyers 9 Dec 14, 2001 06:06 AM
