Old Aug 29, 2004, 08:48 AM
bgriggs is offline
Find More Posts by bgriggs
Make something. Anything!
bgriggs's Avatar
Syracuse Hancock, New York, United States
Joined Jul 2003
Much of the fans inefficiency is due to the lack of a bell shaped inlet lip. The aair hits the flat front edge of the duct and scatters and creates all sorts of vortices. He might get a 5% increase by adding a properly formed inlet.
BTW I used to make a BD-10 kit and they do fly well. I never did get around to the BD-5. Perhaps someday.
Bill
bgriggs is offline Find More Posts by bgriggs
Old Aug 29, 2004, 12:25 PM
RNAF is online now
Find More Posts by RNAF
Κάτω Χώρες
RNAF's Avatar
The Netherlands
Joined Dec 2003
BGRIGGS,
did you make a model kit or the real life one?
Kind regards,
Dave
RNAF is online now Find More Posts by RNAF
Old Aug 29, 2004, 07:02 PM
nachman is offline
Find More Posts by nachman
Tel Aviv-Yafo Sde Dov, Israel
Joined Nov 2002
Flight test with two duct funs fail. I had to add so much weight to keep it balanced that it was just to way much wing loading (18.7 grams on 84 sq cm). I then made a simple test plane from a Bob Selman foam wing panels I had. With half the wing loading ( and probably a much better wing profile), it had enough power to fly, but still far from a good flyer. I figured out that the problem is not static thrust but poor dynamic thrust. With the fixed rotor blade angle, not much of the blade area was doing anything as the speed went up. So I decided it's time to make a real duct fun for this plane. This time taking into account all the remarks and suggestions that were made pluse some common sence and some luck. The new duct fun, when doen, will have cambered stators, twisted ( for a constant pitch ) and cambered impeller and inlet lip. And one more thing, it will be a tractor not a pusher. Alfredo you were right about it. I've just found a picture of a pusher duct fun, and saw that even with the engine mounted in front of the impeller, the stators are still behind it. The pictures are of the unfinished new fun. So far the weight of the unit went up from 2 to 2.17 grams. Blade thickness is now only 0.3 mm. Pitch of impeller is 1" . Will update when I'll have some data from this fun.
nachman is offline Find More Posts by nachman
Old Aug 29, 2004, 07:56 PM
Zeroaltitude is offline
Find More Posts by Zeroaltitude
Cheapskate freeloader!
Zeroaltitude's Avatar
Orebro, Sweden
Joined Oct 2002
Nachman, very nice project you have going here!
Ive got a question regarding the actuators. Im a total newbie at this micro-stuff, and have just bought a RTF Peanut-scale Nieuport 11 from Gasparin, so youll have to forgive me if what Im about to ask is stupid. If I understood correctly, youre planning on using magnetic actuators in the BD5, correct? Unless Im totally mistaken, this plane will need to fly pretty fast for the fans to be efficient. Wont you experience problems with the actuators having difficulty overcoming the airflow at "high" speeds?
The reason Im asking is because of something Ive noticed about my Nieuport 11. It has excellent controlauthority in normal flight, but If I try to dive it to build up speed (for a loop or similar) it will not enter a dive steeper than 15-20 degrees with full down elevator. There seems to be a maximum speed that this plane will not go beyond in a dive. The only reason I can see for this is that the actuators are unable to deflect the elevator at that speed, so the plane stabilises itself in a shallow dive.
For my Nieuport this is not a problem, actually it might even be a good thing. I just thought it might be a problem with a plane like yours, because I suspect that it will need to fly at a much higher speed.
For a faster model of more normal dimensions with normal servos, you would just get stronger servos. But how strong can you make a magnetic actuator without sacrificing wheight?
Please dont take this as "advice" or anything of that sort. Its a just question from someone with very little knowledge in this area of R/C flight.
Anders O
Zeroaltitude is offline Find More Posts by Zeroaltitude
Old Aug 29, 2004, 08:36 PM
aerogel is offline
Find More Posts by aerogel
Thanks for the Fish!
aerogel's Avatar
Land of cajuns
Joined Dec 2001
Kewl There it is the Twist...That look like it will grab some air!
Aerogel
aerogel is offline Find More Posts by aerogel
Old Aug 29, 2004, 08:59 PM
bgriggs is offline
bgriggs's Avatar
Joined Jul 2003
Originally Posted by RNAF
BGRIGGS,
Kind regards,
Dave
I made a model kit. It used a Wemotec minifan 480 and 10 800 AR cells on a plettenberg HP 220 series motor. Top speed close to 100 mph.
Old Aug 29, 2004, 09:05 PM
Pete P. is offline
Find More Posts by Pete P.
Frequent Poster
Pete P.'s Avatar
South of Boston
Joined Mar 2004
OMG! NAch- That fan unit kicks butt!!! I cant wait to see what you do with the 7mm motors! Oh, and BTW I'm buying those tomorrow! :-)
Pete P. is offline Find More Posts by Pete P.
Old Aug 30, 2004, 12:15 AM
Propjob81 is offline
Find More Posts by Propjob81
Propjob81's Avatar
Joined Apr 2004
Awesome stuff!! I have had many thought about the LRF F-16 or F-18 being made someday, maybe it will sooner than I thought.
Matt
Propjob81 is offline Find More Posts by Propjob81
Old Aug 30, 2004, 12:40 AM
Phreakish is offline
Find More Posts by Phreakish
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
I didn't see it in any of the posts... How in the world do you make these fans!??
Are these cnc'd from something, or what? I'd really like to know.
Phreakish is offline Find More Posts by Phreakish
Old Aug 30, 2004, 03:18 AM
devilscries is offline
Find More Posts by devilscries
RIP THE BRING!
devilscries's Avatar
Rhode Island
Joined May 2004
Oooooooowwwwwwwwww!!!!!!!!!!!! Ooooooooohhhhhhhh!!!!!!!!!!!!!!
devilscries is offline Find More Posts by devilscries
Old Aug 31, 2004, 08:18 PM
nachman is offline
Joined Nov 2002
I've finished the new duct fun. Big improvment over the original one.
original fun new fun
weight: 2gr 2.4gr
motor: Didel 6mm 4.5 ohms same
OD : 24mm 23.6mm , 25mm at front lip
shrood length 9.7mm 16.2mm
pitch: varies with diameter 1" constant
I'm not sure it can get much better then that with this motor on this fun size. One fun should be enough now to fly this plane.
Old Aug 31, 2004, 08:46 PM
nachman is offline
Joined Nov 2002
Anders, it's pager motor powered after all. I'm not expecting it to be a rocket. Bigger and havier duct fun powered aircraft in previews posts seems to do ok with actuators. I personaly don't have any experience with actuators, so I'll just have to try.
Zlatko, I have checked the EDF-30. Although sounds not much bigger, it is. 9W input power vs. 1.5w is one thing for example. I couldn't find the weight of that unit in their specifications to compaire.
Old Sep 01, 2004, 10:51 AM
RNAF is online now
Κάτω Χώρες
RNAF's Avatar
The Netherlands
Joined Dec 2003
Yeah, I've seen the EDF-30 too. It isn't updated for a long while so I suppose it weighs 15 grammes with 10 grammes of thrust (hahahahahaha )
Looks sweet Nachman.
Dave
Old Sep 01, 2004, 10:53 AM
aerogel is offline
aerogel's Avatar
Land of cajuns
Joined Dec 2001
nachman your work is excellent.!!!! love the heat sink : ) 3 grams is great for that size of motor.. I check out the edf 30 around the same Trust numbers I was geting On My 25mm jewls a year ago...
excellent workman ship keep it up..
aerogel
Old Sep 01, 2004, 11:45 AM
bmutlugil is offline
Find More Posts by bmutlugil
bmutlugil's Avatar
Turkey
Joined May 2002
Aerogel,
As much as I understand, 3 grams thrust was for the older fan at 4V. The thrust for the new one must be 4.8 grams at that voltage..
I don't know much about fans and thrust, but this looks very good to me - the thrust to weight ratio is greater than 2..
We must not forget the incredible craftsmanship..
Regards,
Bulent
bmutlugil is offline Find More Posts by bmutlugil
6mmFlyRC's New BD-5 Microjet jazsop Pusher Prop Jet Models 40 Dec 21, 2005 03:02 PM
Video 6mmflyrc.com's new BD-5 MicroJet Maiden Flight jazsop Electric Plane Talk 0 Dec 12, 2005 01:58 AM
Bullet and BD-5-R2 Fly steve neill Electric Ducted Fan Jet Talk 30 Sep 22, 2001 06:10 PM
BD-5 3-views? Pierre Audette Scale Kit/Scratch Built 2 Sep 14, 2001 04:00 AM
BD-5 conversion steve neill Electric Ducted Fan Jet Talk 16 Sep 11, 2001 03:14 AM
