Old Aug 21, 2004, 04:11 AM
Les or Gypsy Stockley
Guest
n/a Posts
Futaba S9650 Servo
http://www.servocity.com/html/s9650_mini_digital.html
The specs look good, anyone using these and can give me first hand reports.
Looking to use it on v tails for an F3B model.
Cheers, Les.
RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off.
Old Aug 21, 2004, 02:11 PM
Darwin Barrie
Darwin Barrie
Guest
n/a Posts
Re: Futaba S9650 Servo
Hi Les,
I have several of these in use. I have them on Flaps in a Compulsion and
Fusion and will be installing them in a new Compulsion as well. They are
fast, light and strong. You won't be disappointed.
Darwin N. Barrie
Chandler AZ
----- Original Message -----
From: "Les or Gypsy Stockley" <stockley@slingshot.co.nz>
To: "soaring" <soaring@airage.com>
Sent: Saturday, August 21, 2004 1:31 AM
Subject: [RCSE] Futaba S9650 Servo
reports.
> Cheers, Les.
MIME turned off.
Old Aug 21, 2004, 04:11 PM
Harley Michaelis
Harley Michaelis
Guest
n/a Posts
Darwin. . .the picture of the servo is not entirely clear with regard to the
mounting lugs on the side. Are there a pair on each end, similar to the
Airt.94141, or is there a single one in the center of the case?
I could never see the logic of pairs on each end where thin wings were
involved. Seems you either need a base thick enough to drive a screw into to
secure the servo using a "bottom" lug. . .or cut it off and use a "top" lug
with a rail underneath it on a base. In either case, you are either using up
precious vertical space with a base taking it up with a protruding screw
head.
On the other hand, servos with a center lug provide space under it for a
rail and it does not matter if the screw head protrudes above the lug.
It appears the lugs on the 9650 are similarly placed as on the Airt. 94141.
When I used that servo, I always cut the things off to install in a wing,
finding the "hat bracket" a better way to mount the servo.
What's your appraisal with regard to lugs on this servo?
To: "Les or Gypsy Stockley" <stockley@slingshot.co.nz>; "soaring"
Sent: Saturday, August 21, 2004 10:29 AM
Subject: Re: [RCSE] Futaba S9650 Servo
> Hi Les,
> Darwin N. Barrie
> Chandler AZ
> reports.
> > Cheers, Les.
that
> MIME turned off.
MIME turned off.
Darwin Barrie
Darwin Barrie
Guest
n/a Posts
I believe the intent was to make the servo 100% flexible for any
installation. Personally, I just used a small dab of 5 minute epoxy and
didn't worry about the lugs. If I was going to screw them down I'd cut off
the lug that was in the way.
They are much like the 141's but I don't think you'll get the gear train
slop the 141's were notorious for.
Darwin N. Barrie
Chandler AZ
To: "Darwin Barrie" <ktlkrn@cox.net>; "Les or Gypsy Stockley"
<stockley@slingshot.co.nz>; "soaring" <soaring@airage.com>
Sent: Saturday, August 21, 2004 12:13 PM
the
to
lug
up
> head.
94141.
> From: "Darwin Barrie" <ktlkrn@cox.net>
> > Hi Les,
> > Darwin N. Barrie
> > Chandler AZ
> > reports.
> > > Cheers, Les.
"subscribe"
> that
> > MIME turned off.
that
> MIME turned off.
Found Wanted Futaba s9650 servo ncpiperpilot Aircraft - General - Radio Equipment (FS/W) 2 Oct 03, 2006 12:11 PM
Discussion Ideas for mounting a Futaba S9650 Servo to Corona mlgreene Electric Heli Talk 6 Aug 10, 2006 06:17 PM
Wanted WTB damaged futaba s9650 servo aamiggo Aircraft - Electric - Helis (FS/W) 2 Jun 11, 2006 02:00 PM
Question Futaba S9650 Servo Availability Dynomike Mini Helis 13 Mar 04, 2006 10:25 PM
Where can I buy gear sets for Futaba S9650 servo for my logo 10 UAVProducts Electric Heli Talk 2 Mar 24, 2005 05:51 PM
