Old Aug 21, 2004, 06:07 PM
BIGPhutte is offline
Find More Posts by BIGPhutte
Joined Aug 2004
HPI Nitro RS4 3 Evo newbie tuning.
Hey, just got this madfast car, broke the engine in against the wall now im tuning it , I've been at it all day trying to find the "sweet spot" , somtimes it will run for 3 min, then stall, sometimes is will run for 3 secs and stall, I cant seem to get it .... ne healp would be appretiated
BIGPhutte is offline Find More Posts by BIGPhutte
Old Sep 03, 2004, 06:35 AM
NoS is offline
NoS
Find More Posts by NoS
NoS
IT Technician
NoS's Avatar
Cambridge MA
Joined Sep 2004
does the rpms go high once u start it
NoS is offline Find More Posts by NoS
Old Sep 17, 2004, 11:03 PM
NITRONORMRS4RTR3 is offline
Find More Posts by NITRONORMRS4RTR3
Philadelphia Pa/Wilm, Pennsylvania, United States
Joined Sep 2004
man I just got a rs4 rtr 3 about a month ago used and I had the same problem I tryed the book and I couldn't get it tuned so I took it to my local hobbie store and they tald me that it wasn't getting enoufe air so he turned the needle valve to closed and then turned it 4 turns man it started write up and was running sweet , I drove it and had some problems and now im back to the needle problem and I have to replace he carb because the needle has problems staying in the write spot one big mess . so I will say don't go buy the book try turning it off then 4 turns start it but dont flood it check the fuel line ,and airline for cracks ,bubbles,or proper hook up then start it it should run sweet if not trust me take it to the hobbie shop and have them teach you I LEARNED THE HARD WAY BUT THERES NORE TO MY STORY. also make sure that all your batterys are good ,and that all yourthrottle linkage is set up properly as well also make sure that the carb is 1mm at the nutral setting ,open at full throttle,and back to 1mm at full brakealso make sure theres no brake drag and its 1mm as well always try with engine off ,also check to see if air cleaneris clean and oiled properly as well .If its running good it should always emit smoke at full throttle if there is no smoke the engine is set to lean , and could be esaly damaged .also during break-in, its normal for fuel to spit out of the exhaust pipe.. If you need to know more let me know later but you should be good to go so have fun and don't let the car get away frm you about 45 out of the box.
NITRONORMRS4RTR3 is offline Find More Posts by NITRONORMRS4RTR3
For Sale SOLD!!!!!Hpi Nitro Rs4 3 Evo--like New NissanS15 Cars - Cars and Parts (FS/W) 20 Feb 15, 2007 10:43 PM
Discussion HPI RTR Nitro RS4 3 Evo good buy? IceyDicer Nitro and Glow Power Cars 9 Nov 19, 2006 08:49 PM
