I've had both planes out to almost uncomfortably far distances where they were just specks, with never the slightest loss of control. No argument, the Berg is a superior piece of avionics, but for the little stuff I'm quite happy with the Pico. Glenn |
I purchased a complete SlowStick off ebay (something I don't think I'll do again...) GWS 4N receiver 2 GWS Mini std servos ICS 100 ESC When I finally powered it up, I turned on the receiver and the servos started to twitch! Once I powered up the transmitter, she calmed right down and the servos re-centered themselves. This tends to indicate to me that some sort of stray RF is getting into the system until the transmitter's carrier overpowers it. Maybe it's my computers? There are no major RF sources nearby... I plan to do then maiden voyage with an RC buddy from work on Sunday. between the two of us (we are TV broadcast engineers) we might be able to unravel this mystery and report back... Looking forward to video from on wing, I remain, Ack |
You should never put power to the RX without first turning on the TX no matter what kind of RX you have. Good way to strip out a servo before ever getting to fly it. There will always be some sort of signal that the RX will pick up. |
Southern MA. USA
Joined Jan 2003
Ack,
When you plug your battery pack to the Rx it starts looking for a signal that is not there untill you turn on the TX, it then calms down because the signal that it gets is that it should be at rest ( in the neutral position ) untill you command it by moving the sticks on the TX. It basicly is doing what a chicken does when it's head is cut off, runing around nuts waiting for input from the brain. Always turn on the TX before plugging the battery to the plane. BTW- The GWS 100 ESC is too small for the 300 SS, it's only rated for five amps, it will overheat and start to break down causing glitching, going to the 300 8 ~ 15 amp will prevent this from happening. Moe |
I lost my Slow Stick due to the same problem a few weeks ago. On climbout
the plane went haywire and did a highspeed dive from around 80 feet alt - lost all control. That was with the antenna going out on the left wing, and my TX antenna was fully extended (some have lost planes this way, forgetting to do this). I spent $79 on a new Berg 6 channel RX and the thing is rock solid!! I love it, well worth the money. No more glitching. |
Berg = bye bye glitches.
I have one four and four fives. They are great. It is good to be able to rule out one problem quickly. Berg does that. LcJ |
Latest blog entry: Own your own - What it means
I took it to HobbyTownUSA and tried to trouble shoot the problem.
We ended up switching out the motor and I was able to walk between 50-70 feet away with the motor running and had no glitches until I reached the range limit. I had the antennae all the way in when testing. I took it to the park and I still get the motor cutting just 100 feet away but not as bad as it was before. There is still a problem but it appears that the problem may have to do with the motor producing static in the fuselage. I have the motor mount stuck to the metal fuselage stick using a screw. Any suggestions on dealing with the motor interference? |
Oh well... On the Learning curve, Ack |
| Thread Tools | |
| Discussion GWS R4P Receiver problem...help? | freedomflyer | Beginner Training Area (Aircraft-Electric) | 3 | Feb 27, 2006 08:44 AM |
| Help Go Brushless First Time With Slow Stick Gws | agapornis | Power Systems | 1 | Mar 01, 2005 05:12 PM |
| Help! Help Slow Stick GWS 400 | onecb | Beginner Training Area (Aircraft-Electric) | 9 | Sep 09, 2004 04:25 PM |
| GWS receiver? Please help... | Vincent | Radios | 2 | Jul 20, 2002 10:05 PM |
| GWS receiver? Please help... | Vincent | Foamies (Kits) | 7 | Jul 07, 2002 09:19 PM |
