Old Aug 21, 2004, 10:11 AM
Jonathan Barnes
Jonathan Barnes
Guest
n/a Posts
Elliot drills any good ?
I'm replacing my meddings pillar drill with a small bench drill for my
little jobs, and I'm thinking of buying an old Elliot Progress drill for my
larger jobs.
Does anyone on this group have any experiance of, or opinions on, these
drills ?
Jonathan
Barnes's theorem; for every foolproof device
there is a fool greater than the proof.
To reply remove AT
Old Aug 21, 2004, 12:11 PM
Bob Minchin
Bob Minchin
Guest
n/a Posts
Re: Elliot drills any good ?
Jonathan Barnes wrote in message ...
>larger jobs.
>drills ?
>Jonathan
>To reply remove AT
We have an old Progress drill in the lab at work. Been going strong for the
last 30 years to my personal knowledge.
5 speed change via stepped pulleys and hi/lo backgear.
The backgear got quite noisy about 20 years ago and I stripped it down but
could not see anything obvious. I refilled the gearbox with the heaviest
gear oil we had in the stores and it has been fine ever since.
The quill oil seal leaks a bit and tended to give the first user each day a
horizontal stripe across the chest of his shirt.
I mounted an inverted tuna fish tin on the underside of the quill above the
chuck Now any oil slung out hits the inside of the tin and drips on the
table which is easily cleared up and does not get us in trouble with our
SWMBOs
I'd have no doubts about buying one
BTW they weigh between half and one hernia each so do get help shifting it.
The geared head is the heavy bit and so also do bolt it down to the bench.
Don't leave this detail as a roundtoit as I doubt that you will be able to
catch one as it topples.
Good Luck
Bob
Peter A Forbes
Peter A Forbes
Guest
n/a Posts
On Sat, 21 Aug 2004 15:38:50 +0100, "Jonathan Barnes" <jbarnes@ATnetcomuk.co.uk>
>larger jobs.
>drills ?
We have an Elliott Progress 3A, and apart from its weight, it is a VERY good
machine tool. Unless yours has been seriously misused, it should give you years
of service. Most wearing parts like bearings are easily replaced, I have a
parts list for the 3A but not for any other models.
Peter
Peter & Rita Forbes
diesel@easynet.co.uk
Engine pages for preservation info:
http://www.oldengine.org/members/diesel
Old Aug 21, 2004, 02:11 PM
Peter A Forbes
Peter A Forbes
Guest
n/a Posts
On Sat, 21 Aug 2004 17:51:44 GMT, "Bob Minchin" <bob.minchin@OEnewsreader.com>
>Good Luck
>Bob
I'd second that! The base is not that big and the machine is very top-heavy if
it starts to go over, so watch what you are doing. I still haven't got mine
bolted down yet as I have machinery to move round first, but Bob's warning is
quite correct.
Factory picture of the 3A is on our site at:
http://www.oldengine.org/members/die...d/Elliott1.htm
Peter
Peter & Rita Forbes
Pico Line Tx - any good? staib Electric Plane Talk 1 Jun 30, 2001 09:45 AM
Any good electric shops in Daytona?? David Hogue Electric Plane Talk 0 Jun 08, 2001 09:47 PM
Hear any good comments from by-standers? jas_Qfix Electric Plane Talk 28 Jun 07, 2001 07:19 AM
