Old Aug 22, 2004, 01:50 PM
Alfredo Rubio is offline
Find More Posts by Alfredo Rubio
Moderador.
Alfredo Rubio's Avatar
guadalajara, jalisco, mexico
Joined Sep 2002
WOW!!!!!! a pager fan!!!! I hope too the plane will flies very fine...my son Yhoshua built the prop version in Freeflight No-Cal, some tricky to trim, but finelly flew very fine, good luck.
Evenu Shalom Aleheim.
Alfredo Rubio
Alfredo Rubio is offline Find More Posts by Alfredo Rubio
Old Aug 22, 2004, 03:10 PM
Andybill15 is offline
Find More Posts by Andybill15
Joined May 2004
waow... does it work?
Andybill15 is offline Find More Posts by Andybill15
Old Aug 22, 2004, 04:17 PM
RNAF is offline
Find More Posts by RNAF
Κάτω Χώρες
RNAF's Avatar
The Netherlands
Joined Dec 2003
WOW GREAT JOB!!!!
I really like it! It doesn't matter if it won't fly or if it's a powered glide, I like it!
Respect 2 u
Dave
RNAF is offline Find More Posts by RNAF
Old Aug 22, 2004, 06:15 PM
nachman is offline
Find More Posts by nachman
Tel Aviv-Yafo Sde Dov, Israel
Joined Nov 2002
Dave, I surlly hope it will fly. Pete, I was looking for that motor ever since it was first posted, but they just don't import it over here. I woull'd defiantly give it a try if I had one. I added a more clear picture for the fun placment. I've tried to make everything as streemline as possible. Aerogel, I just happend to have the fun from another project. It's far from being optimize but some how it turnd out that it loads the 4.5 ohms Didel motor to it max efficiency ( not power ! ). The blades are flat and aren't even twisted. After it will fly I'll try to make a more efficient prop.
Duct Fun Data: 3v 0.21A 2.15 gr' thrust
3.5v 0.25A 2.55 gr' thrust
4v 0.28A 3 gr' thrust
so assuming a working voltage of 3 to 3.6 volts there is deffiantly a need for two funs, or maybe an M20 fun, and the plane should weight no more then 12 grams. Also, one 60mah batt. can still be used to power both.
Alfredo, you're funny Hava nagila...
nachman is offline Find More Posts by nachman
Old Aug 22, 2004, 08:38 PM
Zlatko is offline
Find More Posts by Zlatko
My member is not
Zlatko's Avatar
Melbourne City Hlpt, Australia
Joined Jun 2004
Nice work nachman,
Great detail and precision.
With your ducted fan unit, try adding a bit of tube after the fan, same diameter as the main shroud and about the same lenght. That should give you perhaps another 20% thrust ( like duct D here http://www.hoverhawk.com/amcatypes.html ). What material did you use for the fan and duct?
BTW, I love BD-5s as well. For people interested this is a good site http://www.bd5.com/ , they have a plan for a Super BD-5 .
Cheers
Zlatko is offline Find More Posts by Zlatko
Old Aug 22, 2004, 10:08 PM
Pete P. is offline
Find More Posts by Pete P.
Frequent Poster
Pete P.'s Avatar
South of Boston
Joined Mar 2004
That thing kicks butt ;-) Is beautiful!!!! All it need sit more power to zip along!!
Pete P. is offline Find More Posts by Pete P.
Old Aug 23, 2004, 04:56 AM
bmutlugil is offline
Find More Posts by bmutlugil
bmutlugil's Avatar
Turkey
Joined May 2002
Hi Nachman,
Very good and inspiring, I am sure everyone seeing this thread will have the desire to build a BD-5.. The machining is impressive as always..
Best regards,
Bulent
bmutlugil is offline Find More Posts by bmutlugil
Old Aug 23, 2004, 05:05 AM
RNAF is offline
Κάτω Χώρες
RNAF's Avatar
The Netherlands
Joined Dec 2003
I wonder how a BD-10 would do?
Nachman I have confidence in you! Good luck with your to-come-flights!!!
Keep us updated!
Kind regards,
Dave
Old Aug 23, 2004, 05:11 AM
RNAF is offline
Κάτω Χώρες
RNAF's Avatar
The Netherlands
Joined Dec 2003
Oh, I just figured something, what about your airfoil? Don't you want an under-cambered one for more effective lift? Your current airfoil looks like the standard Clark-Y which gives less lift for smaller models?
Dave
Old Aug 23, 2004, 08:45 AM
clipclop is offline
Find More Posts by clipclop
QLD, Australia
Joined Sep 2003
BD5!!!,
Is there a modeler that doesnt admire the lines ??????
You've just inspired me to finnish my speed400 version-its been hanging unfinnished for 2 yrs .
Stewart
clipclop is offline Find More Posts by clipclop
Old Aug 23, 2004, 09:19 AM
devilscries is offline
Find More Posts by devilscries
RIP THE BRING!
devilscries's Avatar
Rhode Island
Joined May 2004
thats dead sexy
devilscries is offline Find More Posts by devilscries
Old Aug 23, 2004, 01:31 PM
Moderador.
Joined Sep 2002
Thanks Nachman you posted in the tech datta you got a max of 3 grams in thrust, do you can tell me the BD-5 total weight?
Ruaj Aleheim
Alfredo Rubio
Old Aug 23, 2004, 07:31 PM
nachman is offline
Joined Nov 2002
I've made another Duct-fun with a counter rotating prop this time. So now it has about 4 to 6 grams total thrust for a 14.5grams plane. I'll check how it flys over the weekend with throtle only and then it will be time to re-do the airframe with lighter balsa and add some actuators ( probably 2 x 28 ohms 4mm motors).
Zlatko, I'll check what you sugested and add it if it helps. Another 20% is a lot.
Dave, the airfoil is the same as the one on the original rubber power plans, and I have no idea what it is, but seems to be working well on this plane. It doesn't need to glide fast to stay in the air.
Old Aug 23, 2004, 08:32 PM
Moderador.
Joined Sep 2002
The guys who knows about edf planes said the thrust mus to be the 50% of the total weight, and I noticed you put the motors in pusher configuration, if you let me to say, maybe is better in tractor configuration, because the stators (the fixed blades) working cleaning the flow, I mean in a stight flow and not turbulence, this is wath makes a fan eficient, I have a FF BD-5 plan too and the wing profile is flat bottom, I did a search in google about the BD-5 and a custom plane has 2 jets in fuse sides as the Learjet!!!
where do you get this tiny fans?
Regards.
Alfredo Rubio
Old Aug 23, 2004, 08:49 PM
Zlatko is offline
My member is not
Zlatko's Avatar
Joined Jun 2004
nachman,
One fan was very nice and looked good, but now you are just showing off . If you can make one that nice than you are good, if you make 2 then you are better, if you make more we WILL buy them ) ... PLEASEEEEE!!
Alfredo is correct but that will change the balance, but then again you did put 2 fans on it . A quick way to test my sugestion is to make the duct from paper and tape. I am currious to see by how much the thrust is improved.
Cheers
I didn't even see the "counter rotating props" bit, I was too buissy looking at them. NICE!
6mmFlyRC's New BD-5 Microjet jazsop Pusher Prop Jet Models 40 Dec 21, 2005 03:02 PM
Video 6mmflyrc.com's new BD-5 MicroJet Maiden Flight jazsop Electric Plane Talk 0 Dec 12, 2005 01:58 AM
Bullet and BD-5-R2 Fly steve neill Electric Ducted Fan Jet Talk 30 Sep 22, 2001 06:10 PM
BD-5 3-views? Pierre Audette Scale Kit/Scratch Built 2 Sep 14, 2001 04:00 AM
BD-5 conversion steve neill Electric Ducted Fan Jet Talk 16 Sep 11, 2001 03:14 AM
