Old Aug 24, 2004, 02:30 AM
nachman is offline
Find More Posts by nachman
Tel Aviv-Yafo Sde Dov, Israel
Joined Nov 2002
Alfredo, I've made a thrust check in pusher and tractor configuration and couldn't see any noticeble change. They are home made. From a book I have about Jet models I understand that they used pusher duct in the past but nowdays it's only tractor as you said, but all the reasons for doing so were related to the use of piston engine and not to rotors / stators configuration. Also, it says that 1/3 thrust should fly good, 1/2 thrust should have aerobatic performance and 2/3 thrust - Jet like! So I'm in the entery level now, and I just want it to fly, but I'm planing on reducing the weight.
Zlatko, I agree that one fun looks better, but right now there is no chance for it to fly with just one. Pete is going to send me some of the 7mm motors and that might make the differance. My prefferance is to use only one duct-fun.
nachman is offline Find More Posts by nachman
Old Aug 24, 2004, 03:10 AM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
Hey Nachman,
I've read about using bigger motors but I think it'll become too heavy unless they give 4-5 grams thrust:
1.2V 10 Ohm
7x 17 mm 2.78 g -->7mm Didel motor
axis 1.00mm
0.5V 3 Ohm
6 x 12mm 1.32 g -->6mm Didel motor
axis 0.80mm
I hope I am not saying stupid things hahaha
Dave
RNAF is offline Find More Posts by RNAF
Old Aug 24, 2004, 08:58 AM
aerogel is offline
Find More Posts by aerogel
Thanks for the Fish!
aerogel's Avatar
Land of cajuns
Joined Dec 2001
nachman have you done a rpm test on your funs The books I have say About the same thing I have noticed at this scale a curve in the Stators will Not help any but The Cure and angle of attack in the blade will..
I have yet to use a didel motor....just the high rpm Bit charger motors with some success.....Motors have allways been the problem
You could put a N20 or M20 Motor More weight but 3 or 4 times the Thrust
Hope you get it air born Free flight or r/c......Nice Bird
aerogel
aerogel is offline Find More Posts by aerogel
Old Aug 24, 2004, 09:28 AM
devilscries is offline
Find More Posts by devilscries
RIP THE BRING!
devilscries's Avatar
Rhode Island
Joined May 2004
omg i was drooling with one fan and i havn't checked this page sense i said that but 2 fans im in shock i don't know wat to say, that is the sexiest thing i have ever seen.
devilscries is offline Find More Posts by devilscries
Old Aug 24, 2004, 11:57 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
Surely this must be a first in model flight: A pop band having direct influence on ducted fan thrust. The Cure seems a very unlikely candidate; I would have assumed AC/DC or Aerosmith would have been more suitable. Hmmm..., maybe I should be playing Bachs "Air" to my 4.5ohm pagers to keep them from frying or read poetry to Depron to make it lighter. Think of what Dizzie Gillespie could do for 3D models.......
Michael
epilot is offline Find More Posts by epilot
Old Aug 24, 2004, 12:08 PM
RNAF is offline
RNAF's Avatar
The Netherlands
Joined Dec 2003
LOL EPILOT
I also was wondering why I saw all those capital letters
AC/DC will be good enough
Dave
Old Aug 24, 2004, 12:22 PM
aerogel is offline
aerogel's Avatar
Land of cajuns
Joined Dec 2001
LOL
so pull on your hair pull on your pout cut the
conversation just open your mouth pull on your
face pull on your feet and let's hit opening time
down on fascination street
10 grams Thrust!!!!!
Aerogel
Old Aug 25, 2004, 12:25 PM
Pete P. is offline
Find More Posts by Pete P.
Frequent Poster
Pete P.'s Avatar
South of Boston
Joined Mar 2004
Man, that thing is SO nice!! Have you thought about putting the 2 motors in a pull-push fasion one in front of the other?? I believe that'd save some space. Also, I think you can get a tad more thrust by putting the vanes in to make the airflow straight. Just a thought :-) But sexy anyway! ::licks finger, touches jet's tailfeathers:: Tssss!!
Pete P. is offline Find More Posts by Pete P.
Old Aug 25, 2004, 01:07 PM
RNAF is offline
RNAF's Avatar
The Netherlands
Joined Dec 2003
Whahahahahaahaaa that's one thing for sure!!
Good job Nachman, keep up the good work!! (and updates of course )
Dave
Old Aug 25, 2004, 03:32 PM
REVKEV6 is offline
Find More Posts by REVKEV6
massachusetts
Joined Apr 2003
hmmm with the dual motor setup it looks like it would be a good candidate to make an a10 out of....
REVKEV6 is offline Find More Posts by REVKEV6
Old Aug 25, 2004, 08:27 PM
ssyed is offline
Find More Posts by ssyed
Joined Sep 2002
Your stators are not cambered! if you camber them it will increase thrust quite a bit you can probably use a more aggressive blade angle and just sweep it near the ends, you want to keep the hub bigger so you can have the blade thicker where it meets the hub, in general hubdiam=motor diam.
have you seen the EDF-30? that is just a bit bigger than what you are doing right?
ssyed is offline Find More Posts by ssyed
Old Aug 26, 2004, 02:03 AM
nachman is offline
Joined Nov 2002
Zlatko, I've tried your suggestion and it reduces static thrust by 5%.
Ssyed, your right about everything. Cambered stators should help, but not easy to machined if done as a single piece with the shroud. How ever, camberd and twisted blades should also imrooved efficiency and are no more difficult to machined then the current flat blades. So this weekend I'm going to give a try to a better rotor design. The hub was 4mm becouse it was originaly ment for a 4mm motor. I'll make the new hub 6mm as suggestted.
I havn't seen the 30mm EDF. I'll check it out.
Thanks all for the nice comments !!!
Old Aug 26, 2004, 02:16 AM
Turbo442 is offline
Find More Posts by Turbo442
Turbo442's Avatar
North Plains, OR
Joined Nov 2003
How about a photo of the BD-10. SEXY! Got to see it fly at Oshkosh a couple of years...
matt
http://rob.com/pix/matt
Turbo442 is offline Find More Posts by Turbo442
Old Aug 26, 2004, 05:22 AM
Zlatko is offline
Find More Posts by Zlatko
My member is not
Zlatko's Avatar
Melbourne City Hlpt, Australia
Joined Jun 2004
Hi nachman,
Sorry, generally if the fan is inside a tube then the thrust is higher. I don't know.
What material did you use to machine the duct and fan? Is it acrylic?
Very good idea about a micro A-10 or a BD-10.
Cheers
Zlatko is offline Find More Posts by Zlatko
Old Aug 26, 2004, 09:41 AM
RNAF is offline
RNAF's Avatar
The Netherlands
Joined Dec 2003
LOL,
when I first saw these pics I thought about an A-10 too.
I said it too about a BD-10 in a previous reply in this thread Thanks for the pic, beautiful huh?
Dave
6mmFlyRC's New BD-5 Microjet jazsop Pusher Prop Jet Models 40 Dec 21, 2005 02:02 PM
Video 6mmflyrc.com's new BD-5 MicroJet Maiden Flight jazsop Electric Plane Talk 0 Dec 12, 2005 12:58 AM
Bullet and BD-5-R2 Fly steve neill Electric Ducted Fan Jet Talk 30 Sep 22, 2001 05:10 PM
BD-5 3-views? Pierre Audette Scale Kit/Scratch Built 2 Sep 14, 2001 03:00 AM
BD-5 conversion steve neill Electric Ducted Fan Jet Talk 16 Sep 11, 2001 02:14 AM
